RW trd lug nuts the cause for clicking sound - Page 18 - TundraTalk.net - Toyota Tundra Discussion Forum
Old 11-13-2012, 01:57 PM   #256 (permalink)
Originally Posted by midwest division View Post
Many of us have removed the rings entirely with the click still being present. No one can pinpoint what it is. But this issue is the least of my worries since my front diff has been howling for the past 5k miles.
Well THAT sucks! Sorry I couldn't be of more help, aftermarket wheels to match a 6" lift and off road bumpers sounds like the fix to me!
Red Rock TRD is offline   Reply With Quote
Old 11-13-2012, 02:05 PM   #257 (permalink)
midwest division's Avatar
Exactly! U think like me! Too bad I told my wife the reason I went with this pkg is for the wheels lol. In time, I think I'll have some methods mounted up. Although now that the weather has been below 50 deg, my wheels don't click anymore. I have countless hours trying to fix the issue with everything idea I could come up with. And everything I tried, the click remained. Then I got so pissed I decide to not worry about it. Go figure I stop messing with it and the temp cools down and the clicking goes away. Now if only the diff howl could go away so I dnt have to go to the dealer... I'd be a real happy camper.
midwest division is offline   Reply With Quote
Old 11-17-2012, 11:38 PM   #258 (permalink)
graystone's Avatar
My story,,,click all the same as urs except this clear coat was coming off rims my dealer long story short ..gave me all NEW rims same tires...no clicking YET! i expect it to come back and almost ask for different rims..
one theory not givin at first i thought the air was catching the lose clear cloat and clicking ..then a little further where the edge off tire goes over rim when we roll it pushes the clear coat off and clicks ..problems with second part some of u have takin off the bead and still heard click ..are all u guys with clicking having issues with clear coat.
anyway have new rw rims and old tires no clicking YET..
graystone is offline   Reply With Quote
Old 11-18-2012, 12:20 AM   #259 (permalink)
Powertechn2's Avatar
Graystone, the issue is that our wheels are not cleared, single coat finish...
I installed me rw wheels about a week ago myself, anti-seized the mating surfaces and so far no clicking...
I did notice a few oddities when I took A close look at the mating surfaces but I'm mobile right now...
Sent from my RAZR MaXX
I put the Laughter in Slaughter
2010 CM RW, blacked out, Led's,Hid's bhlm, 315/60r18 Grabber's, XD wheels, Aero turbine exhaust, Rancho leveled, RW springs, more than meets the eye.
I like weapons.
and you can call me Power.
Powertechn2 is online now   Reply With Quote
Old 11-20-2012, 02:15 PM   #260 (permalink)
Cross-rotated tires/wheels last week and back to clicking.
Old 11-20-2012, 02:59 PM   #261 (permalink)
I should have updated when my clicking came back a few weeks ago. Made it almost 7 weeks and 574 miles click free (from 9/14 to 11/1). Wheels and hub were wire wheeled, a liberal dose of anti-seize was applied and the rings and center caps were removed. Clicking is just as it was before. Mine is always the left/front, even after rotating the tires.
2011 Tundra DC RW (Red)
1966 FJ40 Landcruiser
kb3gun is offline   Reply With Quote
Old 11-20-2012, 03:04 PM   #262 (permalink)
I'm beginning to think its a combination of the studs and hub surface they protrude through. When my truck goes in within the next few months for the front diff issue I'm going to see if I can get them to install new hub assemblies. We will see how it goes. I'm not even to going to mention I think it's the wheels since they will look at me like I'm a nutcase.
Old 11-20-2012, 03:20 PM   #263 (permalink)
c0astie31's Avatar
Remember I said this months ago, lol, I bet longer studs would fix the issues
2011 ROCK WARRIOR CM, 18x9 XD MONSTERS, 35" TOYO MT, BHLM, POLICE/FIRE SCANNER, 6000K LOWS AND FOGS, 3"-1" LIFT,CAMERA, NFAB BARS, MAGNAFLOW 12588, CLAZZIOS, METALMILLER CUSTOM EMBLEM AND HITCH COVER. TONNO PRO, SMOKED TAILS AND 3BL, SMOKED RECON LED CAB LIGHTS, N10CEFAB GRILLE INSERT
MY BUILD
http://www.tundratalk.net/forums/tun...31s-build.html
KILLERWAXXIN
c0astie31 is offline   Reply With Quote
Old 11-20-2012, 03:29 PM   #264 (permalink)
Lol, yep and I've been right there with you since the day you said it. I'm just starting to be more and more convinced that is the issue.
Old 11-20-2012, 03:46 PM   #265 (permalink)
Actually all we would need to do is run a conical tapered lug nut that method states to run with thier wheels. with the extended threads that extend down into the bore of the wheel like the stock sr5 wheels, we would be getting that needed thread engagement back. I dnt think our bolt pattern holes have a large enough diameter to accept this type of lug nut though. This is a serious issue that Toyota and TRD have overlooked, so how do we go about getting them to fix the issue...?
Something like this with that extended thread portion which is found on the other sr5 wheels should do the trick here.
Old 11-20-2012, 03:51 PM   #266 (permalink)
c0astie31's Avatar
So in a sense we would be hub and lug centric if we made our wheels able to use a extended shoulder lug like u posted
MY BUILD
KILLERWAXXIN
Old 11-20-2012, 03:58 PM   #267 (permalink)
Exactly! Now I wonder if we have the room to fit them?
Old 11-20-2012, 04:39 PM   #268 (permalink)
TubeDriver's Avatar
Can you do me a favor and check exactly how much thread engagement the next time you loosen up your lugnuts? My prediction is that you are going to have about 5-7 full turns. 10 is really what you want but I don't see it happening.
The ET lugnuts will probably not fit in the lug holes on the RW wheels.
Tie your shoes, Drive your car, Love your girl!
Widespread Panic
TubeDriver is offline   Reply With Quote
Old 11-20-2012, 05:22 PM   #269 (permalink)
Actually, I did count the turns during my last rotate...it was between 8-10 if I remember correctly. And I'm also afraid the ET style won't fit in the RW holes.
The Following User Says Thank You to midwest division For This Useful Post:
Powertechn2 (11-20-2012)
Old 11-20-2012, 07:01 PM   #270 (permalink)
I got between 8 and 10 turns.
I have a set of et lugs, however I already have my wheels on my truck now and do not have clicking (yet) so I don't want to eph with it and possibly cause clicking lol.
Things that I had noticed... The dealer had installed the new wheels, and shortly there-after I noticed the clicking... The dealer also swapped, rotated, re-balanced... yadda yadda... I never installed the wheels myself or removed them when I had the clicking.
I noticed that when I look at the wheels the hub mating surface didn't seem like it had been flush mating, the hub of the wheel had a circle around it where it seemed like from the center of the stud holes all the way around. The inside of this ring looked like the wheels were seated, the outside of this ring had a light layer of rust, like there was clearance. may have been vice versa, it was getting dark and I had a jack under the truck and no stands and no lift... This was on 2/3 of the wheels, the 4th had never been mounted...
Also, fwiw they did manage to scratch the wheels where the locking lug was due to too large of a socket... Ohh well... I give up this time, they already replaced all 4 wheels, then a 5th, then a tire... The other dealer had already paid for my summer wheels. I am calling it a draw now.
I found it odd that the surface looked literally like the wheel hadn't been fully seated on the hub.
I have not checked with the service manager who had said there may be a tsb, have been too busy... I will try to check with him next week sometime and see if anything has came up or any solution...
I like weapons.
