#16 (permalink) |
She has twin 509's with 500 hp each...Tops out at 82-85 mph... Not so good on gas LOL
All my friends have Fountains.. I am actually the slowest...Thats ok 82 is fast enough for me
08 Tundra Double Cab, 5.7L, Nav, 20" wheels Tires, Slate Metallic, Retrax, Platinum steps, Corsa Dual sport exhaust |
#18 (permalink) |
I feel ya on the fuel, I hold 205 gallons and with a couple of 525's so fuel can go away fast, especially if you are leaning on the fun sticks
That is the main reason why it only comes out a few times a year. I happen to be lucky and co-own it with a really good friend so that helps offset some of the cost. I wish we had a trailer for it, I am sure it would look good behind my silver DC.![]()
** 2007 Tundra 4.7L 4x4 DC ** Silver Sky Metallic ** K&N Intake ** JC Whitney Nerf Bars (Black) ** And the Glock 30 next to the cup holders
#19 (permalink) |
gboffroad
I'm sure it would look great... Nice boat
08 Tundra Double Cab, 5.7L, Nav, 20" wheels Tires, Slate Metallic, Retrax, Platinum steps, Corsa Dual sport exhaust Last edited by need4speed : 04-30-2008 at 08:28 PM. |
#22 (permalink) | |
07 SlateDC / 12" Custom lift WWW.CUSTOMMOTORSPORTS.COM 37" Toyo Open Country's 20" KMC XD Monster's N-Fab nerfsteps WWW.N-Fab.com N-Fab light bar (4) 9" ProComp quarts halogens Banks Monster Exhaust www.Bankspower.com |
#23 (permalink) |
jtruck618,
The T.T DC is not considered a HD truck..That is correct.. It would be better if it came with 1 extra leaf spring. If you notice in the pic the nose of the boat (tongue) weight was down a bit...It still tracked fine..minimal sway at 70 mph..Never had to put the peddle to the metal to get up to 70...and I rarely used tow haul mode except when i was approching a steep hill...This was the longest tow trip for me...I also was concerned about towing this size boat with the tundra on such a far trip.. The dealership saw my pictures before I bought the truck.. They said not a problem.. and i guess they were right.. Very Impressed
#24 (permalink) |
So you don't use the tow/haul mode at all times? Maybe it works different in the Tundra. I use it in my Silverado when pulling any load. I hit the button and it shifts different, holds higher RPM before shifting up to next gear. When I hit an upward slope, it slightly increases RPM and does not downshift to the lower gear as would a truck without Tow/Haul. Is there an advantage to not have it activated at all times? When Im cruising at highway speeds, the truck runs the same as it would anytime, unless a slope or something of the such. I have an old clunking 4 speed tranny though, maybe it is different with the Tundra's 6 speed.
#25 (permalink) | |
Thanks for the pic !!! ![]()
#26 (permalink) | |
I tried different things to get the best MPG's for the trip home.. The tundra seemed to keep steady speeds without the tow/haul mode activated.. I used it only when going up a steep hill to keep the rpm's up... The Tundra also has a built in tranny brake system.. It is activated whenever you step on the brakes while going down a steep hill...You don't have to be towing anything for this to work.. Nice feature
#27 (permalink) |
The mpg I was referring too was the boat or the truck .
#28 (permalink) |
I would lean towards the truck..." The Boat" forget it...10 gallons an hour cruising at 50 if that
#29 (permalink) |
LOL , I knew the truck would win that one , but 10 gallons an hour wow !
#30 (permalink) |
10 Gallons an hour each engine....I guess its worth it for the thrills.....
