Largest Tire - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 16 (permalink) Old 10-18-2011, 12:32 PM Thread Starter
Largest Tire
Whats the largest tire you can put on stock alloy wheel and stock height?
2007 DC SB SR5 4X2 5.7L
Westin Signature Step bars
csands is offline
post #2 of 16 (permalink) Old 10-18-2011, 12:39 PM
Supporting Vendor
Discount Tire's Avatar
Quoted: 93 Post(s)
275/70R18
With 3/1 leveling kit: LT295/70R18
Low Prices! More Choices! FREE Shipping!
At The Store:
To Your Door:
Sales and Technical: 1.888.459.4080
Useful Links:
Discount Tire is offline
The Following 2 Users Say Thank You to Discount Tire For This Useful Post:
Jesco (10-18-2011), Sylverbullit (10-28-2012)
post #3 of 16 (permalink) Old 10-18-2011, 11:56 PM
I hope the question makes sense. I believe it was answered before by the Discount Tires guys, but I can't find it.
What is the largest tire that can be put on a stock rim, and still be safe and within Toyota's specs?
dilettantologist is offline
post #4 of 16 (permalink) Old 10-19-2011, 12:09 AM
1stYoda's Avatar
Look at the response right before yours bro.
1stYoda is offline
The Following User Says Thank You to 1stYoda For This Useful Post:
signaltwenty (10-26-2012)
post #5 of 16 (permalink) Old 10-19-2011, 02:51 AM
"The Midnight Modder"
$h@ki's Avatar
Quoted: 633 Post(s)
Originally Posted by Discount Tire View Post
275/70R18
The Tri-lander: Guam, Oahu & Okinawa
$h@ki is offline
post #6 of 16 (permalink) Old 10-19-2011, 03:38 AM
Is that without trimming the skidplate or anything else???
11 Crew is offline
post #7 of 16 (permalink) Old 10-19-2011, 01:54 PM
Supporting Vendor
Quoted: 93 Post(s)
You should'nt have to trim the skid plate with a 275/70R18.
If you level it (3/1)and run a 295/70R18 you will need to trim the skid plate.
If you want to stay within Toyota specs you'll want to stick with the exact stock size. Anytime you change the diameter of your tire there will be an effect (big or small based on the amount of change) on your speedo, shift points, ABS, fuel economy etc... Jumping up 1" in diameter (275/70R18) will have a minimal effect on these things but there will be some.
If you want to jump up only 1/2" in diameter the 285/65R18 is also a good size for a stock Tundra with stock wheels not modifications will be required.
Use this tire size calculator to see the estimated effect of tire size changes on your speedo: http://www.discounttiredirect.com/di...foTireMath.jsp
At The Store:
To Your Door:
Useful Links:
el jefe (10-25-2012), Sylverbullit (10-28-2012)
post #8 of 16 (permalink) Old 10-24-2012, 08:31 PM
What about the 17" rock warrior rims? Thanks
Tundraforlife is offline
post #9 of 16 (permalink) Old 10-25-2012, 11:52 AM
Supporting Vendor
Quoted: 93 Post(s)
With factory suspension or 3/1 and Stock Rock Warrior wheels.... 295/70R17 or 285/75R17.
With a 3/1 lift you can physically fit a larger tire but to do so properly you'd need to run a wider aftermarket wheel as well.
With an aftermarket wheel a 305/70R17 or 315/70R17 can fit, both will likely require some modifications.
At The Store:
To Your Door:
Useful Links:
The Following User Says Thank You to Discount Tire For This Useful Post:
EROCK11 (10-25-2012)
post #10 of 16 (permalink) Old 10-25-2012, 12:18 PM
BigNuge's Avatar
Quoted: 698 Post(s)
I have the same sort of question/request.
I am leveling the truck with the RC kit (front spacer only, @ 2.25" at the front).
I want the wheel wells to fill out better, but don't want to have to cut/bend much (I would prefer not cutting/bending anything at all).
My plan is to level the truck, install my EGR pocket FF's, use the stock TRD 18's & stock tires as winter/off road tires. Then pick up a set of 20" A/M (or possibly a set of 20" Platinum rims) for a nice summer/street tire/rim combo. I would prefer an A/M rim so I can get a wider tire with a smaller offset to fill out to the edge of the FF's.
Hope this helps with a tire/rim recommendation.
Please let me know what tire size & rim size/offset you would recommend to achieve what I described above.
