Ask the Guru - Detailing Questions - Page 122 - TundraTalk.net - Toyota Tundra Discussion Forum
post #1816 of 1983 (permalink) Old 01-12-2016, 08:06 AM
firerescue4's Avatar
Quoted: 535 Post(s)
Originally Posted by Jaj23 View Post
Is FG400 now called "Heavy Cut 400"? Having a hard time finding FG400.
Thanks.
Yes it is. They renamed their products. Here is a chart with the old and new names.
http://www.detailedimage.com/Menzerna-Polishing-Chart/
2010 Crew Max TRD
OME 612 front
Coachbuilder +2 Coachbuilder shackles rear with OME shocks
Ranch hand front bumper
Hawk LTS Pads at 4 corners with Centric Powerslot rotors
35X12.50x20 Dick Cepek Mud Country Tires
20X9 +30 Dick Cepek Torque Rims
Diamondback Bed Cover
e-bay Pocket Flares
24" LED Light Bar
K&N drop in
Official Tri-State Member #6
firerescue4 is offline
The Following 2 Users Say Thank You to firerescue4 For This Useful Post:
Dixon Cider (01-12-2016), Jumbo Jet (01-12-2016)
post #1817 of 1983 (permalink) Old 01-12-2016, 08:38 AM
Jaj23's Avatar
Quoted: 1081 Post(s)
Menzerna Polishing Chart - Detailed Image
Thanks,
So should I get SF3500 or SF3800 in place of SF4000? Or should I get the old SF4000 since it is still available in the quart size bottle?
Also, There doesn't seem to be a RED Lake Country polishing pad...should I get the BLUE instead?
Sent from my Atari 2600
Jaj23 is offline
The Following User Says Thank You to Jaj23 For This Useful Post:
post #1818 of 1983 (permalink) Old 01-12-2016, 09:22 AM
Quoted: 535 Post(s)
Any of the polishes you mentioned will be fine for a finishing polish. I use sf 4000. A blue pad for the finishing polish is fine.
2010 Crew Max TRD
OME 612 front
e-bay Pocket Flares
24" LED Light Bar
K&N drop in
The Following User Says Thank You to firerescue4 For This Useful Post:
post #1819 of 1983 (permalink) Old 01-12-2016, 04:58 PM
Migs53's Avatar
Quoted: 46 Post(s)
Welp..... pulled the trigger on some detailing goods. I am a newbie to this self-detailing but am pumped to get into this and keep the paint on my new TRD PRO and wife's RX 350 in tip top shape!
Ordered a truckload of stuff today, so now its just the pressure to make sure my wife's car looks fantastic when I finish with it so I can justify this expense! haha
I ordered:
(1x) Griot's Garage Random Orbital Polisher 6" with a 5" backing plate (only 1 is fine, or do I need to get a 2nd plate?)
(2x) Uber 5 pack foam pad 5.5 inch (assorted color pack)
(1x) Adam's Detail Spray
(1x) 1Z einszett Plastic Deep Cleaner
(1x) Nanoskin Glide Autoscrub System Lube
(1x) 6" Nanoskin autoscrub 6" fine grade foam pad for DA polisher (Do i need to get a larger backing plate for this, or will using the 5" plate be OK?)
(1x) Adams Super VRT
(1x) Sonax Gloss Shampoo Concentrate
(1x) Sonax Full Effect Wheel Cleaner
(1x) Uber detail boar's hair brush
(1x) Wheel Woolie
(2x) 5 gal bucket
(2x) grit guard bucket inserts
(1x) Menzerna SF 4500 Final finish
(1x) Menzerna SIP 1500
(1x) Menzerna Power Lock Sealant
(2x) Chemical Guys Wool wash mitt
(1x) Uber 10-pack no name MF Towel 16x16
So...... i think I got everything I'm needing for a good detail job, inside and out, yeah? Please critique/comment/suggestions if you see something missing from my order that could be somewhat necessary.
Thanks, dudes for all the info, lots of stuff learned from reading through all these posts from the last couple of years - amazing!
Migs53 is offline
The Following User Says Thank You to Migs53 For This Useful Post:
post #1820 of 1983 (permalink) Old 01-12-2016, 05:14 PM
Quoted: 535 Post(s)
I ordered:
(1x) Wheel Woolie
(2x) 5 gal bucket
It's hard for me to think about detailing this time of year here in the Northeast but here it goes. 1,5" backing plate is enough. It will also be fine with the nanoskin. You might want to pick up some more pads and microfiber towels. I go through 2 sets of pads while polishing and 1 pad while sealing. The pads get caked up with spent polish about midway through the Tundra. You can never have to many microfibers! I use 2 to 3 per polishing and sealing step. Then you need some for the interior, wheels, tires, etc. A good drying microfiber is also nice to have.
A little tip. Sonax Full Effect is good but you can pickup Eagle One a2z all wheel and tire cleaner at Walmart for around 4 bucks a bottle. I feel it works better than the Sonax at a fraction of the cost.
Other than that looks like you have a great order comming your way.
