Steering wheel vibration again - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 16 (permalink) Old 05-17-2010, 03:44 AM Thread Starter
2010 Silverbullet's Avatar
After having the wheels and tires put on and rebalanced a second time still noticing some steering wheel wobble again at speeds above 55 or 60mph. After 1st rebalance all seemed ok for a little while. Now frustrated and not sure what to do. Anybody have any ideas? I've researched all the posts and can't seem to find a clear answer. What next? go back to the original stock wheels?
2010 Tundra, Silver, 5.7 liter dc, 4x2, Ultra Goliaths 20x9 35mm offset, 305/50/20, Goodyear Eagle GT'S
2010 Silverbullet is offline
post #2 of 16 (permalink) Old 05-17-2010, 06:33 AM
ripcord's Avatar
I would check your wheel to see if the wheel weights are getting thrown off. Bad install? either way you might take it to a different shop to get it balanced.
I have heard of aluminum wheels being bent (out or round) you should ask them to check this as well.
Also what about an alignment?
2009 Tundra CrewMax 5.7L 4x4 SR5 TRD in Pyrite Mica
Tundra owner since May '09
ripcord is offline
post #3 of 16 (permalink) Old 05-17-2010, 05:38 PM
SalsaRedPearl's Avatar
Have you noticed it doing it on all types of roads (blacktop, concrete)? I've noticed some vibration in mine on certain stretches of road.
2009 Crewmax Limited 4x4- 5.7
Volant CAI / Stebel Big Daddy Horns / Line-X Bed Liner / Extang Solid Fold / TRD T-Handle Shifter / Tinted Front Windows / Toyota 20" Carved Alloys / Hankook Dynapro ATMs / iPod Interface Cable / Fog Light Mod / Interior LEDs
SalsaRedPearl is offline
post #4 of 16 (permalink) Old 05-17-2010, 06:13 PM
uflbret's Avatar
I had vibration right after I got my 33" put on, the tech at 4wheel parts warned me about possible vibration b/w 55-60 before I even left. Apparently, Toyota's steering shaft is not able to be adjusted/tightened like Chevy's and Fords. He said this is the culprit. Not sure I believe him though since after I rotated my tires the problem went away and never came back, even after subsequent rotations. ??
'08 Slate DC SR5, CST 3.5" spindles, Bilstein 5100 front/OME rear shocks, PP 2" shackles/1" blocks, 18x9 XD Hoss w/35x12.50-18 General Grabber AT2, N-Fab steps, Line-X, 15% tint, debadged, Pioneer AVH-P3100DVD, SI BM MkIII, Infinity, US Acoustics power.
uflbret is offline
post #5 of 16 (permalink) Old 05-17-2010, 06:24 PM
Are the wheels hubcentric? If they are there is a special way to balance them
LITUNDRA is offline
post #6 of 16 (permalink) Old 05-17-2010, 09:43 PM
Fundra's Avatar
You may have to get hubcentric rings.
2007 Tundra 5.7, 4x4, The work truck edition. I call her "The Sweet Fleet" It does have: 20 x 9 Mamba M1 wheels, 305/55R20 Nitto Trail Grappler MT tires, 2.4 Readylift leveling kit, Shaved emblems and etc.
Fundra is offline
post #7 of 16 (permalink) Old 05-20-2010, 09:55 PM
lumbergh's Avatar
I had one shop balance my wheels twice and they swore they were in balance. I then went to another shop and they said they were way off and balanced them fine.
Both shops are pretty reputable. I've always heard that there is something weird about the way Tundra rims are (lug centric or something) and people can have a hard time with balancing them.
I was so glad to get rid of the shakes. I would try another shop first.
2010 Crewmax 4x4 Platinum Limited- Silver Sky Metallic w/ Redrock interior
6" Pro Comp Stage Icon (front coilover and rear piggy back with rear Deaver replacement
20x9 Fuel Mojave +25
35x12.50r20 Nitto Trail Grapplers
Nfabs Line-xed w/xtra, Line-X w/xtra Bedliner, DVD Headrests, WeatherTech Floorliners
lumbergh is offline
post #8 of 16 (permalink) Old 05-22-2010, 01:55 PM Thread Starter
Problem resolved again, if anyone is interested, the tire shop replaced the lug nuts with a different type that more closely resembled the stock lug nuts as they apparently fit better than the ones with the install kit. Something about it fitting closer and closing the gap. Anyways, all appears fine this time so we'll see.
The Following User Says Thank You to 2010 Silverbullet For This Useful Post:
lifeis11 (05-23-2010)
post #9 of 16 (permalink) Old 06-06-2010, 05:42 PM
Just got a 2010 DC Rock warrior and it does this also. I raised the air pressure from 36 to the recomended 40, but have not driven it yet. I'm hoping it will help. It is really annoying. Suggestions?
outnback is offline
post #10 of 16 (permalink) Old 06-09-2010, 05:17 AM
lifeis11's Avatar
hey
im experiencing some wheel wobble as well. can you elaborate a bit about whats different about the lugs? are they shorter? the ones i originally bought came from 4 wheel parts and seem pretty long. about a week later, the company i bought the wheels from sent me some lugs as well. west coast lugz or something like that. in any case, the west coast ones do seem quite a bit shorter than the ones i purchased from 4 wheel.
am i on the right track? should i swap the longer ones for shorter?
thanks
2012 Platinum Crewmax 4x4 Mag Grey/ Red Rock. 20x9 XD Monster, 285/55/r20 BF Goody AT, Bakflip F1, stubby antenna, nav override switch, oem rubber mats.
FOR SALE
2010 TRD SR5 Crewmax 4x4 White/grey. 6" pro comp st 2, 20" XD Hoss, 35" Terra Grappler, volant, custom flow 50 exhaust, line-x, remote start, trd sway, factory tonneau: SOLD
lifeis11 is offline
post #11 of 16 (permalink) Old 06-09-2010, 02:20 PM
CMAXon22's's Avatar
I have this problem as well, a few weeks ago the toyota dealer told me that aftermarket wheels tend to have balancing problems, I dont know what to believe. I may just have them rebalanced and hope for the best
2011 TRD CREWMAX
-stainless side steps
-18" TRD wheels
-Bakflip tonneau
-much more to come
CMAXon22's is offline
post #12 of 16 (permalink) Old 06-09-2010, 02:35 PM
TINMANS07TUNDRA's Avatar
... was thinking about getting aftermarket . Now I am scurred
TINMANS07TUNDRA is offline
post #13 of 16 (permalink) Old 06-09-2010, 02:51 PM
nastyn8's Avatar
Quoted: 55 Post(s)
ROADFORCE balance, if a shop doesnt offer it walk away
nastyn8 is offline
The Following User Says Thank You to nastyn8 For This Useful Post:
lifeis11 (06-09-2010)
post #14 of 16 (permalink) Old 06-09-2010, 10:23 PM
lifeis11's Avatar
where do i find it?
FOR SALE
lifeis11 is offline
post #15 of 16 (permalink) Old 06-12-2010, 12:36 AM
I have a problem with the wobble too, but it only occurs between 50-60mph. Not a huge deal, but that is the speed that I do a lot of my driving. I have a free balance and rotation from the dealer so I will see what happens with that. 2010 Silverbullet - do you know what kind of lug nuts they put on the truck?
2008 Timberland CrewMax SR5
DeeZee Stainless Steel Step Bars
20" Ultra Goliaths and 275/55/20 Nitto NT420.
Sold and replaced with 2012 KIA Optima SX Touring
jproell2 is offline
