#16 (permalink) | |
08 Slate CM TRD Ltd. Hauling a Jeep 98 TJ Rockcrawler. ![]() ARE LSII Tonneau, Bedrug, Prodigy Brake Controller, Weathertec mats & window trim, SuperSprings, blah... |
#17 (permalink) | |
#18 (permalink) |
yea and I'm sure there would not be a prob for 4*4 either. But syber ur 4*2 like me. And same for 07's.
Yea those are nice. They make the moda 210's fir regular cars aswell and Im pushing my gf to put them on her black 06 mustang. ANd for the car they are $100 less. It kinda sucks how those are 20" and I think there is a 22" in there and they look like 18" ha.
2008 Double Cab 5.7 TRD Black on Black -Katskinz leather -Tint -K&N drop in w/ carbon delete My Moms ride 2008 Sequoia Limited Black 5.7 -same tint as the Tundra |
#19 (permalink) |
I think I know the answer, but I want to make sure that 325/60/18's will fit. I am lifted 2.5". What kind of backspace do I need?
![]() Mine: 2007 Tundra Double Cab, 5.7L, slate, 2x4, Flowmaster 50 series dual in/dual out, Homemade leveling kit (2.5") Hers: 2007 Tundra Double Cab, TRD 2x4, 4.7L, desert sand Previous Vehicles: 1990 Jeep Wrangler Islander, Rancho Lift 1992 Chevrolet Silverado Z71 4x4 RCSB - 190,000 miles and still running strong when I sold it. 2001 Honda Magna VF750C 2002 Chevrolet Tahoe Z71 2006 Chevrolet Trailblazer SS (8.9 sec 1/8 mile - STOCK) |
#20 (permalink) | |
Tire sizes vary slightly by manufacturer, but assuming this is a BF Goodrich Mud Terrain or equivalent type tire, it's slightly taller than stock (32.6") and almost 2" wider (12.2") than stock. If you split the 2" width increase between the inside and outside of the hub that would mean you could run a 30mm offset and be okay (with your lift). I'd recommend a 15mm offset just to be safe. Typically, a 18x9 aftermarket features a 30mm offset, which basically pushes most of the additional width outward. If you're running a 10" rim (which I would suspect you are) then you'd probably want most of the additional 2" pushed outward. Either a 0mm offset or no more than a 15mm offset would be fine. You might get away with a 30mm offset with the additional clearance of the lift kit, but you might end up rubbing a bit and have to trim the skid plate some.
2008 Black Double Cab SR5 |
#21 (permalink) | |
#22 (permalink) |
For a huge selection of Wheels for your Tundra Check out BigWheels.Net: custom wheels,chrome wheels,alloy wheels,car wheels,truck wheels,aftermarket wheels,large rims,wheel and tire packages,polished wheels Some are nice, some are hideous but there are alot to choose from. Some of the prices are a little high so price compare after you find one that you like. Its a great resource.
#23 (permalink) |
i have the styled steel wheels on my new tundra would like the sr5 18" alloys but cant find them around does anyone know where i can get some decent priced rims i know nothing about them by the way im from the hampton roads area of virginia please help thanks
#24 (permalink) |
Tundra Aftermarket Wheel/Tire problem
I have an 08 Crew Max SR5. I got rid of the stock factory tires and wheels and went wwith BFG All Terrain Radials with Eagle Style 197 wheels. This combo proved impossible to properly balance at tire store. Even got new set, same wheel, and couldn't balance. They awithced me over to V-Tec Off Road Black. So far, seems pretty good also some hopping sensation in rear of truck. Will take it back tomorrow and see if any wheel threw off a weight. When the BFG's are on the stock wheels, they are perfect in their ride and balance. Has anyone experienced a balance proble on 08 tundra wth aftermarket wheels/tires? |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
