2008 5.7 long box 4wd...brakes and suspension - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 6 (permalink) Old 05-06-2018, 11:05 PM Thread Starter
Quoted: 3 Post(s)
Hi All,
I am preparing to tow a Travel Tralier. GVWR on the trailer is 8500lbs, but I doubt I would get above 7500lbs.
My 2008 has 71k miles. I have never replaced the suspension, and I think I have done the brakes once...maybe. Extended cab, no TRD.
Given my undertaking, I am considering upgrading the suspension in the interest of towablity and the brakes for safety.
I cannot go "whole hog", but I will not cheap-out either.
I would appreciate any feedback on set-ups for both new breaks/brake system and suspension.
Thanks for your time.
If "Ctrl+S" saves, what does Jesus do?
Team Coors Light is offline
post #2 of 6 (permalink) Old 05-09-2018, 10:03 PM
volleyball's Avatar
Quoted: 584 Post(s)
EBC yellow pads. Get the bilstein shocks/struts. you can get them with no lift.
volleyball is offline
post #3 of 6 (permalink) Old 05-11-2018, 01:01 PM
riccnick's Avatar
Quoted: 361 Post(s)
Just buy quality / oem parts then if you're not trying to go ham on the budget. Get Centric brake parts from rockauto.com, or go with NAPA brand if you like shopping in-store (and feel like paying more for no reason), and Bilstein replacement shocks from wherever you can find them. Shouldn't cost too much and will give the piece of mind for the trip.
2019 Ram 1500 Laramie Crew Cab
Hemi eTorque 4x4
12" Uconnect, Air Ride, Pano Roof
Dearly Missed: 2010 Toyota Tundra DC 5.7l, TRD Off Road, 4WD Silver Sky Metallic
Front only Bilstein 5100's at top setting
TRD Rock Warrior Wheels LT 285/70R17E BFGoodrich All Terrain T/A KO2's
riccnick is offline
post #4 of 6 (permalink) Old 05-11-2018, 02:45 PM
He Has Risen!
RRzxter's Avatar
Quoted: 3624 Post(s)
Brakes and tires are the 2 most important things on your vehicle.
And if your brakes are in good shape and the trailer has electric brakes,
then tires are by far much more important than shocks.
And I would be more concerned about tongue weight of the trailer and tires and springs, not shocks.
Springs support the load, the shocks absorb shock and limit bounce/travel.
Post your tire specs/condition and find out tongue weight of your trailer and report back.
RRzxter is offline
The Following User Says Thank You to RRzxter For This Useful Post:
riccnick (05-11-2018)
post #5 of 6 (permalink) Old 05-13-2018, 03:54 AM
koditten's Avatar
Quoted: 533 Post(s)
I can't believe you need anything with only 71k on the truck.
Get a load equalizing hitch and off you go. No need to worry about upgrading suspension.
KO
TWAC (formally know as TWAT) #69
Mods:
AIP delete
TPMS delete
Rear camera install
koditten is offline
post #6 of 6 (permalink) Old 05-16-2018, 12:30 PM
Quoted: 110 Post(s)
I agree with @koditten - give everything a once over and go. I’ve got almost 100k on original brakes and everything still works great when towing. I upgraded my shocks a while back, but unless he stickers are worn out they should be fine. If you are looking for an excuse to upgrade, then Billstein 5100, as memtioned, would be a great choice, IMO, as they perform great, especially for the money.
Tires are also definitely worth mentioning. Check the date code on them and if they are older than 7 years, weather checked, or worn, get a new set. E rated tires aren’t necessary for occasions towing, but do provide a more stable towing experience. Either way, make sure the tires are properly aired up. Depending on the tongue weight and how much transfer u can get with the Wd hitch, I prefer abt 41+ psi in stock P rated tires and about 55 psi in E rated tires (assuming they are stock size).
2013 5.7l DC RB 4x4 TRD MAG GREY w/TOW PKG, WTEC MTS, BGDFLCTR, LOPRO TNO, BDRG, COACH ShKLS N BSHNGS, 45BKUPCAM, DYNAMT W/DB-3 MLV, PRMSiQ, PNR AVHX2500BT, H11_2_H9, Hlla500FF, MGMC #203, TRDSwyBr, PNR TSD1720C, JBLGTO628, PNR GMD8604, INF860w, FX2.0RR, BIL6112, IcnLefPk, RidRitBgs, DystrCrdl
Originally Posted by bbq247265 View Post
Blenton = Mike Sweers
Blenton is offline
  TundraTalk.net - Toyota Tundra Discussion Forum > Off Topic Section > Off-Topic Discussion
HTML code is On
