Headlight Restoration - 3M Kit - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 15 (permalink) Old 05-05-2015, 07:47 AM Thread Starter
Quoted: 234 Post(s)
Just thought I'd share my experience with this in case anyone is looking. My 08 headlights started getting a slight fog/cloudiness to them in places. I hadn't paid that much attention to them until I was washing it last weekend, I started noticing it. While I was in Advance Auto last night, I wanted to look at the kits. Previously I tried one of the liquids on a grand cherokee I had, and it didn't work well. I talked to one of the guys in there, and he recommended the 3M kit. I bought the kit that polishes, and used with a drill.
As for how it works, I thought it turned out much better. Be sure to go through the prep work with taping the truck or else you will get scratches on the paint. The instructions were very clear and easy to follow. I thought the sanding pads worked well, and everything went on and off very easily. Overall, I'm pleased with the results. I would post pictures, but in the ones I took last night, you couldn't tell much from the way the sun was hitting, plus my lights weren't completely dull.
08 Double Cab, 4.7L, 4x4
275/70/18 Nitto Ridge Grapplers
18x9 Vision Warriors
2" MotoFab Leveling kit
Flowmaster Super 50 Series Dual In/Dual Out
parker44 is offline
post #2 of 15 (permalink) Old 05-05-2015, 07:57 AM
Stealth Ninja Moderator
StevenD's Avatar
Quoted: 10804 Post(s)
The 3M kit works great. I used it many years ago on a 8 year old camry and when I was done, they looked brand new.
2015 Tundra CrewMax 1794 2WD
ddd
ddd
StevenD is offline
post #3 of 15 (permalink) Old 05-27-2015, 10:41 AM
Grayhawk's Avatar
Quoted: 29 Post(s)
What sealant did you use?
_______________________________________________
Tri-State Member #29
Things with wheels:
'07 White 4.7L SR5, Ceramic pads, Drilled & Slotted rotors. Weathertechs, Borla Cat back Exhaust in the mail.(more coming soon)
'03 Yamaha(Toyota) R1; Custom white w/ red flake paint, HID's, Flush Mounts, swingarm mounted license plate, Red L.E.D. under glow.
'97 Nissan Maxima GLE Stock.
Imagine what I would have if I didn't upgrade everything I own!!
Grayhawk is offline
post #4 of 15 (permalink) Old 05-29-2015, 05:02 PM Thread Starter
Quoted: 234 Post(s)
I just followed through the instructions on the kit, and it came with a 3M polish that I put over it. I think this is what you are asking about?
parker44 is offline
post #5 of 15 (permalink) Old 05-29-2015, 05:55 PM
Grayhawk's Avatar
Quoted: 29 Post(s)
I used the kit but it only came with rubbing compound which is not a sealant.
Things with wheels:
Grayhawk is offline
post #6 of 15 (permalink) Old 05-29-2015, 10:27 PM
#10KungPaoChickenWithRice's Avatar
Quoted: 1184 Post(s)
Be sure to use a lot of masking tape around the headlight area. I'd also double tape the area. I used this product but the drill kicked out and got the paint. So I have a lil "character" mark on the fender. Next time I'll just remove the head light.
Edit: I taped the area but the pad managed to hit the spot with no tape!
#10KungPaoChickenWithRice is offline
post #7 of 15 (permalink) Old 01-01-2016, 07:45 PM
eplanajr's Avatar
Quoted: 14 Post(s)
Below are some before & after pics onmy 2008, using the 3M kit from amazon (i used this one
3M 39008 Headlight Lens Restoration System https://www.amazon.com/dp/B001AIZ5HY..._a1XHwbPTGCCF6 )
Not bad for 30 minutes of work. Next time I'll spend more time, but it also won't be 30 degrees outside..
Sent from my SM-N900P using Tapatalk
2008 CrewMax 4x4 5.7
Past whips: a few fast cars and a few slow trucks.
eplanajr is offline
post #8 of 15 (permalink) Old 09-08-2017, 04:21 PM
volleyball's Avatar
Quoted: 584 Post(s)
My 08 is starting to cloud. I was thinking getting the powerball as I have a car that needs work more than the truck.
I am not looking to go quick and cheap.
I plan on keeping both vehicles a long time so putting in effort and money now is worth it.
So what is the good stuff?
volleyball is offline
post #9 of 15 (permalink) Old 10-25-2017, 11:49 PM
Craig Bireley's Avatar
Quoted: 20 Post(s)
Tooth Paste works.
Craig Bireley is offline
post #10 of 15 (permalink) Old 10-26-2017, 10:09 AM
Danimal86's Avatar
Quoted: 8 Post(s)
ProTip-Keep sanding until the powder that comes off is white. If its yellow or tan, keep going!
2017 Tundra SR5 Crewmax Super White 5.7L 4x4 Trd Off-Road Package
Mods:
Amp Research Power Steps
BakFlip G2
Coming Soon:
Stereo Overhaul
Color Matched Grill and Bumper(s)
Danimal86 is offline
post #11 of 15 (permalink) Old 10-26-2017, 10:22 AM
volleyball's Avatar
Quoted: 584 Post(s)
I did the powerball. I had a car that was in great need and it came out great. My Tundra wasn't looking very bad but I did it anyway. To look at it it's better but not perfect. I decided to stop as visually there is a great improvement and I did the least wear on the surface.
Funny the car that looked worse came out looking better. Could have been I did the car first and then the truck without cleaning the ball.
post #12 of 15 (permalink) Old 06-14-2018, 07:16 PM
volleyball's Avatar
Quoted: 584 Post(s)
I looked at my vehicles. The Tundra still showed the spots the powerball didn't get rid of and the car had yellowed.
I got he Mckees headlight restoration kit. It worked great on both vehicles and the Tundra headlights are now nearly new looking. I applied their sealer but it says it should be applied at each wash. And should be what we in the north consider warm. So I am now looking for a sealer that will last through winter. Anybody got the scoop?
post #13 of 15 (permalink) Old 06-14-2018, 07:55 PM
McGovTundra's Avatar
Quoted: 281 Post(s)
Originally Posted by Craig Bireley View Post
Tooth Paste works.
Find a good bug repellent with DEET in it . Repel with 40% DEET is great. Spray it on and wipe it off. You will be shocked at the improvement. And how much you saved over all of these name brand "kits."
And yes....yes.....yes.....once you use Repel with DEET you will ask yourself "and people spray this sh!t on their children?" Yes. You will a say that.
McGovTundra is offline
post #14 of 15 (permalink) Old 06-14-2018, 10:14 PM
Azblue's Avatar
Quoted: 8753 Post(s)
Just use whatever sealant/polish (I don't use regular wax, doesn't last very long) you use on the rest of the truck. I use Menzerna (now Jescar) Power Lock. Use it on the lens, chrome, and paint ever time you "wax" your truck. The sun here kills paint and headlights quickly, but this works well.
Save The Chrome Club #1
SAVE THE CHROME!!!
Azblue is offline
post #15 of 15 (permalink) Old 07-11-2018, 10:37 AM
Black2Blue's Avatar
Quoted: 3 Post(s)
You must thoroughly clean lenses before polishing them. Get some “Totally Awesome” cleaner from Family Dollar, spray on headlights, watch all the yellow dirt run off, polish by hand with rubbing compound. Done. If lenses are really bad, Spray Awesome, then Extra-fine steel wool, then rubbing compound.
Black2Blue is offline
