Sound deadening - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 23 (permalink) Old 10-12-2018, 01:37 PM Thread Starter
Jai
Jai's Avatar
Quoted: 11 Post(s)
Sound deadening
Hello, sorry if this has been covered. Looking to reduce the highway noise in my 2018 CM 1794. Just got a quote from Car Toys (DFW area) $3k for materials and install (dyno materials). Any thoughts? Seems pretty pricey to me
Jai is offline
post #2 of 23 (permalink) Old 10-12-2018, 02:43 PM
Quoted: 4 Post(s)
It's a pretty in depth job and can get up there in price. But $3k is insane.
Considering that you would need no more than $4-500 in materials, you're looking at $2500 in labor. Are they doing the inside and outside of the doors? Are they building steel panels to cover the door holes? Are they doing the floor and roof? If so, I can see getting to that price. But if not, I would get another quote.
hypa is offline
post #3 of 23 (permalink) Old 10-12-2018, 04:27 PM Thread Starter
Jai
Jai's Avatar
Quoted: 11 Post(s)
No steel panels, but they will do the entire inside cab. Floors, firewall, all doors, roof and back wall (with the power window). And they will add a thick foam layer to the floor.
I know it's a lot of work, but you're right $2500 is a lot for labor.
Jai is offline
post #4 of 23 (permalink) Old 10-12-2018, 07:05 PM Thread Starter
Jai
Jai's Avatar
Quoted: 11 Post(s)
Second thought, going to do the doors myself, probably going with the Dynamat Extreme material. $151 on Amazon... we'll see how this goes.
Jai is offline
post #5 of 23 (permalink) Old 10-13-2018, 12:26 AM
1lowlife's Avatar
Quoted: 1237 Post(s)
I did all my doors (inside and out), back wall, and entire floor area in my 2014 DC.
Didn't do the roof.
Did Dynamat all over and Dynaliner on rear wall and under the back seat.
Dynamat
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Dynaliner
The roller came in very handy.
https://www.amazon.com/gp/product/B0...WE3VTYF1JYYF6X
Took me a weekend.
Wife immediately noticed the difference in the noise reduction with my BA muffler and road noise.
She thought I was nuts when I pulled out the entire interior of a new (at the time) truck..
I think I over did the doors because they are heavy and slam with the slightest closure.
I put in on the exterior door skin where ever I could reach it.
I'd put less on the inside of the door (on the plastic under the door panel as pictured) if I did it again..
There is no fu(king way I pay someone $2000 to do it.
Watch a bunch of youtube videos and go for it.
Just be easy putting your interior panels back in, not so much the door panels, but the trim panels.
Before..
After..
Learn it, know it, live it.
Texas Tundra Group #183
1lowlife is online now
post #6 of 23 (permalink) Old 10-13-2018, 12:32 AM Thread Starter
Jai
Jai's Avatar
Quoted: 11 Post(s)
1lowlife, thanks for the pics and info. I've been watching a lot of videos and reading other posts.
So glad I found this forum, saving my wallet and helping my confidence with things I've never done before. Cheers
Jai is offline
post #7 of 23 (permalink) Old 10-14-2018, 09:01 AM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
Dynamat (CLD tiles) is a great start for vibration dampening, as well as a closed cell foam (CCF) to eliminate rubbing. The next step for a true noise barrier is going to be a Mass Loaded Vinyl (MLV) layer. Covering every square inch of your interior in Dynamat is overkill and not necessary, although Im guilty of this as well. lol. I saw the absolute biggest benefit in making my interior quiet once I did the MLV. I have Dynamat on my roof, doors, floor and rear wall, Second Skin Heat Wave Pro (radiant barrier) a layer of CCF and finally a layer of MLV. I did the install myself and with materials I was around $600
This is a great site to start your research before you spend thousands of dollars
https://www.sounddeadenershowdown.co...SAAEgKHpPD_BwE
Jumbo Jet is offline
1lowlife (10-14-2018)
post #8 of 23 (permalink) Old 10-16-2018, 04:55 PM
walter93's Avatar
Quoted: 10 Post(s)
This is making me want to do more sound deadening. I just cringe at taking out my entire interior to do it.
walter93 is offline
post #9 of 23 (permalink) Old 10-17-2018, 05:48 PM
#CJ
#CJ's Avatar
Quoted: 11 Post(s)
You and me both. But I bet those trucks sound so dang quiet on the inside. Must be nice.
CJ
2014 Toyota Tundra Magnetic Gray Metallic SR5 w/TRD Off-Road Package
#CJ is offline
post #10 of 23 (permalink) Old 10-17-2018, 06:48 PM
Powertechn2's Avatar
Quoted: 1642 Post(s)
I did my 2010. All doors inside outer panels, and inner skeleton area, as well as rear wall inner, and outer, and the inside of the between panel that the 2010's had, and any part that I had access to while installing speakers, parts of the floor etc...
It made a huge difference even though I only used FatMat extreme (pretty sure it was the extreme). I did not do the entire floor as I didn't have enough time to remove my entire interior.
The doors alone made a huge difference. Night and day quieter vs my 2017 Plat. Both trucks were/are CM's.
I would not pay someone 2500 in labor to do it though. I would diy.
and you can call me Power.
Powertechn2 is offline
post #11 of 23 (permalink) Old 10-18-2018, 01:33 AM
1lowlife's Avatar
There really isn't much to it.
Remove the seats and console (if you want), the interior panels pretty much snap on and off.
Just be careful snapping them back in.
Give yourself a couple days or a weekend to get it done.
post #12 of 23 (permalink) Old 10-18-2018, 09:19 AM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
Yeah, no need to rush it. I did mine over a couple of weekends. I set a goal for the day and then wrapped it up by the end of that day. Unless you have enough space to close up the garage and leave your truck gutted inside over night. I did my doors on Saturday, then my roof on Sunday. The next weekend I did my floors and back wall. Super easy to tear these trucks apart.
post #13 of 23 (permalink) Old 10-20-2018, 01:25 PM Thread Starter
Jai
Jai's Avatar
Quoted: 11 Post(s)
Thanks for all the info and pics, gave me the confidence to give this a go. Did all my doors, went with Noico (less expensive route). Really noticed the difference.
However, driving in the rain really tells me that I have to do the floors and maybe the roof, very intimidating.
Not doing this for audio, just for quiteness during the ride.
Jai is offline
post #14 of 23 (permalink) Old 11-04-2018, 07:05 AM Thread Starter
Jai
Jai's Avatar
Quoted: 11 Post(s)
What type and where did you get the MLV that you used?
Jai is offline
post #15 of 23 (permalink) Old 11-05-2018, 09:18 AM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
I bought my MLV from Sound deadener showdown... that link I posted. He will help you calculate how much you'll need so you're not wasting material. He has the exact material figured out for a Tundra
https://www.sounddeadenershowdown.co...ckup-2007-2015