Long-winded I know, but I want this investment to come out with a nice full looking wheel well with minimal cutting/bending of permanent truck parts.
Sorry for the apparent thread jack.....
Edit: I should add that another goal for the summer tire/rim package be a nice quiet comfortable ride for highway/on road driving.
2012 Nautical Blue Tundra CM, Limited, 5.7, 4x4, TRD Off Road.
New England Tundra Club Member #23
Tundra-with-a-Plow-Club #1
Tundra Campers Club Member #2
Save The Chrome Club Member #6
Tundra Ham Radio Club #5
BigNuge is offline
post #11 of 16 (permalink) Old 10-25-2012, 12:53 PM
BigNuge's Avatar
Quoted: 698 Post(s)
Originally Posted by Bad Dad's Tundra View Post
I think you are asking too much from a 2.25" level kit and pocket flares.
Pocket flares look good from the side, but can look horrendous from the back, unless you have the right wheel/tire combo to fill 'em (unless you like the fat chic with a tucked in butt look)
IMO, to be able to pull off pocket flares, you need a 0 offset wheel (on a 9" wide wheel) and a 12"+ wide tire. Guys are running 33" tires on 0 offset wheels with 3" level kits, and only have to push their plastics forward an inch. Not sure how that combo would work on a 2.25" level.
I ran 295/70/18 tires on +18 offset with oem flares, with a 3" level, it looked good. It would have looked stupid if I had pocket flares...imo.
Haha, love the fat chick comment And no, I DO NOT want that....
I appreciate the insight...
And the tire/rim size & specification that gets me where I want to get is what I am asking for. If I need to bite off a 3/1 kit I will do that. Trying to keep a slightly tucked look if I can....
I certainly don't mind pushing the inner fender well plastic here and there....
BigNuge is offline
post #12 of 16 (permalink) Old 10-25-2012, 01:02 PM
TundraStyle's Avatar
Where are the modifications to the skid plate needed? I've been running my shoes for a couple months and haven't noticed any need to trim my plate.
Texas Tundra Club #37
Magnetic Grey Club #51
2011 CrewMax 5.7L 4x4
TODO: CAI (TRD), Lock & Drop Tailgate, Front Facing Camera
DONE: Charcoal Delete, LED Interior, K&N Drop In, 295/70/18 Nitto Trail Grappler's, 2.5" Level Kit, De-Badged, BHLM, Info Button, Smittybilt M1's.
TundraStyle is offline
post #13 of 16 (permalink) Old 10-25-2012, 01:11 PM
BigNuge's Avatar
Quoted: 698 Post(s)
If you want all the rubber inside the pocket flares, but not be too tucked in, +10 to +18 will probably get you there. In all honesty, I'd recommend going with the 3/1, so you can get the bigger, wider set-up that you are after. This is coming from someone who wasted money by installing a 2.5" level kit, then later a 3/1 3/1's open up so many more possibilities than the little 2 inchers. 2 inchers are meant to level a stock truck, not put bigger tires on.
My understanding is that a leveling kit lets us go to a 33" tire without trouble. Is that a true statement?
If so, then I am only looking to go to a 33" tire (9"/10" wide, whatever works) that accomplishes the look/ride I want.
BTW, my kit came with the shims to go to 3", I can get a 1" block anywhere if I need to.
BigNuge is offline
The Following User Says Thank You to BigNuge For This Useful Post:
clvhunt (10-09-2013)
post #14 of 16 (permalink) Old 10-25-2012, 01:27 PM
BigNuge's Avatar
Quoted: 698 Post(s)
Yes, a 2" leveling kit will let you put on a 33" tire...hell, you can do that without a leveling kit. But, if you want to push the tire out of the wheel well (I.e. to fill a pocket flare) you will need more height so you don't rub on everything (body mount, bumper).
Lets not confuse things here. There is a big difference between putting a 33" tire on your truck, and putting a 33" tire on your truck that will compliment pocket flares.
Ahhh, now we're getting somewhere....
Ok, understood.
So, your saying the 3/1 is where I want to go so I can fill the wells out with the pocket FF's with a nice wide tire/rim combo.....???
BigNuge is offline
post #15 of 16 (permalink) Old 10-25-2012, 02:07 PM
BigNuge's Avatar
Quoted: 698 Post(s)
Sounds good!
Thanks for all of the info, I really appreciate it!!!
Now for a tire dealer to woo me with a deal I can't beat
BigNuge is offline
Bad Dad's Camrys (10-25-2012)
