Does anyone think 305/55/20's will fit without a leveling kit?
Just wondering. The wheels are a 20x8.5 and do have a +35 offset so i was just thinkin (hopping) that they would work. I hate turning wrenches.
nope. sorry.
www.IBTOHQ.com |
think they are too wide. There are guys that run this size with a leveling kit and get rubbing
www.IBTOHQ.com |
#6 (permalink) | |
oh so the 33" may not be an issue .. but the width may be? the other solution for this guy is a wheel with a lower offset .. if he goes with something that is has a lower offset, the wheel will stick out more and he could possibly fit it
White Tundra Club Member #2 |
#7 (permalink) |
Yeah maybe, not really sure.
www.IBTOHQ.com |
#9 (permalink) |
315/35/24 +35mm
im running 315/35/24, 32.7" dia. with a +35mm off set with no problems stock no leveling kit.
'08 tundra 4.7 4x4 ,head light mod air box mod 24" boss wheels with 315/35/24 general tires '02 660 grizzly,jetted,piped '84 cr500r Bored .80,port&pol,pipe,reeds,70+hp'03 drz125 jetted,piped phrogs forever Semper fi Last edited by dexx69 : 08-27-2008 at 04:47 PM. |
#10 (permalink) | |
I've asked this question multiple times just to be sure and everyone says a 305/55/20 is good to go with a 3/1" leveling kit and a slight trim of the skidplate. Where did you hear that these rub?
08' White on Red Rock Crewmax Limited 4X4 -Tint -NFAB steps -TRD shift knob -Borla Exhaust -Truxx 3/1" -Alcoa 20X9 Adventurers -305/55/20 BFG AT KO's -WeatherTech floor liners -WeatherTech Lic. Pl Frames |
#11 (permalink) |
I'm running 285/55/20 .
My wheels came on the truck as part of the X-Sp package , they did not rubb until after I got my Toytec lift installed . I had to trim my skid plate about an 1" 1/2 on both sides . Now no rubbing at full turn .
#12 (permalink) | |
Of course not at the expense of rubbing and if the 305's rub then I won't get them.
#14 (permalink) | |
I think you'll be fine getting the 305's , worst case you use tin snips and trim the skid plate yourself , it's pretty thin and it's an easy fix . Yeah I agree about the look of mine , but I'm going to put on a 6" lift this winter and for now they will have to do . Here is something that might help you out Tire size calculator
#15 (permalink) | |
You going 35" on the 6"? Pro-comp lift? I'll add that I don't like the look of mine at all right now, doesn't even look like a 4X4. And at my property it bottoms out where my F150 supercrew had no problems. I bottomed out one of my N-fabs today..
