Help me decide!!! - TundraTalk.net - Toyota Tundra Discussion Forum
Old 12-06-2012, 03:59 PM   #1 (permalink)
flippindrew's Avatar
Help me decide!!!
Guys, I need some assistance. I need your input as to what wheels to go with and what size for a set of Nitto Terra Grapplers. Your input is appreciated!!!!!
And size, I'm stuck between 285/65/R18 E, and 275/70/R 18 E.
Which do you like?
flippindrew is offline   Reply With Quote
Old 12-06-2012, 04:07 PM   #2 (permalink)
chphilo's Avatar
I like Goliath and XD Addict. But are you planing to lift your truck or keep it stock? What offset will suit your needs? If you are gonna keep it stock, I would say get Goliath with 275's. I like 285's, but 285's are substantially more expensive than 275's.
2010 Tundra, CM, 4x4, 5.7, TRD Off Road, Silver Sky Tundra Club #7, TWACC #100
Toyota Stepboards, Tint, Pioneer AVIC Z140BH, Pioneer ND-BC5 Camera, Metra Axxess, Line X (Extra, Color Match), ValuGard Undercoat & Rust Inhibitor, AVS Window Visor, Clazzio (black/red leather), TRD Cat-Back Exhaust, TRD Intake, Toyota Hood Protector, Husky WeatherBeater, Westin Ult BB, Westin Lights, Moto Metal 961, BAKFlip F1
chphilo is offline   Reply With Quote
The Following User Says Thank You to chphilo For This Useful Post:
flippindrew (12-06-2012)
Old 12-06-2012, 04:44 PM   #3 (permalink)
I'll be keeping the truck stock height. I'm not worried about the price of the tires since I won a set from Nitto So.... won't have to worry about offset etc. Would you still stick with the 275 or go 285 with that?
Old 12-07-2012, 08:42 AM   #4 (permalink)
Bump.... c'mon guys I need some input!
Old 12-07-2012, 09:01 AM   #5 (permalink)
chphilo's Avatar
275/70/18 is roughly 1/2 inch taller and 285 is about 2/5 inch wider. If I were you, I would go with 285. I like wider tires.
By the way, congratulations.
Old 12-07-2012, 09:04 AM   #6 (permalink)
JCv2.0's Avatar
Gameroom cash: $2213388
Goliaths on 285s
Old 12-07-2012, 09:14 AM   #7 (permalink)
Well after doing some research I found that if I want to keep everything stock (which I do), I will have to stick with a 275/65/R18 for a 18x9 wheel with a +18 offset. Does this sound correct to you guys?
Old 12-07-2012, 09:59 AM   #8 (permalink)
chphilo's Avatar
For these tire sizes, even the stock wheels are okay (+60 offset or + 50 for Rock Warrior). Lower offset simply means that it will be pushed out of the wheel well more.
Offset becomes more problematic if you want to fit larger tires. The safe offset for larger tires is around 35mm. Anything lower, you risk having to modify the body mount. Anything higher, you risk rubbing the skid plate or uca.
I got 18 mm offset with stock tires and it sticks out roughly about 1 inch beyond the fender. I like to get Bushwacker pocket style fender flares, so I wanted them to stick out more than the stockers. If I were not interested in fender flares, I would go with Goliath (safe offset in case i want to go with a larger tire and I really dig their looks).
flippindrew (12-07-2012)
Old 12-07-2012, 10:00 AM   #9 (permalink)
JCv2.0's Avatar
That'll work
The Following User Says Thank You to JCv2.0 For This Useful Post:
Old 12-07-2012, 10:57 AM   #10 (permalink)
You guys are awesome. So not to further publicly humiliate myself lol, chphilo I sent you a PM.
Old 12-07-2012, 11:24 AM   #11 (permalink)
I went with the Black XD Hoss on my truck. 20x9 +30 offset. Went with a Nitto Terra Grappler 305/55/20 and it fit with no rubbing.
2011 Tundra CM 4x4 TRD Offroad, SR5, Spruce Mica, Zone 3/1 lift, 20x9 XD Black Hoss, 305/55/20 Nitto Terra Grappler, TRD Skidplate, Sunroof, Cold Weather Package, Deck Rail System, etc...
Clarion NX501 NAV/DVD, 2 RE Audio SRX 10's in a custom vented box, HiFonics Brutus 1200.1, Stinger capacitor, 6K 35W HIDs in Fogs, and Low Beams, Plasmaglow Fire and Ice Light Bar, Rhino Liner Hardline, Tri-Fold Bedcover
stroked383z is online now   Reply With Quote
Old 12-07-2012, 11:37 AM   #12 (permalink)
Mfour's Avatar
I like the Hoss on 285's
Mfour is offline   Reply With Quote
Old 12-07-2012, 11:39 AM   #13 (permalink)
EUPHOR1C's Avatar
Number 2
KORE 2.5 FOX COILOVERS
CST SPINDLES
TOTAL CHAOS UCA
35 x 12.50 x 20 TOYO M/T
REAR 3 in BLOCKS and COACHES +3 SHACKLES
20 x 10 FUEL HOSTAGES
AMP POWERSTEPS -- BAKFLIP HD
Quad Bi-Xenon Retrofit (FX-R 2.0 & Mini H1) Oracle Halos
BIG RIG CLUB MEMBER #50
EUPHOR1C is offline   Reply With Quote
Old 12-07-2012, 01:10 PM   #14 (permalink)
I'm with you EUPHOR1C, I'm digging the Addict's on 285's.
Old 12-07-2012, 01:24 PM   #15 (permalink)
Well, it's sealed. Nitto Terra 285/65/18 on XD Hoss's 18x9 +25 offset from Discount Tire Direct. Am I f'ed lol? Tell me I don't smell trimming?
