Old 05-11-2008, 04:15 AM   #31 (permalink)
Tire pressure sensors come in 2 flavors 20 & 40 Degree Angles for stock tundra rims.
See attached
TundraScout is offline   Reply With Quote
Old 05-11-2008, 06:34 PM   #32 (permalink)
khyber's Avatar
Originally Posted by blackcmax View Post
I called discount tire and they said they were not aware of anything I could do except buy the other style sensors from the dealer, but at $127 each that would be more than what the wheels, center caps, and swap cost me. I called several other tire shops in my area and everybody said the same thing. What discount tire dealer did you go to so maybe I could call them and see what exactly they call this mod so I can tell the one that is in my area.
Discount Tire
New Braunfels, TX 78130
(830) 629-1020
khyber is offline   Reply With Quote
Old 05-11-2008, 10:24 PM   #33 (permalink)
Originally Posted by khyber View Post
Discount Tire
(830) 629-1020
Thanks for the info. I will give them a call.
blackcmax is offline   Reply With Quote
Old 05-12-2008, 08:14 PM   #34 (permalink)
Bruteforce's Avatar
I will stop in at Discount tire tomorrow and see if they have the sensor kits. I got some new factory wheels and tires off eBay today and would like to be able to have the sensors installed. I don't like the styled steel wheels that came on my crewmax.
Bruteforce is offline   Reply With Quote
Old 05-20-2008, 08:49 PM   #35 (permalink)
Bruteforce's Avatar
Went to Discount tire today to get my alloy rims and tires put on. Hated the steel wheels. They said they would put on the sensor "rebuild kits" for alloys and everything would be fine. I had also called the number of the Discount tire in Texes and he said they do the same thing...I think I talked to a shaun? I was pumped....until they broke my sensor! About five guys looked at the wheels and sensors and they said the angle of the steel wheel sensors will not work in the alloys. They also said without the proper sensors anyone would be taking a costly risk. Discount tire is buying me a new sensor for me from my Toyota dealer because of no aftermarkets. They also put everything on for free!!! It looks like I will have to deal with the little pain in the @ss light!
*2008 Tundra CrewMax 4x4 - Slate*
Old 05-20-2008, 09:50 PM   #36 (permalink)
khyber's Avatar
sensors
Did you go from styled steel to OEM alloys (the ones that are similar to the styled steel, little indentations in each spoke) ? That was my switch and it worked fine.
rs
Old 05-20-2008, 10:08 PM   #37 (permalink)
Bruteforce's Avatar
I went from the styled steel wheels to the alloys. I almost wish I had the plain steel wheels...they have the 20 degree valve sensors. I will use the other set of rims and tires with the sensors maybe in the winter time. I'm not going to spend the money for new sensors...I got a bear hunting trip to pay for!!!
Old 05-21-2008, 12:43 AM   #38 (permalink)
khyber's Avatar
and folks call me crazy for fishing for sharks in 14' plastic boats.
Old 09-20-2008, 02:00 PM   #39 (permalink)
Discount Tire 20 & 40 degree TPMS...BROKE ONE!
I read this thread BEFORE I went to Discount Tire.
I showed up to have them take off my STEEL WHEELS
Then take the TPMS OUT OF THE STEEL WHEELS
Then have them put the TPMS ON MY ALLOY WHEELS
Then have them mount the alloy wheels
Discount Tire DISCOVERED that the TPMS from the steel wheels do not fit correctly on the alloy wheels. I told him that Discount Tire sells an adapter for $5.00 that allows the 20 degree fitment to be changed to 40 degrees for the alloy wheels (showed them a copy of post #26 of this thread). They're response...what adapter?
Discount Tires solution: they turned the TPMS upside down and mounted them. No problems, no issues, works like a charm.
However, in the future WHOEVER TAKES OFF ANY TIRE must be forwarned that the TPMS is turned outward. Can they remove a tire without harming the TPMS? Yes. But if they don't know about it each one will be snapped off.
In addition they were putting the last TPMS on and they BROKE it!
They ordered a new TPMS from the dealer, I will have to get the number off the new sensor, that matches the other sensors, so that I can go to the dealer and get them all programmed. Who is paying for all of this? Discount Tire.
Needless to say they DO NOT like any of the TPMS systems on the market.
Bottom line:
Steel wheels off and TPMS moved over to alloys
Alloys added with new BFG tires (new tires and rims bought on Craigslist for $600.00)
Happy customer! Discount Tire, not so happy
6seater is offline   Reply With Quote
Old 09-20-2008, 03:59 PM   #40 (permalink)
I have a set of the TPMS from the styled steel wheels I can sell if anyone needs them.
twinin is offline   Reply With Quote
Old 09-20-2008, 04:33 PM   #41 (permalink)
Deznutjob's Avatar
Hey twinin, you should also start a thread in the Classified area under buy/sell!
37" Toyo Open Country's
20" (Black) KMC XD Monster's
N-Fab nerfsteps WWW.N-Fab.com
N-Fab light bar
Old 09-20-2008, 09:17 PM   #42 (permalink)
Thanks, I'm might just do that. I just figured mine are collecting dust and someone might see their wheels wish come to life if they could find some cheap sensors.
Old 09-23-2008, 05:55 PM   #43 (permalink)
ebag's Avatar
I just bought a set of wheels from Discount Tire and initially they wanted to sell me a "TPMS sensor rebuild kit," Anyway, they asked me how many miles were on the truck and I told them 6000, they said that I didnt need a kit and that my sensors from my stock wheels would be a direct swap to the new wheels.
E.
ebag is offline   Reply With Quote
Old 09-23-2008, 06:07 PM   #44 (permalink)
Each sensor has its own id, if one breaks the new one must be programmed ot the turck by the dealer
nastyn8 is offline   Reply With Quote
Old 09-23-2008, 07:31 PM   #45 (permalink)
Yep, each sensor does indeed have its own serial number. However, the Toyota dealer only needed the serial number of the new sensor (replacing the broken one). They were able to get the serial number off the other 3 sensors via the VIN number on the truck. SO THEY SAY!
I go tomorrow to have the new sensor programmed and everything reset. We'll see how it goes.
By the way Discount Tire waived the fees on switching out the tires and have arranged to pay the 1 hour charge at the dealer for programming the sensor!
