#16 (permalink) | |
calebj06 asked "if it would fit w/o a leveling kit"! Do you see the difference?
www.IBTOHQ.com |
#17 (permalink) | |
thanks for clearing that up..... Hey when your about to spend well over a grand for tires you just gotta be sure... Your truck looks good with he 6" BTW
08' White on Red Rock Crewmax Limited 4X4 -Tint -NFAB steps -TRD shift knob -Borla Exhaust -Truxx 3/1" -Alcoa 20X9 Adventurers -305/55/20 BFG AT KO's -WeatherTech floor liners -WeatherTech Lic. Pl Frames |
#18 (permalink) |
I'm running 305/45/22 never had a problem and can still hop curbs.All stock!!!
http://i413.photobucket.com/albums/p...undra/1239.jpg 08 CrewMax SR5 4x4 |
#19 (permalink) |
For what it's worth. I have the stock 20's on my Limited. They have Dunlop 275/55's on them The web pages say the tire is 31.9 inches in diameter and 10.2 inches wide. I'm considering 305/55's as well. Tire rack says they are 33.2 inches in diameter and 12 inches wide. There is an arm, I believe it's called an "A" frame, part of the suspension, at he top of the tire and behind. There does not seem to be much clearance behind the tire and the arm. Wheel "offset" is the key. As I look at some of the pictures of your trucks I see after market wheels, probably allowing for bigger tires because of different than stock "offset". I put after market tires and wheels on a car a few years back and they placed a spacer between the wheel and hub. I'd wager that is the key. Now where does one get the spacer and the longer lug nuts to compensate for the spacer? That is the big question!?
#20 (permalink) |
Duh! Mashed a few buttons and look what I found!!
Wheel Adapters 5 Lug Suburban |
#21 (permalink) | |
I'm still trying to decide between the Fabtech performance lift , ot the Pro Comp stage 2 . ![]()
#22 (permalink) | |
www.IBTOHQ.com |
#23 (permalink) |
OK, no one responded to my spacer question or suggestion so I've ordered four 1 inch spacers. I think they may be a little too thick but that was the thinnest they make. I'd wager they will allow one to put on 305/55/20's on the optional 20 inch alloy wheel. The 305's are 1.8 inches wider and 1.3 inches greater in diameter than the stock 275/55's on my truck now. I'll let you all know.
#24 (permalink) | |
So you are trying this with no lift at all?
#26 (permalink) |
Bullseye08,
I've changed my plans a little. I'm going to put on Mickey Thompson Classic II's instead of leaving the stock alloy 20's, Off set is +13 compared to +30, I believe, for the stock wheels. I hope this moves the tire, 305/55/20, away from all the suspension sufficiently to prevent rubbing. All parts enroute. Hope to do it Friday or Monday. |
#27 (permalink) | |
