Rancho Quicklift with 275/65/20's Installed (pics) - TundraTalk.net - Toyota Tundra Discussion Forum
Old 01-17-2013, 04:44 PM   #1 (permalink)
Darth Chadious's Avatar
Talking Rancho Quicklift with 275/65/20's Installed (pics)
Thought I would share my experiences and some pics regarding the new Rancho Quicklifts and tires I installed over the last week.
So I ordered these Rancho's off Amazon and recieved them in two days...however to my suprise they looked different when I unpacked them. I called up Rancho and got some answers. They are basically the exact same setup except for the boot...same coil, same shock, etc...The slightly older version has a red accordian style boot while the newer version has a black hard plastic boot. I decided that I didn't want to hassle with sending them back so I tracked down a red replacement boot to match.
So the next morning I went out and rented two sets of spring compressors and started to get to work. I will admit that the coil spring on the Rancho's are pretty tough and it took all 4 of those spring compressors, an impact wrench, and some testicular fortitude to safely get the assembly apart. I replaced the boot got everything back in-line and put it all back together.
So a word of caution...if you order off Amazon...you may run into this same problem. I don't know why they changed the design of the boot...but I prefered the old style to the new. I also recieved the Rancho's for the rear as well...those will get installed this coming weekend though.
This was a win win install for me...my OEM shocks started leaking at 15k and I wanted to level the truck anyways so these were a great solution. The install went fairly well and it took about 2 hours to get them in. Got everything buttoned back up and notcied the camber was pretty off on both front wheels. No worries though as I had already ordered new tires so we went down the street to a muddy field and went for a ride Yes...I went off-road mudding in a 2WD with street tires! All was good though as we had a fun time bouncing around and slinging mud everywhere and we never got stuck. These adjustable shocks really do go from very soft to very stiff depending on the settings you choose. I was quite impressed with the quality of the ride at about 6 clicks to the stiffest setting...just about right.
I would recommend this setup to anyone looking for replacement shocks and a leveling kit.
So two days later I get the call that the tires have arrived so I scoot on over to Discount to get them installed. I decided to go with the Falken Rocky Mountains (same as Wild Peak AT's) in the 275/65/20. I chose these tires because I was looking for an AT tire that would ride good on the street but would give me some durability off-road as well. Also I read alot of good reviews about this tire, they perform great on sand for beach driving, and the price was right as well. When they got them on the truck I honestly thought they were gonna look bigger for a 34" tire, but they fit the wheel well nicely I think. I did have some minor rubbing on the skid plate but I bent it slightly with some channel locks and smoothed it out with a ball peen hammer and I was good to go.
Right after that I headed out for the alignment. I have had the truck aligned twice so far and looking to go in for a 3rd because I still think the camber is a little off. I have a lifetime alignment at Firestone...so I can go back 100 times and won't get charged a dime. The Falken's feel and ride very well. No road noise, no vibrations, and the truck feels very solid on the road. I will mention however that each tire is 25 pounds heavier than the stock Dueler's (275/55/20) I had on there and my gas mileage has gone to shit, but I knew this going into it.
Overall I am very happy with the changes to the truck. With the Rancho's and new tires I actually have to use the step rail to get in the truck now! You can see the difference between my signature pic and the ones I p[osted in this thread. Have a look at the pics and let me know what you guys think or if have any questions.
-The Chadster
2011 4.6l Tundra Double Cab 4x2
Tow Package / 20" Chromed Wheels / Chrome Grill
Chrome Handles / Chrome Mirrors / Chrome Steps
Rancho Quicklift-Front / Rancho 9000xl-Rear
Falken Rocky Mountain ATS 275-65-20
Info-MPG Button Mod / Pioneer AVH-3400BT
Parking Brake Bypass / Anytime On Flush Rear Cam
LineX Bedliner / Tinted Glass / Chromed Tool-Box
K&N 63 Series CAI / LED Swap Interior~Exterior
Darth Chadious is offline   Reply With Quote
The Following 4 Users Say Thank You to Darth Chadious For This Useful Post:
kstateskier (01-25-2013), Powertechn2 (01-29-2013), scream (03-22-2013), spar429 (01-22-2013)
Old 01-22-2013, 08:04 AM   #2 (permalink)
I did the Quicklifts on mine also. Don't know why more people don't go this route.
l1tech is offline   Reply With Quote
The Following 2 Users Say Thank You to l1tech For This Useful Post:
Darth Chadious (01-24-2013), Powertechn2 (01-29-2013)
Old 01-24-2013, 12:34 PM   #3 (permalink)
Other than having to swap the boot...everything else was easy cheesy. My friend is gonna put spacers on his Tundra cause they are cheaper. But in my case all my OEM shocks were leaking so I'm basically get the lift, new shock, new springs, and they are adjustable...so the extra cost was justified to me. Also they have a lifetime warranty as well...very happy with my results so far and happy I didn't go with the Bilsteins.
