Tundra FULL LED Conversion Thread - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 45 (permalink) Old 12-08-2016, 04:51 PM Thread Starter
Supporting Vendor
Xenon-Vision's Avatar
Quoted: 14 Post(s)
Here is the Direct links to everything str8jacketelite ordered from us. I will put the direct links if your car is a different year to make it easier for you.
LED Headlights
Xenon-Vision Dual LED Headlight Conversion Kit (00-06) HERE
Xenon-Vision Single LED Headlight Conversion Kit (07-13) H11 HERE Low Beam
Xenon-Vision Single LED Headlight Conversion Kit (07-13) 9005 HERE High Beam
Xenon-Vision Dual LED Headlight Conversion Kit (14-17) H4 http://www.xenonvisionhid.com/h4-led-headlight/
Foglights **Recommended to use the same headlight Kit for the same color**
Xenon-Vision LED Foglight Kits (same as the headlight kits but with the correct size)
Tundra (00-06) 9006 HERE
Tundra (07-13) 9145/h10 HERE
Tundra (14-17) H11 HERE
Reverse/Backup Light
Tundra (00-13) 921 HERE
Tundra (14-17) 7440 HERE
Interior LED Kits
Tundra (00-06) HERE
Tundra (07-13) HERE
Tundra (14-17) HERE
Cargo lighting
Tundra (00-17) HERE
Tundra below is courtesy of Str8JacketElite
Xenon-Vision
Toll Free (800)239-0748
Enter coupon code "tundratalk" for 20% OFF your purchase!
Last edited by Xenon-Vision; 02-17-2017 at 02:29 PM. Reason: IN STOCK READY TO SHIP
Xenon-Vision is offline
The Following 2 Users Say Thank You to Xenon-Vision For This Useful Post:
huktunfonikz (12-11-2016), Jtaylor163 (02-05-2017)
post #2 of 45 (permalink) Old 12-08-2016, 06:03 PM
CP312's Avatar
Quoted: 39 Post(s)
Any idea how the H4s compare to the Morimoto fogs color wise?
2014 Tundra TRD Crewmax MGM
OME 614s CB +3 Shackles LR UCAs
MB TKO Wheels 295/60R20 Nitto Trail Grapplers
TRD Pro Grille with Color Matched Surround
Linex
CP312 is online now
post #3 of 45 (permalink) Old 12-08-2016, 07:23 PM
jtk324's Avatar
Quoted: 8 Post(s)
Are these all plug and play? I like the idea of doing but do not want to retrofit much.
jtk324 is offline
post #4 of 45 (permalink) Old 12-08-2016, 07:55 PM
huktunfonikz's Avatar
Quoted: 3 Post(s)
I'm interested in LED upgrades for my 2016 Tundra, but not really interested in doing any wiring. Are these lights plug and play with existing wiring? Also, can they be controlled with the factory controls? Do the headlights work with the factory leveling dial?
Thanks in advance for consolidating the parts by model year - very helpful!
huktunfonikz is offline
post #5 of 45 (permalink) Old 12-09-2016, 07:42 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
I can't really say because every LED chip is different. If morimoto uses the same philip LED chip it might. If I ever get a chance to do so will follow up with you.
All plug and play. No additional work needed.
These are all plug and play with existing wiring. They can be controlled with the factory controls and factory leveling dial and no problem at all for the consolidating parts. It was necessary for me to do so to make it easier for the community.
Xenon-Vision
post #6 of 45 (permalink) Old 12-11-2016, 04:04 AM
Quoted: 3 Post(s)
Thanks for the quick reply! I placed my order for the interior light kit and the cargo lights. I did have a couple questions related to the interior light kit, which I posted back on the thread started by Str8JacketElite, here.
1st Truck - 2016 White Toyota Tundra SR5 Crewmax w/ TRD Off-Road and Safety & Convenience Packages
post #7 of 45 (permalink) Old 12-11-2016, 11:59 AM
PMG
PMG's Avatar
Quoted: 66 Post(s)
Does the discount still apply?
PMG
PMG is offline
post #8 of 45 (permalink) Old 12-11-2016, 12:05 PM
Quoted: 5 Post(s)
PMG
Pretty sure it still works. I ordered my LEDs on Friday and I got the discount. I received them on Saturday.
bagito812 is offline
post #9 of 45 (permalink) Old 12-11-2016, 07:58 PM
Quoted: 3 Post(s)
PMG
Pretty sure it works as well. I placed my order on Saturday and it was still working then.
post #10 of 45 (permalink) Old 12-12-2016, 03:10 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
PMG
Yes. The discount applies to all of our products at Xenon-Vision HID & LED Lighting
Xenon-Vision
The Following User Says Thank You to Xenon-Vision For This Useful Post:
Tdjohnson75 (01-25-2017)
post #11 of 45 (permalink) Old 12-12-2016, 07:31 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
H4 is sold out. 2014-2017. Will update when inventory is restocked.
Xenon-Vision
post #12 of 45 (permalink) Old 12-17-2016, 02:58 AM
Quoted: 3 Post(s)
Thought I would share some photos of my 2016 Tundra after converting some of the stock bulbs to LEDs from Xenon-Vision (using their interior light kit and cargo lights). I ordered the "bright white" option and IMO it looks much brighter and cleaner than the stock yellow incandescent. The interior LEDs also fit the license plate bulb holders, so I swapped those as well.
The kit I received was actually missing the 4x vanity lights for the flip visor, so I called them today and their rep was super helpful. He apologized for the oversight and told me he would ship me the vanity LEDs right away without any other hassle - I am looking forward to completing the interior conversion.
The Following 2 Users Say Thank You to huktunfonikz For This Useful Post:
socal57chevy (01-06-2017), Spook46 (12-17-2016)
post #13 of 45 (permalink) Old 12-17-2016, 02:35 PM
CP312's Avatar
Quoted: 39 Post(s)
So... I've done the cargo and reverse light and am about to start on the headlights. I swore someone said you could just pry them forward a bit for bulb install? It looks like I have to take it out completely. Any ideas?
Linex
CP312 is online now
post #14 of 45 (permalink) Old 12-17-2016, 04:06 PM
CP312's Avatar
Quoted: 39 Post(s)
Disregard. Took the grille off and did it that way. I'll try to get some pictures after dark. Here's the best cargo light comparison I could get considering it's light out.
Linex
CP312 is online now
The Following User Says Thank You to CP312 For This Useful Post:
post #15 of 45 (permalink) Old 12-17-2016, 06:51 PM
CP312's Avatar
Quoted: 39 Post(s)
Xenon Vision H4 LED headlights and Morimoto XB LED fogs
low beamhigh beam
Linex
CP312 is online now
  TundraTalk.net - Toyota Tundra Discussion Forum > Supporting Vendors > Xenon-Vision
