Confused on which gear oil for rear diff (LSD), transfer case and front diff - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 7 (permalink) Old 08-23-2018, 01:42 AM Thread Starter
Quoted: 3 Post(s)
I've read several long threads on various forums about replacing the gear oils in the front diff, transfer case and rear diff. I've got a 2006 V8 4x4 with 139k miles and a LSD rear diff. I just bought the truck and have no idea (no service records) if/when any of gear oils have been changed, so I'm going to do it myself. Sorry for the noob questions, but y'all have been very helpful, so I hope you don't mind a couple more questions.
The official Toyota owner's manual says to use 80w-90 hypoid gear oil for the front diff and transfer case and "synthetic hypoid gear oil for LSD differentials 80w-90 GL-5"
I've read people using Amsoil, Royal Purple, Lucas, Mobil 1, etc. I'm confused by all the options. The Amsoil oil I'm considering says it's good for LSD differentials. I just want to be sure I get the correct stuff. I'd also prefer if I can just buy 7 quarts of one type of oil to use in all three locations.
One question I have is there any danger to using gear oil that contains LSD additives and apply it to the front diff and transfer case?
For example, here is the recommendations that Amsoil has for my Tundra:
Limited Slip Differential, Rear 4WD DblCab W/ LSD......GL-5*
Below 0 F......80W-90, 80W [1]
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Severe GearŪ 75W-90 (SVGPK)
Severe GearŪ 75W-110 (SVTQT)
Above 0 F......90 [1]
Standard Differential, Front......GL-5
All TEMPS......75W-90
Transfer Case,U/K TRC......GL-5
So I was thinking the simplest and most factory spec would be the Amsoil SAE 80W-90 Synthetic Gear Lube (AGLQT). Would this be ideal? Do I need any additional LSD additive? The description for the Amsoil additive "Slip Lock" says it's not required for Amsoil synthetic gear lubes as those lubes already have the additive. The gear lube I linked to says only to add the SlipLock additive if LSD chattering occurs.
It gets to below 0F a bit in winter, coldest I've seen is -20F and up to 105F in summer. I plan to use the truck more in winter than summer most likely and will definitely need the 4WD on our snowy and steep dirt driveway. I'm hoping I can just change all the gear oils at once, with one type of lube and not have to change for 50,000-100,000 miles (according to Amsoil).
Last question, what would the advantage be for the 75w-90 Severe Gear Amsoil option?
markofrost is offline
post #2 of 7 (permalink) Old 08-23-2018, 12:32 PM
MetalMonkey's Avatar
Quoted: 369 Post(s)
Don't keep us in suspense ~ post up some pics !
@markofrost
MetalMonkey is offline
post #3 of 7 (permalink) Old 08-23-2018, 12:45 PM
MYT1's Avatar
Quoted: 15 Post(s)
I just went through all this myself.
I ended up using Mobil One 75w/90.
I remember wrestling with the same questions you are and somehow I settled on the Mobil 1.
Two things:
Do you have a true LSD, or do you have the electronic LSD that comes with a lot of Tundras? I think it makes a difference. I also think most Tundras have the electronic LSD, in which case you don't need any special additives.
Second thing.
The drain plug of the front differential might be on there very, very tight. I couldn't get mine off and I ended up stripping the bolt.
When I watched a YouTube video on how to change the front differential fluid the mechanic had all sorts of problems removing the bolt. I didn't think too much of it, but since then I have seen other threads where people had all sorts of difficulty removing that bolt. I know I did. I think they were over tightened at the factory.
Changing the transfer case and rear differential was very easy.
Good luck.
MYT1 is offline
post #4 of 7 (permalink) Old 08-23-2018, 06:12 PM Thread Starter
Quoted: 3 Post(s)
@markofrost
Hah! I'm jumping the gun here. We are 98% set on buying a particular Tundra this weekend. We've got to do a daylong drive to go look at and get it. But between speaking with the owner, Autocheck, Toyota Dealer's it was serviced at, etc, we're pretty sure this is a good deal for a fine truck. I'll post up photos once we get it!
The Following User Says Thank You to markofrost For This Useful Post:
MetalMonkey (08-23-2018)
post #5 of 7 (permalink) Old 08-23-2018, 06:14 PM Thread Starter
Quoted: 3 Post(s)
Two things:
Second thing.
Good luck.
This is all very helpful info, thank you! Still not yet sure on the gear oil to use, but I really appreciate the heads up on the tough bolts on the front diff. I might just save that one for a real mechanic to tackle since I really don't like dealing with stripped things like that.
BTW, did you have to re-tap the bolt hole threads or was it as simple as just replacing the bolt with a new one, once removed?
post #6 of 7 (permalink) Old 08-24-2018, 08:49 AM
MYT1's Avatar
Quoted: 15 Post(s)
I haven't dealt with the stripped bolt yet, although I did buy a new bolt and I have it ready for when I get the stripped one off.
I plan on taking it to a mechanic to remove the bolt.
Before trying to remove the drain bolt, I removed the filler bolt...something I learned on the YouTube video. You don't want to drain the oil and then find you can't get the filler bolt off to add new oil.
Anyway, some oil leaked out of the filler bolt hole and it looked very clean...my truck has 129,000 miles and I don't 4 wheel that much...so I topped off the oil and I will deal with the stripped bolt in a few weeks when I get back from a trip.
Good luck.
MYT1 is offline
post #7 of 7 (permalink) Old 08-24-2018, 08:37 PM
Powertechn2's Avatar
Quoted: 1657 Post(s)
Always remove the fill plug first. If you can't get the fill plug out, don't drain it...
I used and will use Amsoil when I changed the 2010, and when I change the 2017 in spring of next year.
Different years, but yes, most Amsoil synthetic gear lube already has the slip lock additive in it.
I am set up myself for Amsoil, and the pricing is worth it.
You can put the year/make/model in the lookup, and it will tell you what it offers, in the correct weights, and give you options as far as what they offer in different levels of protection.
and you can call me Power.
Powertechn2 is offline
  TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > First Gen Tundra 2000-2006
HTML code is On