2010 Crew Max TRD
OME 612 front
e-bay Pocket Flares
24" LED Light Bar
K&N drop in
post #1821 of 1983 (permalink) Old 01-12-2016, 05:55 PM
Migs53's Avatar
Quoted: 46 Post(s)
Awesome, thanks! I just realized..... i font have leather stuff for both mine and my wife's interior. Suggestions?
Migs53 is offline
post #1822 of 1983 (permalink) Old 01-12-2016, 06:05 PM
Quoted: 535 Post(s)
The deep plastic cleaner will clean it nicely. For protectant try 303 aerospace protectant. I have not used it on leather but I would imagine it would do a fine job. @Jumbojet any recomendations? You might want to pick up 303 anyway for other interior plastics. It's great stuff and leaves a subtle shine that I really like.
2010 Crew Max TRD
OME 612 front
e-bay Pocket Flares
24" LED Light Bar
K&N drop in
post #1823 of 1983 (permalink) Old 01-12-2016, 06:23 PM
Jaj23's Avatar
Looks like SF3500 is replacing SF4000, but there is also an SF3800...I'm just going to go with the SF3500. Can you tell me about how many times I can do my truck with an 8oz bottle of Heavy Cut 400 and an 8oz bottle of SF3500?
Jaj23 is offline
post #1824 of 1983 (permalink) Old 01-12-2016, 07:23 PM
Quoted: 535 Post(s)
8 Oz will last for a while. You will use more because you are a newbie.
2010 Crew Max TRD
OME 612 front
e-bay Pocket Flares
24" LED Light Bar
K&N drop in
post #1825 of 1983 (permalink) Old 01-12-2016, 08:59 PM
JOEGUAM's Avatar
Quoted: 70 Post(s)
It depends how many defects you have and % correction you want to do. You will need a bit more than 8 oz but probably no more than 32 oz. Hell at least you would more for a future use. I have a black tundra and I finished the truck off with SF3800 until I got a zero defect. It took me about 3 days but worth it in the end.
Lifted Tundra Club (LTC) Member #69
Pro Comp 6 Inch Stage II Lift Kit Front MX2.75 Coilovers and Pro Runner Shocks, Fuel Nutz two piece 20x12 with -44 mm offset, Toyo Tire 315x60X20, +3 Coachbuilder1 Shackles, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200
JOEGUAM is offline
The Following 2 Users Say Thank You to JOEGUAM For This Useful Post:
Dixon Cider (01-12-2016), Jaj23 (01-12-2016)
post #1826 of 1983 (permalink) Old 01-12-2016, 09:25 PM
JOEGUAM's Avatar
Quoted: 70 Post(s)
I ordered:
(1x) Wheel Woolie
(2x) 5 gal bucket
To do the whole truck you will need at least 2 pads each ((2) for compounding/correcting defects and 2 for finishing) for big panels to be efficiency and save you time. IMO the 4" pads work best overall for our trucks with 5" at most. Our panels have many curvatures.
Lake country pads are my preferred pads (orange or green for compounding and black/grey for overall Polishing. Your best bet for sealant is a blue Menzerna Power Lock Sealant could probably go with blue or red for finishing.
You can also get more backing plates for the tighter spaces IE 3.5" Dual Action Flexible Backing for the 4" pads and 3 Inch Dual Action Flexible Backing Plate and use 3" pads for even more tighter spaces.
You need a good LED light to see the true condition of your paint
Iron X
You will be surprised that choosing a good microfiber towel will take you a long way without scratching and marring your polish job. I like Supreme 530 Microfiber Towel for removing the polish or Gold Plush Jr. Microfiber Towel for removing the product when you compound/correcting defects.
Best place to learn about detailing is a detailing forum
JOEGUAM is offline
The Following User Says Thank You to JOEGUAM For This Useful Post:
post #1827 of 1983 (permalink) Old 01-12-2016, 10:19 PM
Jaj23's Avatar
Iron X
Do you use this particular Lake Country Pad?
Lake Country Hybrid Power Finish 5 Inch Pads 6 Pack
Jaj23 is offline
post #1828 of 1983 (permalink) Old 01-12-2016, 10:27 PM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
Wow! Great first order....very impressive. The others have given you great tips and advice. However, they've left out the most important tip....the savings! Based on your list, I assume this is an order from Detailers Domain? If so, use coupon code NEWBIE for 15% off.
An amazing leather cleaner is Einszettes Deep Plastic Cleaner. Follow that with Einszettes Leather Care to seal and protect and leave a supple finish.
Again, great list.....enjoy and please post pics!
Mark
Jumbo Jet is offline
post #1829 of 1983 (permalink) Old 01-12-2016, 10:36 PM
JOEGUAM's Avatar
Quoted: 70 Post(s)
I use the CCS lake country, Thin Pro, and 3" flat.
JOEGUAM is offline
post #1830 of 1983 (permalink) Old 01-12-2016, 10:50 PM
Migs53's Avatar
Quoted: 46 Post(s)
Mark
Nice.... yeah, I got 20% off from first order with "welcome20" code. Thanks for leather advice and other tips. Maybe I will order 1 more set of pads.
Cheers,
Migs
Migs53 is offline
The Following 2 Users Say Thank You to Migs53 For This Useful Post:
firerescue4 (01-13-2016), Jumbo Jet (01-12-2016)
