Originally Posted by Dmov
i'm having 275/70-18 kelly Safari TSR's installed on my truck right now. I bought them from my tire vender i sell Big Rigs 18 wheelers.
The shop putting on the tires said the TPMS sensors won't read through the tire and they are quiet sure what air pressure to put in them.
These tires are very similar to Goodyear duratracs, anyways what tire pressures are you guys running, these are 33" tires.
Thanks in advance...
This is a late response but I emailed the manufacturer about your tire pressure question. I got this response which is pretty useless. Sorry. I tried. Hope you got it all squared away.
Response:
Operating air pressure is determined by the vehicle manufacturer.
If you're using the same size tire that came as original equipment on your
vehicle, the proper air pressure is indicated on the door placard or owners
manual of your vehicle.
The air pressure indicated on the sidewall of each tire is the inflation
pressure required to carry the maximum allowable load for that tire.
Vehicle manufacturers have invested considerable time and testing to
establish an air pressure that will provide a smooth comfortable ride in
addition to an even treadwear pattern.
Our recommendation would be to stick with the air pressure established by
your vehicle manufacturer.
Thank you for your inquiry through our web site.
Jenn Chapman - Consumer Relations Rep
