Pressure washer - Page 5 - TundraTalk.net - Toyota Tundra Discussion Forum
post #61 of 68 (permalink) Old 04-01-2019, 08:21 AM
WhiteOut15's Avatar
Quoted: 27 Post(s)
Originally Posted by StevenD View Post
NO NO NO NO NO!!! You pressure washer is NOT rated for hot water. You will burn out the pump in no time flat.
got it!
15' CM 4x4(whiteout coming soon)
Matching tint,Retro headlights,LED's everywhere
3/1 rough country lift,20x10 XD Addict
35.12.5x20 Nitto Terra Grappler G2
WhiteOut15 is offline
post #62 of 68 (permalink) Old 04-01-2019, 08:25 AM
Stealth Ninja Moderator
StevenD's Avatar
Quoted: 11295 Post(s)
Originally Posted by WhiteOut15 View Post
got it!
unfortunately, hot water pressure washers are very expensive. They could be very useful though.
2015 Tundra CrewMax 1794 2WD
ddd
ddd
StevenD is offline
post #63 of 68 (permalink) Old 04-01-2019, 08:48 PM
Powertechn2's Avatar
Quoted: 1657 Post(s)
Hot water definitely cleans better. I always use hot for my buckets.
As for the PW, some are rated for hot water input, but limited to 120, some are limited to 140, and you don't want to let it run for long without water coming out. It will also shorten the life of the pump, even if rated for hot water input. But warm water, like 100 is still better than cold water, however it's even more inconvenient than using just hot from say the wash tub. Now you have to run, adjust the faucets to mix etc...
If it can handle warm/hot input it should say it in the specs.
and you can call me Power.
Powertechn2 is offline
post #64 of 68 (permalink) Old 04-02-2019, 12:16 AM
ACDan's Avatar
Quoted: 5865 Post(s)
A lot of on-demand water heaters have a thermostat you can adjust to that safe range.
2016 SR5 DCLB 4X4
ACDan is offline
The Following User Says Thank You to ACDan For This Useful Post:
Powertechn2 (04-02-2019)
post #65 of 68 (permalink) Old 04-02-2019, 03:23 AM
1lowlife's Avatar
Quoted: 1270 Post(s)
I didn't think i needed a power washer until I started reading this thread.
So gasoline is the way to go and not electric?
That is what I gathered...
Learn it, know it, live it.
Texas Tundra Group #183
1lowlife is offline
post #66 of 68 (permalink) Old 04-02-2019, 07:06 AM
StevenD's Avatar
If youre going to do it, do it right! I just got this.
4000psi, 4.0 GPM, electric start 13HP Honda GX 390, CAT Pump, all aluminum cart
ddd
ddd
StevenD is offline
The Following User Says Thank You to StevenD For This Useful Post:
post #67 of 68 (permalink) Old 04-02-2019, 07:52 AM
StevenD's Avatar
I also have this in my garage. Its electric, only 1800psi and 2.0 gpm. But, its great for washing cars, hosing out the garage, etc. Its quite nice to walk up, unroll the hose and flick a switch to make it work. A lot less hassle than a gas powered pressure washer.
ddd
ddd
StevenD is offline
The Following 2 Users Say Thank You to StevenD For This Useful Post:
1lowlife (04-02-2019), Powertechn2 (04-02-2019)
post #68 of 68 (permalink) Old 04-02-2019, 06:56 PM
All depends on usage.
I have an electric I have had for about 9 years, works great. Cheap Huffky (husky/hd) unit. Auto shut off stopped working, but it still works great.
I also have a large commercial gas unit, 13hp Honda engine, AR pump. I don't use it often. Check valves are failing as the gpm requirements were too much for the previous owners well, cavitation smokes check valves, I got it used for next to nothing.
With high flow units, if you starve them for water from not enough flow on input side, the check valves can fail due to actually sucking too hard and starving for water on old well systems. Had an issue with a company that takes care of a stadium in Detroit. Really long supply hoses as not a lot of water spickets, cheap small diameter hoses... Check valves would only last 1-2 months tops.
Also gas units if they sit, it's just like other gas equipment, carbs get gunky etc... Eventually I will fix it. But my electric one hasn't given up the ghost yet.
Gas is great if you are not near outlets.
1lowlife (04-03-2019)
