Aftermarket Sub w/ stock JBL?
After upgrading the headunits on several of my previous vehicles, I don't mind the quality of the JBL system with exception of the sub. It needs help - especially when driving with the windows down.
Has anyone upgraded the sub w/o replacing the stock radio? My biggest concern at the moment is whether I can reuse the stock sub speaker wiring to feed an amp, or get it from the back of the headunit, or worse, purchase a filter to clean up any processed sound such as JL Audio's Cleansweep. Thanks, Mark 08 CM LTD |
you can run after market subs an and amp from the stock head unit.
you might be able to use the stock wiring, but for best sound, i would replace that as well.
White Tundra Club Member #2 |
Yes you can do it. I think many on this forum have done it. I'm in the process of doing this right now to my DC. You just need a speaker/line level to RCA converter which you tap into the left/rear, right/rear speaker wires. Hey Itchy, what kind of sub/amp are you gonna install.
808toytundra 2007 DC SR5 4x4 TRD Zoomers Exhaust TrueFlow XDI Intake Wet Okole's
has anybody with the jbl stereo (that comes with a sub) upgraded that sub? Did you upgrade the sub and amp? what to???
You would need to decide on which subs to use, but these enclosures look pretty slick. SUBWOOFER BOXES - TOYOTA at Sound Off Audio
![]() 08 Tundra DC Revtek 3" Spacer Lift KMC Hoss Wheels Billet Grill |
#7 (permalink) |
Or you could go with something a little more custom built and custom looking.
Like this. Check Out Our Products! |
#8 (permalink) |
Tech12volt your box looks great! I'm considering just 1 sub though which will be more than enough. Do you make single sub boxes? The sub I'm considering is JL's TW5, however it's a 13" sub requiring 0.80 cubic feet of volume and 2.5" mounting depth. Can you accommodate?
Has anyone done a write on removing stock JBL sub? Any suggestions? Any body try the new JL Shallow subs? I'm a huge fan of JL Audio and Boston subs. JL Audio Products: Subwoofers / 13TW5 Thanks, |
#9 (permalink) | |
