Originally Posted by ebenke
Is it the width or the height or the weight that affects fuel economy the most?
E Benke, mobile
Sent from my iPhone
I believe it is all 3 that factor in and you really can't say one is more than the other. I think it is the moment of inertia that affects your fuel economy. Your truck has to get the wheels turning and it takes more force to get more weight at a further radius from the axle turning. So, weight, width (contributes to weight), and height all factor in. Now, it gets more complicated because you have an angular momentum once you get moving but this may actually not contribute to the linear momentum of the vehicle...I am pretty rusty on all this stuff. Bottom line, if you go bigger, expect some drop in MPG.
That being said, I am in the same boat. I have a stock 08 DC LTD with 20s and I am getting ready to grab 5100s and new tires. I want to fill out the wheel well with some ATs but not sure what size. I would like to go wider than the 275 and taller as well but not so wide and tall that I rub. I would think I can fit a wide 33" tire...maybe 33x12?
