HELP! Remove center console on 07 CM??
I'm in the process of an audio upgrade and have hit a wall with how to remove center console. I got the 4 10mm bolts out of the storage well and two plastic push pins on the forward part of the console but it won't move. This is a CREW MAX. PLEASE HELP! Will post pictures of system. Everyone at TS forums just keeps posting "use the search", blah blah blah. I've done that already there and here.
#2 (permalink) Yesterday, 08:52 PM
Jumbo Jet Registered Member My Garage2007 Toyota Tundra Dealer : Deland Toyota Scion Last Online: Today 07:03 PM Join Date: Mar 2007 Location: Florida Posts: 1,096 Rep Power: 3 Re: How to remove center console in 07 CM -------------------------------------------------------------------------------- Youre still missing a few screws. There are the four at the bottom of the tub, but you also need to pop off the silver trim piece where the shifter is and also the larger trim piece that houses the cup holders. Do the cup holders piece first by grabbing it and pulling it up. The clips in the back will release first, then pull it up and back to clear the cig. lighters. Under that are a few screws. Next pop off the silver part of the instrument cluster trim panel only to the right, closest to the climate contols....... there is a hidden screw under there too. __________________ 2007 Tundra Limited DoubleCab 5.7, Silver Sky, TRD
C.M.T.T.F.F. PROUD MEMBER 2008 Crewmax X-SP pakage 20" JTI rims BFG AT KO 285/55/20 Carbon fiber kit Toytec 3" lift w 1" rear WeatherTech floor liners Flo~Pro muffler Model # FP744 aFe CAI on the way
Sorry I can't confirm it , I read this thread and did a search and posted what was described for removal in CM .
#9 (permalink) |
Got this link from Tundrasolutions. Step by step with pics. Hopefully it applies to your truck:
How to Install Stereo 2007 2008 Toyota Tundra |
| Thread Tools | Search this Thread |
