Towing issues - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 15 (permalink) Old 04-16-2017, 03:32 AM Thread Starter
ProTundra8806's Avatar
Quoted: 7 Post(s)
Towing issues
So the other day I was towing this setup home from my property and I was going up a hill with a slight head wind, cruise was set on 70. Climbing the hill the truck started to down shift, on the 2nd down shift it but like 4300 rpms and seemed to stall out there. While holding the rpms it was slowing down with the cruise still set. Tap the brakes and get back on the throttle and it pulled normal. Did this twice. Anyone had this issue before?
ProTundra8806 is offline
post #2 of 15 (permalink) Old 04-16-2017, 08:10 AM
tightywhitey's Avatar
Quoted: 252 Post(s)
I don't know much about towing...but I usually turnoff the cruise control when I am climbing a hill.
2015 Silver Sky Toyota Tundra 5.7L V8 CrewMax
-Louisiana Edition
-Husky X-act Contour Liners
-TruXedo Lo Pro QT
-TRD Rear Sway Bar
-Firestick ll Antenna
-G-Tek Door Sill Protectors
tightywhitey is offline
The Following 2 Users Say Thank You to tightywhitey For This Useful Post:
theoat (04-17-2017), wildbill23c (04-16-2017)
post #3 of 15 (permalink) Old 04-16-2017, 08:25 AM
dudleyh's Avatar
Quoted: 75 Post(s)
Yes it is the cruise control. It has been awhile. But I remember going up a hill it downshifted to 3 gear I believe and fell flat on its face. Scared me think something was wrong. Turned off cruise and all was good. So now if I'm pulling a hill I turn off cruise control.
dudleyh is offline
The Following 2 Users Say Thank You to dudleyh For This Useful Post:
ProTundra8806 (04-16-2017), theoat (04-17-2017)
post #4 of 15 (permalink) Old 04-16-2017, 09:19 AM
Quoted: 80 Post(s)
Might be some kind of safety built into the cruise control to keep it from redlining trying to maintain the speed when it's not capable of it??? How big of a hill was it? Seems like you should've been able to hold speed with that load unless you were pulling a really steep grade.
bsktball55 is offline
The Following User Says Thank You to bsktball55 For This Useful Post:
theoat (04-17-2017)
post #5 of 15 (permalink) Old 04-16-2017, 01:19 PM
This will happen with no load. If you read in the owners manual is says to not use cruise while towing which I do on flatter ground with some smaller hills with no problems and not to use it while traveling in hilly roads.
wyo7004 is offline
The Following 3 Users Say Thank You to wyo7004 For This Useful Post:
Dixon Cider (04-16-2017), ProTundra8806 (04-16-2017), theoat (04-17-2017)
post #6 of 15 (permalink) Old 04-16-2017, 10:13 PM
wildbill23c's Avatar
Quoted: 649 Post(s)
Cruise control kids out when a downshift to 3rd or a lower gear. Owner's manual I believe mentions it very vaguely...however when you are towing up a long steep hill you shouldn't be using the cruise control anyhow and this is the reason. You are cruising along, speed drops about 10mph and disengaged the cruise control automatically and scares the unsuspecting driver into thinking something is wrong.
Its not a towing issue, its a driver issue. Just remember in the future to use that right foot of yours to help it up those hills, once you get up the hill you can let off the accelerator and your cruise control will take back over....that is unless you wait till the cruise automatically disengages, then you'll have to hit the resume button.
wildbill23c is offline
The Following 2 Users Say Thank You to wildbill23c For This Useful Post:
charlier (04-17-2017), theoat (04-17-2017)
post #7 of 15 (permalink) Old 04-16-2017, 11:59 PM
BOBONTUESDAY's Avatar
Quoted: 45 Post(s)
I encounter your issue atleast once a month. I've been told it's normal. I wouldn't worry about it. But it freaked me out the first time it happened. when I was towing heavy with my tacoma I couldn't even put it in cruise. If I'm pulling more than 3k on my trailer I don't even put it on cruise.
