Ask the Guru - Detailing Questions - Page 11 - TundraTalk.net - Toyota Tundra Discussion Forum
post #151 of 1983 (permalink) Old 02-01-2013, 06:37 AM
Originally Posted by Jumbo Jet View Post
Uber green for SF 4000 and Uber black for PowerLock
You sir are the man
2013 super white TRD crewmax 6" procomp lift
MaxSalsa08 is offline
The Following User Says Thank You to MaxSalsa08 For This Useful Post:
Mr. Creosote (02-01-2013)
post #152 of 1983 (permalink) Old 02-01-2013, 08:22 PM
ffsteve79's Avatar
Originally Posted by ffsteve79 View Post
Any trick for getting the lines out where my fender flares were or is it a lost cause?
ffsteve79 is offline
The Following User Says Thank You to ffsteve79 For This Useful Post:
post #153 of 1983 (permalink) Old 02-01-2013, 08:52 PM
ffsteve79's Avatar
post #154 of 1983 (permalink) Old 02-02-2013, 11:51 AM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
Do you have a PC or Griots polisher? And can you feel the paint worn down with your fingernail? Or is that just a line of build-up or dirt from the flares?
I'd start with a wash and clay of the panels, then a light polish to remove the lines, if they are just build-up.
Jumbo Jet is offline
Mr. Creosote (02-02-2013)
post #155 of 1983 (permalink) Old 02-02-2013, 05:51 PM
ffsteve79's Avatar
No I don't but I will try what you said first. I thinks it is a lot of tiny little scratches. But idk. Thanks!
post #156 of 1983 (permalink) Old 02-06-2013, 01:02 AM
dmonge90's Avatar
Quoted: 4 Post(s)
Would 303 Aerospace Cleaner be safe on my black high-gloss dash kit, the a/c panel as well as the grey plastic? Nothing I've tried has ever cleaned the grey plastic all that well. I've heard great things about 303 and have used the basic armorall products that seem to attract tons of dust. Ready to try something new..
2008 Slate Double Cab 5.7
20" XD Hoss with Nitto Terra Grapplers / Bilstein 5100s / FX-R Retrofit w/ Halos and V-LED Tritons / V-LEDs Everywhere / Longo Tail Lights / Upgraded Audio / and more...
dmonge90 is offline
The Following User Says Thank You to dmonge90 For This Useful Post:
Mr. Creosote (02-06-2013)
post #157 of 1983 (permalink) Old 02-06-2013, 09:12 AM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
303 is a great cleaner. Have you tried a glass cleaner on the high gloss dash kit yet? I clean mine with 1Z Einszettes Windscreen Clear.
The Following 2 Users Say Thank You to Jumbo Jet For This Useful Post:
kstateskier (02-06-2013), Mr. Creosote (02-06-2013)
post #158 of 1983 (permalink) Old 02-06-2013, 09:25 AM
kstateskier's Avatar
Quoted: 296 Post(s)
I also use window cleaner for my dash and consoles. Then finish with Adams VRT.
2017 Tundra Crewmax Limited Weatherby Lake, MO
TRDPro Reservoir shocks Rear
TRD Stainless Dual Exhaust
kstateskier is offline
The Following User Says Thank You to kstateskier For This Useful Post:
post #159 of 1983 (permalink) Old 02-07-2013, 09:59 AM
coolhandsr's Avatar
Quoted: 11 Post(s)
Re: Ask the Guru - Detailing Questions
Hey Jumbo first off thank you very much for sharing your expertise.
Is it ok to use a TOUCH FREE auto wash? Im usually pretty busy and when I get ramdom bird droppings or other things on my paint I want them off now. I dont always have time to give it the good wash at home. Are the chemicals at car washes too harsh? I NEVER use their brushes.
sent from my galaxy s3
coolhandsr is offline
The Following User Says Thank You to coolhandsr For This Useful Post:
Mr. Creosote (02-07-2013)
post #160 of 1983 (permalink) Old 02-07-2013, 08:53 PM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
I personally don't use them, but I will sometimes use the ones with the pressure washers to get the undercarriage clean after driving on the beach. Some, not all, but some use harsher chemicals that strip your wax off. It's a gamble without knowing what kind of soaps they use, but the ones by my house buy 55 gal. drums of a harsh, non-ph balanced cleaner from a local distributor that I use for misc. stuff. So I only use the pressure washers.
I guess it boils down to, I'd rather use the touch less wash than let bird crap etch my paint.
BigBlueAZ (02-17-2013), Mr. Creosote (02-07-2013)
post #161 of 1983 (permalink) Old 02-07-2013, 09:19 PM
Swampthing's Avatar
Quoted: 3 Post(s)
Wipe bird poop off with water and wash when you get time. Those machines will jack your paint up making it worse.
Swampthing is offline
The Following 2 Users Say Thank You to Swampthing For This Useful Post:
BigBlueAZ (02-17-2013), Mr. Creosote (02-08-2013)
post #162 of 1983 (permalink) Old 02-08-2013, 01:50 PM
coolhandsr's Avatar
Quoted: 11 Post(s)
Maybe my best bet then would be to just use the water spray alone to clear off debris.
The Following 2 Users Say Thank You to coolhandsr For This Useful Post:
post #163 of 1983 (permalink) Old 02-08-2013, 02:02 PM
Swampthing's Avatar
Quoted: 3 Post(s)
RO or distilled water gets poop off fast and easy due to its low ph. Keep a bottle on deck at all times. No need to wipe much as the low ph water loosens it right up.
post #164 of 1983 (permalink) Old 02-14-2013, 11:11 PM
koma74's Avatar
Any recommendations on gray fender flares, and weathered rubber molding that should be black??
koma74 is offline
The Following 2 Users Say Thank You to koma74 For This Useful Post:
BigBlueAZ (02-17-2013), Mr. Creosote (02-15-2013)
post #165 of 1983 (permalink) Old 02-14-2013, 11:38 PM
Jumbo Jet's Avatar
Quoted: 254 Post(s)
Adams Super VRT and/or Adams In and Out spray. I love Super VRT for my bed rails and the plastic cowl around the wipers. Beads water for months.
For the weathered rubber molding around the windows, try Klasse AIO. I've restored many a rubber trim with Klasse AIO. Wipe it on, and wipe it off.... super easy.
