trailer brake wiring harness??
with the towing package, they give you the harness for the brake control. where abouts under the column is the wires to hook the harness up??
-Remove the driver's scuff plate
-Remove the left hand kick plate -At the top of the panel you should find the plug. Mine was wrapped up pretty good to keep it from rattling. If i remember correctly, it also had a "dummy plug" installed in the harness. Hope this helps. |
#7 (permalink) | |
Wiring Harness???
#8 (permalink) |
Mine was against the left side, kind of forward. Had one wrap of electrical tape around the plug. Very difficult to find. They tucked it up there pretty good. I put mine a little higher than the picture above, just under those switches.
2007 Tundra D/C Ltd 4wd 2005 Tundra D/C SR5 2wd 2004 Sequoia SR5 2wd |
#9 (permalink) |
It took me forever to find. It's buried in all those other wires wrapped with tape and the dummy plug makes it look like your not looking at the right one. I pulled on each set of wires looking close to find the tape holding it in. I mounted it between the steering wheel and the console on the 45 degree slant. Very easy for me to reach espescially since I use it so much every day hauling FEMA trailers.
#11 (permalink) | |
Here's My Location
I located mine to the right of the steering column and positioned it so I could see the readout through the steering wheel as I'm driving. I can also easily reach the control to apply emergency breaking power via the lever at the bottom of the unit if it ever became necessay. (See pictures) This location doesn't hit my knee and I'm 6'1" with long legs. Even with the seat all the way up, which I'd never be driving in that position anyway, it still doesn't hit my knee. |
#12 (permalink) | |
#13 (permalink) | |
#14 (permalink) |
i mounted my prodigy in the same place. doesn't rub on my right knee at all. best brake controller I've used.
#15 (permalink) | |
'07 5.7L CM Limited 4x4 | Toyo A/T's 275/60/20 JBA SS Headers/Single-Exit Catback | Volant CAI ReadyLIFT Leveling Kit | Line-X Bedliner |
