2007 Tundra Transmission problems - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 7 (permalink) Old 05-11-2016, 09:41 PM Thread Starter
07 Tundra dual cab SR5, V8
Clutch does not engage when cold or after sitting for a day or more.
Have to rev engine to get fluid to clutch, then it works.
Transmission does not down shift when breaking hard to stop or slow down. Engine revs up then slams into gear.
Check Engine light came on, Traction Assist slip indicator light on, and VSC light were on. Dealer saw 4 errors tagged, showing transmission solenoids have failed. Transmission fluid leak.
Dealer Solution: Replace the transmission and replace the drive shaft
$8,500, plus $1,000 to replace the leaky water pump. Charged me $150 for diagnosis and 2 quarts of fluid.
My Solution: go to a transmission specialist.
diagnosis was free, faulty transmission fluid pump, possible solenoid problems, leaking water pump. Cost $1800. If rebuild is needed, then $4,000.
$800 deposit for them to pull the Tranny and find out what is really the problem. Will know tomorrow.
Dealer did two recall repairs. No charge. Driver door window switch and reprogram computer for disabling gas pedal when braking hard.
pmorinishi is offline
post #2 of 7 (permalink) Old 05-11-2016, 09:43 PM Thread Starter
Also, the transmission specialist is able to fix the transmission leak without replacing the entire drive shaft, which is required by Toyota dealer.
post #3 of 7 (permalink) Old 05-11-2016, 10:28 PM
bigsapz's Avatar
Quoted: 184 Post(s)
How many miles?
bigsapz is offline
post #4 of 7 (permalink) Old 05-11-2016, 11:33 PM Thread Starter
134,000
I bought this car last year from the original owner, who claimed he had no issue with the transmission.
Started having problems about 3 months later, after transmission fluid leaked out.
post #5 of 7 (permalink) Old 05-12-2016, 02:00 PM
Supporting Vendor
1AAuto.com's Avatar
Quoted: 110 Post(s)
Welcome to the site it's great to have you here
Tony
SHOP HERE FOR AWESOME
1AAuto.com is offline
post #6 of 7 (permalink) Old 05-12-2016, 02:09 PM Thread Starter
Has anyone else experienced this problem and gotten it fixed?
Truck is no longer under warranty.
post #7 of 7 (permalink) Old 05-15-2019, 12:41 PM
What was the final result? I'm having exact same issue. Nearly identical miles and same year truck.
bluebullet is offline
  TundraTalk.net - Toyota Tundra Discussion Forum > Member Area > New Member Introductions