BOBONTUESDAY is offline
The Following User Says Thank You to BOBONTUESDAY For This Useful Post:
theoat (04-17-2017)
post #8 of 15 (permalink) Old 04-17-2017, 01:12 PM Thread Starter
Quoted: 7 Post(s)
I came from a diesel, first gas truck in 6 years. I'm used to towing 20k pounds with cruise on and never skip a beat. Figured a big v8 with 4.30s should be able to handle a utility trailer with a ranger on it.
post #9 of 15 (permalink) Old 04-17-2017, 01:31 PM
dudleyh's Avatar
Quoted: 75 Post(s)
Don't compare apples to oranges.
I came from a CTD 6.7L.
The Tundra likes rpm's and for what ever reason Toyota shuts the truck down in cruise control when it down shifts to 3rd prolly for safety.
Mine has towed my 2014 Jeep JKU (5000lbs+) many times on a trailer and never had a problem.
dudleyh is offline
theoat (04-17-2017), wildbill23c (04-17-2017)
post #10 of 15 (permalink) Old 04-17-2017, 02:44 PM
The cruise is too abrupt if you ask me. Even with no load it shifts up 2 gears on most hills, and the engine is running above 3,00 rpm. Kills the mileage as well.
nkyrental is offline
The Following User Says Thank You to nkyrental For This Useful Post:
theoat (04-17-2017)
post #11 of 15 (permalink) Old 04-17-2017, 04:55 PM
Bluewoo's Avatar
Quoted: 70 Post(s)
Normal - don't use cruise when towing
Black Tundra Club Member #178
2012 5.7 DC Black on Black SR5-tow-off road.
OEM Running Boards
N-fab Light Bar
V Series A.R.E cap with Yakima roof rack
Yakima MegaWarrior with extension
AIP Failure on 12/30/12
Bluewoo is offline
The Following 2 Users Say Thank You to Bluewoo For This Useful Post:
charlier (04-17-2017), wildbill23c (04-17-2017)
post #12 of 15 (permalink) Old 04-17-2017, 06:02 PM
BRK
I too came over from a CTD. I haven't had this issue yet but i was expecting to experience issues like this.
2017 Tundra CrewMax Limited - Firestone Air Bags (Truxedo Titanium Tonneau Cover, CAI, Dual Exhaust all planned by the end of the year)
2012 Ram 2500 Big Horn CTD (sold)
2012 Nissan Armada Platinum (sold)
2011 Honda Pilot (sold)
2008 Tundra DC SR5 - Air Raid CAI, custom same side dual exhaust by Exhaust Pros (sadly sold in 2010 with 28k)
19991 Pontiac Bonneville - 195k and still drive it 700 miles a week!
BRK is offline
post #13 of 15 (permalink) Old 04-17-2017, 10:16 PM
toyturbodiesel's Avatar
Quoted: 36 Post(s)
Tundras have a cruise control that's like a bi-polar chick. It chills till a bit of incline then after a few mph drop it wakes up screaming about the need for fuel and lower gears. Best not to use in hilly areas towing or not. Maybe they are better in later years?
2008 SR5 DC 5.7 MB Chaos rims, Firestone Bags, ARE Cap, AFE CAI, Borla Cat-Back, various other dangly bits and pieces. Retired USAF.
toyturbodiesel is offline
post #14 of 15 (permalink) Old 04-18-2017, 07:27 PM
Bluewoo's Avatar
Quoted: 70 Post(s)
Here ya go
OEM Running Boards
N-fab Light Bar
Bluewoo is offline
The Following User Says Thank You to Bluewoo For This Useful Post:
charlier (04-18-2017)
post #15 of 15 (permalink) Old 04-19-2017, 08:48 PM
Quoted: 3 Post(s)
Towing issues
My 2008 would pull my camper and utv trailer with no issues at all with the cruise control. 2014 has the same issues as described.
dakota3717 is offline
