Interesting Torque Converter Discovery - Page 2 - TundraTalk.net - Toyota Tundra Discussion Forum
post #16 of 21 (permalink) Old 03-28-2018, 09:31 PM
mrmachinist's Avatar
Quoted: 485 Post(s)
@ToyotasForever
The obd fusion app shows it has a watch and iPad app as well in the App Store.
I am just looking into getting this but thinking that app will be the best fit for me. Trying to pick out a Bluetooth adapter. I would like the kiwi but donít really want to spend that much but Iím scared to cheap out and be unhappy.
Edit: ordered this one 1/4 the price of the kiwi3 with similar reviews. Still listed as compatible on the obd fusion app.
https://smile.amazon.com/gp/aw/d/B07...?ie=UTF8&psc=1
If itís junk Iíll order the kiwi
mrmachinist is offline
The Following 2 Users Say Thank You to mrmachinist For This Useful Post:
MtnClimber (03-30-2018), ToyotasForever (03-29-2018)
post #17 of 21 (permalink) Old 03-30-2018, 12:06 AM
Quoted: 58 Post(s)
Originally Posted by ToyotasForever View Post
MtnClimber,
I have a 2014 DC 5.7, and an old (but working) iPad that was given to me, that I'd like to use with an OBDII data-reader for now, and later, have that same OBDII adapter work with an iPhone.
I try to limit the amount of WiFi my wife is exposed to, as she is a breast cancer survivor with a genetic sensitivity to radiation, and medical science has not yet ruled out the (potentially-negative) effects of even low amounts of EMR, especially given her particular genetic mutation's known sensitivity to (some forms of) radiation.
Since (I understand that) BlueTooth puts out less wattage than WiFi, I'd like to find a Bluetooth-compatible OBDII scanning device like you all are using, that would work with the iPad, and an iPhone.
Can you (or anyone else?) recommend an ODBII-reader that would use Bluetooth and work with BOTH my current iPad and an iPhone?
Also, ideally, I would like to scroll through menu choices, rather than enter whatever these "clunky PID codes" are that folks are referring to, as being required to operate some of these adapters.
Thanks in advance,
ToyotasForever
Not sure the question can be answered as to will it work with both your current iPad and iPhone without knowing which models you have. The problem you may have with older models is that they don't support Bluetooth 4.0 which is required by the better OBDII readers. I believe Apple began using Bluetooth 4.0 in the iPhone 4S and iPad 3rd Gen (iPad 3) and all newer models.
I have used the Kiwi3 with iPad Mini 4 and iPad Air 2, both of which are fairly new models. The mapping function in OBD Fusion doesn't work as these wifi-only iPads don't have built in GPS, but that's not a show stopper for me.
Here's a picture of my present set-up in action...
2012 Silver Sky Metallic Sequoia SR5 4WD 4.6L
TRD Pro eng skid, Or-Fab trans skid, custom transfer case skid, RCI gas tank skid, 1.75" lift with 6112 on lowest notch, Wheeler's Superbumps (front), Revtek 441R & 5100 (rear), Michelin Defender LT275/70R18 on MB Chaos +25, 3rd Row Removed
MtnClimber is offline
The Following User Says Thank You to MtnClimber For This Useful Post:
ToyotasForever (06-11-2019)
post #18 of 21 (permalink) Old 03-30-2018, 12:13 AM
Quoted: 58 Post(s)
The specs on the Veepeak look good as far as I can see. "wonít drain your battery even if you leave it plugged in for weeks" is a nice feature that the Kiwi also has. Let us know how it works out, either way.
The Following 2 Users Say Thank You to MtnClimber For This Useful Post:
mrmachinist (03-30-2018), ToyotasForever (06-11-2019)
post #19 of 21 (permalink) Old 03-31-2018, 01:33 AM
Quoted: 485 Post(s)
I got it in today. Connected right away to obd fusion. I bought the Toyota expansion and it took a little bit to get the pids to show up. Going visit my mom tomorrow about an hour away Iím going to play with it some more. First impressions are good so far.
On a side note which trans temp is the pan and which is the TC out of 1 and 2?
The Following 3 Users Say Thank You to mrmachinist For This Useful Post:
MtnClimber (03-31-2018), R. Spiker (03-31-2018), ToyotasForever (06-11-2019)
post #20 of 21 (permalink) Old 03-31-2018, 08:28 AM Thread Starter
R. Spiker's Avatar
Quoted: 11 Post(s)
That's easy to determine. Once the truck has warmed up, drop the tranny into 3rd gear and take off from a stop. One of the two tranny temps will start to climb. That is your torque converter.
2014 Limited CrewMax 4x4 w/ tow mirrors and 46 gallon Transfer Flow fuel tank pulling a Lance Travel trailer
R. Spiker is offline
The Following User Says Thank You to R. Spiker For This Useful Post:
mrmachinist (03-31-2018)
post #21 of 21 (permalink) Old 03-31-2018, 12:21 PM
Quoted: 58 Post(s)
Good answer. I might have said it a bit different. When the truck is cold, drop the tranny into gear, hold the brakes, and give it a tiny bit of gas. One of the two tranny temps will start to climb. That is your torque converter.
  TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > Tundra Drivetrain
