Ask the Guru - Detailing Questions - Page 51 - TundraTalk.net - Toyota Tundra Discussion Forum
post #751 of 1983 (permalink) Old 09-14-2013, 09:57 PM
Quoted: 25 Post(s)
I don't believe you have to, but if you don't you're basically removing the bigger marks to replace with finer ones. You should polish it up with 4000 or 1500....C'mon your wife is worth it!
And you could just do one coat of the PL for now-which if you get good coverage will be fine-and then do another coat later on if you want to.
I think that PL on top of PL is diminishing returns big time and from what I was taught by Sensei, is really done just to ensure coverage if any spots are missed.
I think you'll be a lot happier with the results if you polish with the 1500 or 4000 after doing the 400...but test first...you might be good to go after just doing the 1500 and then could go straight to the PL...
JJ could say for sure, but a higher speed and more agressive pad might be enough to get the marks out with the 1500...I think it's going to be one of those "you don't know until you try" scenarios.
halftondra is offline
The Following 2 Users Say Thank You to halftondra For This Useful Post:
morser77 (09-14-2013), Mr. Creosote (09-15-2013)
post #752 of 1983 (permalink) Old 09-14-2013, 10:05 PM
Jumbo, I've been watching all of the ammonyc videos and he seems to be really high on using microfiber pads with his polishers. What the benefits of using these over a foam pad? If SI1500 was the most abrasive polish I was using would microfiber be too abrasive for this? What types of treatments would work better with microfiber pads?
snod12 is offline
The Following User Says Thank You to snod12 For This Useful Post:
post #753 of 1983 (permalink) Old 09-14-2013, 10:27 PM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
Originally Posted by morser77 View Post
Wife just got a 2012 Venza. Gonna clay it tomorrow and was gonna make a pass with SF4000 then 2 coats of PL. Paint is in good shape, usual swirls...Do you think the SF4000 will be enough or should I drop down to SI1500? I also have FG 400.
4000 is a light jeweling polish, it won't give you much cut. Try 1500 with an orange pad and see where you're at. For best results, 400 with an orange pad, don't buff off, and go right over it with 4000 and a green pad. Buff clean and finish should look amazing. Seal with Power Lock. Wait at least three hours between the first and second layer of Power Lock, or apply second layer after your next wash.
Mark
Jumbo Jet is offline
The Following 2 Users Say Thank You to Jumbo Jet For This Useful Post:
post #754 of 1983 (permalink) Old 09-14-2013, 10:34 PM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
MF pads are about all I use for cutting and correcting. Nothing wrong with foam, but MF cuts so much better.
I use Menzerna 400 or M105 with a MF pad for easy cutting power. Then follow with 4000 and a green foam pad. It helps to have an air compressor handy to blow them out and fluff them up in between panels. Or an old stiff brush works well too. They get matted down after a panel or two.
For serious correction, such as a Mercedes with "ceramic-clear" clear coats, I love Surbuf MF pads. Much stiffer fibers than the Optimum, άber or Meguiars MF pads.
post #755 of 1983 (permalink) Old 09-14-2013, 10:38 PM
Quoted: 25 Post(s)
I got the Surbuf pads so for the Tundra the next time I do correction would you suggest a lower speed on the Griot's or finer polish or both?
Working on putting the project together...Just so much to it and I've been busy lately...
The Following User Says Thank You to halftondra For This Useful Post:
post #756 of 1983 (permalink) Old 09-14-2013, 10:40 PM
I order lake country pads yesterday but I must have mistakenly been under the impression they were foam. Thanks for the clarification.
snod12 is offline
post #757 of 1983 (permalink) Old 09-14-2013, 10:55 PM
2010's Avatar
Quoted: 6719 Post(s)
Hey Jumbo,
My wife's new car has some black plastic under the front bumper, feels like a fairly hard plastic. What would you recommend using on that to protect it and give it a nice shine?
2010 is offline
The Following User Says Thank You to 2010 For This Useful Post:
post #758 of 1983 (permalink) Old 09-15-2013, 08:31 AM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
Originally Posted by 2010CrewMaxTRD View Post
Hey Jumbo,
Adams Super VRT.
Jesco (09-15-2013), Mr. Creosote (09-15-2013)
post #759 of 1983 (permalink) Old 09-15-2013, 08:38 AM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
You can play with it and dial in a good speed. The Surbufs won't damage anything, but the fibers are stiffer so they tend to leave tiny little marks on the paint. The marks are more apparent on darker cars, but they come right out with the next step polish and the finish will be perfect. It's really no big deal, just a heads up for people using a Surbuf for the first time.
If you're using FG 400 with a Surbuf, try starting with Griots on 4-5 and see where you're at. You'll get great cut on that speed. Then follow with SF 4000 and a green pad to jewel it out.
Mark
post #760 of 1983 (permalink) Old 09-15-2013, 03:03 PM
morser77's Avatar
Quoted: 1862 Post(s)
So I ended up doing as u guys suggested, 400 right to 4000 then a single coat of PL. the results were worth the 3 hours it took.ImageUploadedByAutoGuide1379271798.601510.jpg
PHP Code:
2008 Tundra DoubleCab 5.7 TRD • 295/70/18 Cooper ST Maxx • BORA 1" wheel spacers • TRD Rear sway bar • TRD front skid plate • TRD CAI • Carrier bearing drop • Front diff spacer • BA Muffler 6" system • Firestick II antenna • Debadged • BHLM
morser77 is offline
The Following 2 Users Say Thank You to morser77 For This Useful Post:
Jumbo Jet (09-15-2013), Mr. Creosote (09-15-2013)
post #761 of 1983 (permalink) Old 09-15-2013, 06:52 PM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
Nice!! Looks amazing. What did you think of Menzerna? Pretty simple, huh?
morser77 (09-15-2013), Mr. Creosote (09-15-2013)
post #762 of 1983 (permalink) Old 09-15-2013, 08:17 PM
morser77's Avatar
Yeah this is the second time I use their product, first on my Tundra. I couldn't be happier with the results I get using the Griots DA and Menzerna. Thx again.
PHP Code:
morser77 is offline
post #763 of 1983 (permalink) Old 09-15-2013, 08:18 PM
morser77's Avatar
What do you guys like to use to get dried wax off of softer rubber like door gaskets etc?
PHP Code:
morser77 is offline
The Following User Says Thank You to morser77 For This Useful Post:
post #764 of 1983 (permalink) Old 09-15-2013, 08:19 PM
jaxadam's Avatar
Quoted: 4 Post(s)
Excellent job! Looks great!
18% Tint
Undercover Lux SE
Big Tundra BHLM with 5k Halos
6k HIDs
20 x 9 Fuel Krank +20 wrapped in Toyo ATII 305/55/20
Pro Comp 3" up front, Coachbuilder +2's in the back
6k Interior LEDS
3D Mats
Textured black N-fabs
Colormatched grill with Grillcraft MX mesh
Debadged
Spyder LED Tail Lights
Matte Vinyl Front & Rear Bumper
JL Audio Stealthbox, Hertz HSK 165's, Arc Audio IDX, Hertz HDP5, Sony XAV-601BT
TRD Duals
More to come...
jaxadam is offline
The Following 2 Users Say Thank You to jaxadam For This Useful Post:
post #765 of 1983 (permalink) Old 09-15-2013, 08:42 PM
Quoted: 25 Post(s)
creamy peanut butter...no seriously...that's what's advised...
