Improving Towing
Hi, I was just wondering if there any i can add to my suspension to improve it for towing. I know the max towing capacity its 10500 im not trying to go over it. Any body know about the "Air lift load lifter"? or "Maxloader Toyata Tundra Spring Support System "?
Im looking for a 5th wheel i will be driving a lot with it cause my job. |
Welcome , if you use the search there are alot of posts regarding towing with the info you're looking for .
You're welcome .
#5 (permalink) | |
#6 (permalink) | |
#7 (permalink) |
Ok.. I have a 08 Sr5 Double cab and I ve been looking on the internet for the air bags or the spring support system. but i dont know if they really help or make a difference.
on the spring support system it said this: Maintenance free Better handling and control No adjusting needed No clamping bolts, air lines, or compressors Less sway, axle wrap, and vehicle maintenance Factory ride quality maintained when empty Easy, do-it-yourself installation Cost effective Provides an additional 2,500 lb capacity <---- true?? false ?? Limited lifetime warranty |
#8 (permalink) | |
#10 (permalink) |
I had a local shop install my airbags, brake controller and hitch all at the same time. I guess I'm too lazy to do it myself, although it really is within the capability of anyone handy with tools. I had the air bag controller installed as well (a lot more expensive) because I wanted to be able to controll the air pressure easily from the cab of the truck. Now, that might require a little more expertize than just installing the air bags alone. This addition gives you a pressure gauge in the cab; a kind of neat feature, and a lot less hassle when wanting to change the air pressure for various loads.
