I, along with many others with the RW wheels, have been putting up with clicking...almost as if a rock is stuck in the tread. The clicking sound will come and go, and get very loud and then quiet down. At first it was the driver front, made an apt with the dealership b/c I was convinced it was a bad cv joint. After running across various threads of others w this issue, I started to think it was solely an issue with the wheel...especially once all of my wheels started to click. I tried removing the beadlock rings, soaking the lug nuts in silicone lubricant, and cleaning up the mating surfaces of the hub and wheel. None of these quieted the sound. The only trick was to hose the wheels down with water, let sit over night, and the clicking would be dramatically reduced the next day. After a few months of listening to this annoying sound, I've finally narrowed it down to the useless McGard spline drive lug nuts with the free floating conical washer. When I pulled each lug nut and attempted to pack grease b/w the nut and washer during my last "fix", a few were spinning free while others were corroded and stuck solid. The sad thing is that the these trd lug nuts retail for $175. Very outrageous.
In order to fix this, I'm going to try running a standard 14 x 1.5 conical 60degree taper lug nut without the floating washer. I have never had an issue with any of my past vehicles using the standard type lug nuts without the floating washer built in on aluminum wheels. Should fix the issue.
Please comment if you've ever had a clicking noise. I'll keep everyone posted.
The Following 2 Users Say Thank You to midwest division For This Useful Post:
I don't have any clicking noise with mine with almost 12k miles on it same year as yours except everything is still stock outside of intake/exhaust and my grille.
SSDD
2011 Tundra RW 5.7L (w/mods to come)
2012 Can Am Outlander 800 (27" Mudlites on Motorsport Alloys M10 Reapers)
BDT - If I ever blow my motor, I'm gonna put a 10 second vtec motor in my tundra
The Following User Says Thank You to junior07 For This Useful Post:
2012 DC Lted, 4x4 Barcelona Red debadged
TRD Supercharger
TRD Off Road
TRD Rear Sway Bar
TRD True Dual Exhaust
TRD Rock Warrior wheels w/ Wild Country XTX Sport LT285/70x17
Auburn LSD
Firestone Ride-Rite Airbags, Compressor, & Auto Air Command
Kenwood DNX9980HD
Prodigy P3
Piaa Driving & Fog Lights
The Following User Says Thank You to ronaldjay For This Useful Post:
Thanks for the replys so far. I know a few over on TS have had this issue. Mine didn't start untill this spring. I'm sure the lug nuts with the floating washer stuck from corrosion are the culprits. I'm also sure my areas climate and therefore salted rds can contribute to that.
The Following User Says Thank You to midwest division For This Useful Post:
I have no clicking & the TRD lug nuts w/ washers.
2012 RW wheel set bought used pretty much were brand new.
I plan on using my steel rims in winter time.
The Following User Says Thank You to SnoGirl For This Useful Post:
Mine started to click last week, thought it was the rings, now I have 2 striped ring holes, but for now I glued then in the holes, not really sure how to fix it, but I will figure it out
Maybe I should try what u are doing, I have some much lugs lying around,
2011 ROCK WARRIOR CM, BLACK BEADLOCKS,35" TOYO MT, BHLM, POLICE/FIRE SCANNER, 6000K LOWS AND FOGS, 3"-1" LIFT,CAMERA, NFAB BARS, MAGNAFLOW 12588, CLAZZIOS, METALMILLER CUSTOM EMBLEM AND HITCH COVER. TONNO PRO, SMOKED TAILS AND 3BL, SMOKED RECON LED CAB LIGHTS, N10CEFAB GRILLE INSERT
MY BUILD
Yup, I even heard a situation where a corporate Toyota tech came to inspect a case and said its the rings. It def is not the rings. Swap your lug nuts...I bet your click goes away. I'm going to order some soon and see what happens.
Yep that's where mine started untill this past weekend when my fiancé could here them out of the pass window. I've tried torquing below and above specs with no luck.
The RW lug nut does, it is called a captured conical swivel washer. The locking lug nut does not have a swivel washer, but the rest of the spline drive lug nuts do.
