From what I understand, only certain wheels work with a lift. There are already few rims that fit our trucks, so this narrows the search down even more. Anyone who knows the necessary specs, will these rims fit my truck when I finally make the move to lift it? If not, why? What do I need to look for? Thanks in Advance.
Part #: 228-2950B Size: 20x9 Backside Setting: 6 3/8 Offset: +35 Bolt Circle: 5-150 Cap: 89-9850 Bore: 110.3mm Load Rate: 2200 There is also a "Low Offset" option with the following numbers Part #: 227-2950B Size: 20x9 Backside Setting: 5.24" Offset: +6 Bolt Circle: 5-150 Cap: 89-9850 Bore: 110.3mm Load Rate: 2200 ![]()
The +35 would stick out too far? Do you see any reason as to why these rims, with the +35 offset WOULDN"T work with a 6" lift?
you got it backwards, the lower the offset, the farther out the wheels will sit.
So the +6 would stick way out, while the +35 will be in. so the +35 will look better. I am no wheel expert, but i dont see any reason why either of them wont fit. Go with the +35 though if those are your only 2 choices.
White Tundra Club Member #2 |
Got it! Thanks. I'm new to these "truck" things.
