Rancho Quicklift with 275/65/20's Installed (pics) - Page 2 - TundraTalk.net - Toyota Tundra Discussion Forum
post #16 of 42 (permalink) Old 01-29-2013, 06:55 PM
If you dont mid send me the model #'s for the rear you used. You have been a great help. Thanks!
donald1017 is offline
The Following User Says Thank You to donald1017 For This Useful Post:
Powertechn2 (01-30-2013)
post #17 of 42 (permalink) Old 01-29-2013, 06:58 PM Thread Starter
Darth Chadious's Avatar
No prob...here is a link to the ones for the rear. The same model for both sides:
http://www.amazon.com/gp/product/B001D6UF1O/ref=oh_details_o02_s02_i00
2011 4.6l Tundra Double Cab 4x2
Tow Package / 20" Chromed Wheels / Chrome Grill
Chrome Handles / Chrome Mirrors / Chrome Steps
Rancho Quicklift-Front / Rancho 9000xl-Rear
Falken Rocky Mountain ATS 275-65-20
Info-MPG Button Mod / Pioneer AVH-3400BT
Parking Brake Bypass / Anytime On Flush Rear Cam
LineX Bedliner / Tinted Glass / Chromed Tool-Box
K&N 63 Series CAI / LED Swap Interior~Exterior
Darth Chadious is offline
The Following User Says Thank You to Darth Chadious For This Useful Post:
post #18 of 42 (permalink) Old 01-29-2013, 07:05 PM
thanks
post #19 of 42 (permalink) Old 01-29-2013, 07:09 PM
Brandan86's Avatar
Nice setup. Tundras look so nice leveled. You should check out Alamo City Tundras so we can see it in person.
2001 AC SR5
FIRST GEN CLUB MEMBER # 3
Brandan86 is offline
The Following User Says Thank You to Brandan86 For This Useful Post:
post #20 of 42 (permalink) Old 01-29-2013, 10:28 PM
thompsonreido's Avatar
Quoted: 3 Post(s)
Any chance you could keep the mud flaps with 275 65 20? I can with 285 60 20. Might go with Toyo AT2's and want to know before I make that decision. Thanks
viper 2-way alarm/starter, tonneau cover, spray in boxliner, bug deflector, tekonsha prodigy brake control, rock tamer mud flaps, Husky floor liners, LED taillights, LED 3rd brake light, BHLM, TRD sway bar, OEM Fender flares, Tow mirrors, Fuel offroad boost, 285 60 20 Goodyear Duratrac's, LRO 3/1 and Firestone airbags.
thompsonreido is offline
The Following User Says Thank You to thompsonreido For This Useful Post:
post #21 of 42 (permalink) Old 01-30-2013, 12:18 AM
Powertechn2's Avatar
Quoted: 1100 Post(s)
Truck looks good.
If you think the rancho springs were a bear to compress, try compressing the trd steins....
I had to swap my springs over after a lil too in depth conversation with rancho, the ql only gets about half the lift if you install them on a trd stein equipped truck (mine is a rw) unless you swap the stein springs over...
I am GLAD to see they get the correct lift on a non trd steined truck...
before (brand new)
after ...
(bfg's)
New wheels... (sans center caps, was in a hurry)
dirty enough pic to show the wheel well clearance...
and you can call me Power.
Powertechn2 is offline
post #22 of 42 (permalink) Old 01-30-2013, 11:21 AM Thread Starter
I don't see why not...though some of it may depend on your offset. The stock wheels I have are +60 or else I would have done 285/65/20 and I don't want to add spacers. Also I only have the little flaps in the front and not the ones on the rear, but it looks like there would be plenty of space.
thompsonreido (02-26-2013)
post #23 of 42 (permalink) Old 01-30-2013, 11:26 AM Thread Starter
Originally Posted by Powertechn2 View Post
Truck looks good.
Thanks, I'm very happy they worked out good. I actually think they have started to settle now in the front as it almost had a Baja look, but now it seems to have settled and looks more level now.
post #24 of 42 (permalink) Old 01-30-2013, 11:37 AM Thread Starter
Here's some slightly better pictures I was able to snap:
post #25 of 42 (permalink) Old 02-04-2013, 07:39 PM
Finally had mine installed today. How can you see the adjustments to change anything? They say they are 9 way adjustable and I dont see enough marks on the small turn dail tell to be 9 way. Hell I cant see what I have it on to make sure they are the same. Any advice?
post #26 of 42 (permalink) Old 02-04-2013, 07:51 PM
Count the clicks from all the way soft.. (counter clockwise).
Hope the shop has the adjuster facing the right way.
post #27 of 42 (permalink) Old 02-05-2013, 10:34 AM Thread Starter
They should be set at the softest setting from the factory (which is #1 as the softest and #9 as the stiffest). The numbers are broken down 1,3,5,7,9....the spaces in between those numbers are considered "clicks" as well. Right now I'm running #6 in the fron and #5 in the rear. To adjust the ones in the rear you will need to crawl under the truck to access the knobs. The ones in the front will require you to turn the wheel to full lock in either direction to access each side at a time. Like he said ^^, hopefully the faced the knobs out so you have access to them.
post #28 of 42 (permalink) Old 02-06-2013, 12:17 AM
Thanks I really appreciate the responses. Its a pain to see the numbers on the dail.
post #29 of 42 (permalink) Old 02-06-2013, 07:34 AM Thread Starter
Make sure and post some pics so we can all see the progress on your truck!
post #30 of 42 (permalink) Old 02-26-2013, 02:25 AM
Does anyone know how much lift do the rancho rear shocks allow? I know it doesn't lift it any but the bilstein 5100 rear will allow up to 1" lift, so I was wondering if the rancho allow the same.
2008 Tundra CrewMax TRD 5.7L
2001 Lexus GS430 (low and wide)
1999 Corvette (500hp)
jalam321 is offline
