TPMS LIGHT FIX (simple and easy) - Page 5 - TundraTalk.net - Toyota Tundra Discussion Forum
post #61 of 141 (permalink) Old 11-17-2010, 03:41 PM
tonyspin's Avatar
Quoted: 6 Post(s)
Originally Posted by flatsguide View Post
How does one reset the tpms module? I purchased some stock BBS wheels, with the toyota sensors in them already, to replace some 2008 stock alloy wheels in my 2008 tundra. The tire pressure ratings are less in the new wheel/tire combos and so i guess the sensors turn on the light.. how does one get the dash light sensor module to reset to the new lower pressure? Thanks!
Switch the old sensors to the new wheels.
tonyspin is offline
post #62 of 141 (permalink) Old 11-21-2010, 09:20 AM
is there a diagnostic/code scanner available for tpms
Just wondering if there is an aftermarket tool i can access the tpms with and get the tire sensors and tpms to communicate.. unfortunately I purchased a set of tires/wheels with toyota sensors in them and gave him my old stock wheels w sensors... shoulda switched them i now know....
flatsguide is offline
post #63 of 141 (permalink) Old 11-21-2010, 09:42 AM
Pm sent!!!!!
2008 White Crewmax Limited TRD
20" Fuel Octane wheels black w/ Hankook tires
Roll-n-lock bed cover
Wade Sure fit mats
Borla Exhaust
jdubcee is offline
post #64 of 141 (permalink) Old 11-21-2010, 09:51 AM
tonyspin's Avatar
Quoted: 6 Post(s)
You can contact wileetundra over at TS. He will rent you an interface cable you can use with your laptop. It might be cheaper to go to the dealer if all you want to do in program the TPMS, but if you want to change other options, this might be cost effective.
Program Your Tundra w/USB & Home PC - Toyota Tundra Forums : Tundra Solutions Forum
tonyspin is offline
The Following User Says Thank You to tonyspin For This Useful Post:
kdavidson (02-20-2016)
post #65 of 141 (permalink) Old 02-08-2011, 07:47 AM
re.ac.tor's Avatar
Quoted: 3 Post(s)
Exclamation
Another option is to purchase a TPMS strap kit. Straps the TPMS sensor to the wheel if the angle of your TPMS sensor does not match/will not work with your new wheel.
TPMS Strap Kit - Tire Pressure Sensor Accessory | Revolution Supply Co. -
re.ac.tor
'10 CM SR5 4x2, 5.7L, Sandy Beach Metallic,
re.ac.tor is offline
post #66 of 141 (permalink) Old 03-14-2011, 02:07 AM
rlemn8r's Avatar
I got told by my dealer that the TPMS would not work with my 35s because they require a higher tire pressure than stock. They said the sensor would go off because the pressure was to high as well as to low. Is this true??
rlemn8r is offline
post #67 of 141 (permalink) Old 03-14-2011, 08:14 AM
tonyspin's Avatar
Quoted: 6 Post(s)
No, you reset the pressure with the button
tonyspin is offline
post #68 of 141 (permalink) Old 03-14-2011, 11:09 AM
nastyn8's Avatar
Quoted: 54 Post(s)
Tony is right the threshold of range can be reset, if not Toyota would be replacing computers in the Rock Warriors like they will be in the trail teams Fj cruisers for the new campaign. Toyota will be setting the Rock Warrior pressure to 46 pounds
nastyn8 is offline
post #69 of 141 (permalink) Old 03-15-2011, 02:20 AM
rlemn8r's Avatar
What button are you talking about??
rlemn8r is offline
post #70 of 141 (permalink) Old 03-15-2011, 02:58 AM
gpend5.7sport's Avatar
Quoted: 7 Post(s)
good info on how to take cluster out i think ill just have the annoying light lol
Gabe
Cute Raptor Bro
gpend5.7sport is offline
post #71 of 141 (permalink) Old 03-15-2011, 08:48 AM
tonyspin's Avatar
Quoted: 6 Post(s)
Under the dash on the drivers side. Check your owners manual for exact location
tonyspin is offline
post #72 of 141 (permalink) Old 03-17-2011, 10:22 AM
volleyball's Avatar
Quoted: 485 Post(s)
When you plan on pulling the dash, pm me and maybe I can help you with a solution. My tpms works so i cannot try on mine
volleyball is offline
post #73 of 141 (permalink) Old 04-16-2011, 11:51 PM
You know the real reason behing TMPS.Its cuz ford put crappy tires on their cars,and people had wrecks,and blow outs.This is the fix ,more big brother looking out for you.
white rocket is offline
post #74 of 141 (permalink) Old 04-17-2011, 06:08 AM
volleyball's Avatar
Quoted: 485 Post(s)
So you are now the official government spokesperson?
Statements like these give the internet a bad name. Think before you post
post #75 of 141 (permalink) Old 05-18-2011, 03:38 PM
I'm looking to get a set of sensors for my truck as well to clear the sensor light. I don't plan to install them in my wheels, I plan on doing the pressurized pipe mod because I installed an aftermarket tpms monitor to view my pressures at all times. What model number sensor would work? 42607-0c030...42607-0c050...42607-0c060...all of them? Thanks in advance
TRD Supercharger
TRD Big Brake Kit
TRD Sway Bar
24" Slides w/ Nitto 420S
Roll-N-Lock bed cover
Mcgaughy's Lowering kit
Custom Stainless exhaust (x-pipe)(bam mufflers)
Tundra Racing air bags
Viar onboard compressor with dual guage set-up
Myron & Davis Headrest Entertainment
Orange TPMS monitor system
Viper remote start
Paint to match Tow Mirrors
lmbbuilders is offline
The Following User Says Thank You to lmbbuilders For This Useful Post:
