coolant leaking - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 3 (permalink) Old 04-16-2019, 12:21 AM Thread Starter
coolant leaking
I have a 2002 tundra with the 4.7 V8 just recently replaced the water pump and timing belt (gates kit) due to my water pump leaking 195k on the truck, so got it all back together it ran fine for about a week and a half then noticed it leaking fluid again, couldn't tell from exactly but figured it was from the thermostat housing area because there was fluid pooling up around the top of the intake and I could see a fresh source of it on the top of the water pump area where it mates up to the front of the engine. So tore it down again and replaced a failed O Ring and then reassembled and used extra sealant around the thermostat housing and O Ring area, started it ran fine then the leak started again! So I am going to tear it down again and replace the water pump gasket ,O Ring and look for anything I missed the other 2 times.
Does anyone know where this leak might be coming from?
Kiki8675 is offline
post #2 of 3 (permalink) Old 04-25-2019, 07:59 AM
Buckaroo's Avatar
Quoted: 15 Post(s)
I don't know that V-8 but if you are seeing the leak in that area and you have verified it is not the thermostat, re-checking the water pump seems like the right thing. Would also replace the radiator cap if you have not done so recently - easy & cheap. Also check your overflow tubing/reservoir for cracks.
Buckaroo
Buckaroo
- 2017 Limited Tundra DC 5.7L 4WD
- 2017 XLE Camry 2.5L
- 2010 Mazda Mx-5 Touring
- 2004 EX Accord 2.4L
- 2002 XLE Camry 2.4L
- 2000 4Runner 3.4L 4WD
Buckaroo is offline
post #3 of 3 (permalink) Old 04-25-2019, 07:20 PM
ViktorG's Avatar
Quoted: 289 Post(s)
The smaller o-ring behind the water pump can get rolled easily if not lubricated during install and leaks, seen that several times after water pump replacement on those engines.
2010 RCSB ([email protected] on NOS) - AWD conversion, Pauter rods, JE 8.5:1 pistons, Ti int & SS exh valves, Ti retainers, 5 angle valve job, P&P heads, TRD SC w/ 50mm pulley, ASP crank pulley, 84mm TB, SABM, IPT VB, JBA LTs, Killer Chiller, 1.25 Gal IC tank, Frozenboost 101 HE, IKH-24 plugs, 325 LPH AM FP, 2"/4" Belltech drop, weight reduction
ViktorG is offline
  TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > First Gen Tundra 2000-2006
HTML code is On