The Following User Says Thank You to Darth Chadious For This Useful Post:
Old 01-24-2013, 04:53 PM   #4 (permalink)
What stiffness setting are you running? I should have mine shipped by tomorrow.
donald1017 is online now   Reply With Quote
The Following User Says Thank You to donald1017 For This Useful Post:
Old 01-25-2013, 10:21 AM   #5 (permalink)
6 clicks up from the softest setting. I think thats just about right...stiff but not so much that I feel every bump. I like my truck to feel like a truck, so that why I have it set high. If you like a real soft car like ride the lowest setting will give you that.
Old 01-25-2013, 11:12 AM   #6 (permalink)
909SCUM's Avatar
How much lift did you get? .. .. 2-1/2"?
2011 TRD CM Rock Warrior
FOX 2.0 Coilover's -3" Lift
RW wheels with 1.5" & 1.25" hub-centric spacers
909SCUM is offline   Reply With Quote
The Following User Says Thank You to 909SCUM For This Useful Post:
Old 01-25-2013, 11:36 AM   #7 (permalink)
kstateskier's Avatar
Good writeup and feedback.
These trucks look "SO RIGHT" level on about a 34" tire. You and I are running the same setup almost - althuogh I'm on a 3/1 LRO and 275/65/20 BFGATKOs. I love the ride/handling. I also love how this tire size fits perfect inside the wheel well, doesn't stick out and handles so well.
You're right though the MPG takes a shit, but oh well its a truck!
2007 Tundra DC SR5, Kansas City, MO
LRO 3 front spacer
Coachbuilder +3" Shackles
Coachbuilder Air Ride spacer
Firestone Ride Rite Rear Air Bag kit
Bedliner
TundraPart.com Fog Light Kit • Anytime-Fog light Mod
DDM HID - 55w5K lows, 35w4300K fogs
20" Toyota Limited 5 Spoke Alloys
275/65/20 BFG ATKO
Advent OEM Nav, Hertz components
TonneauPro HardFold Cover
kstateskier is offline   Reply With Quote
The Following User Says Thank You to kstateskier For This Useful Post:
Old 01-25-2013, 12:52 PM   #8 (permalink)
Yeah it's about 2.5 inches...they state that they lvl out to 2.25" after a week or two, but it's been 2 weeks and they still sit about 2.5" on each side. It's level, but I worry if I carry a load or a trailer I might sag a little in the back. Might purchase the Firestone airbags to go in the rear also to solve that issue. My friend has them on his Tundra and tows a 9000lb+ 26" boat and has no sag at all when towing that beast.
Old 01-25-2013, 01:00 PM   #9 (permalink)
I agree...it was pics like yours that helped me with my decision. So thanks for that! The ride and handling is great and it does fill the wheel well nicely. I know alot of people like there tires to stick out some... it looks good (sometimes), but it wasn't the look I was going for. Plus I think "that" looks better on blacked out trucks while I stuck with the chrome and even added some. Also happy I was able to keep the stock wheels too! Overall I think it's a great choice for someone not looking to do anything too crazy and just want to lvl out and get a bigger tire. KState...your truck looks familiar...you don't happen to live in the Alamo Ranch area do you?
Old 01-26-2013, 07:39 AM   #10 (permalink)
Darth I see they sent you one with a red boot & one with the black dust sheild. I called and asked them to send me a red boot to put on the other one as well. What crap! Now I have to have someone take the unit apart to put it on...
Old 01-29-2013, 01:05 PM   #11 (permalink)
Truck looks good!
jetcycles is offline   Reply With Quote
The Following 2 Users Say Thank You to jetcycles For This Useful Post:
Darth Chadious (01-29-2013), Powertechn2 (01-29-2013)
Old 01-29-2013, 01:21 PM   #12 (permalink)
Yeah it sucks that they would do that. I didn't even wait for them to send them to me. I went online and found a Orielys that had them in stock and bought a replacement that night...had it installed next morning.
You can compress the spring yourself like I did, but if you feel uncomfortable doing that then take it to a shop...they should only charge like 50-60 bucks and hopefully the have the spring compressor thats mounted to a stand or table.
Old 01-29-2013, 01:24 PM   #13 (permalink)
Originally Posted by jetcycles View Post
Truck looks good!
Thanks! I have been meaning to get the DSLR out and take some better photos to post...just been too busy this last week. I also finally got the alignment right now too after 3 trys. Thank Baby Jesus for Firestones lifetime alignment...that thing paid for itself the second time I had to take it.
I'll try and post some better pics and my alignment sheet later this week.
Old 01-29-2013, 05:36 PM   #14 (permalink)
Did you take the black dust sheild off the other one or put the boot over it somehow?
Old 01-29-2013, 05:51 PM   #15 (permalink)
I compressed the spring and removed the hard plastic dust cover and installed the red Rancho boot so they would both match. It's funny they took away the red boot on the quicklifts, but when you order the matching set for the rear they come with the red boots...
