As most of you know, the IBC on the 2016 does not work. Until Toyota comes up with a fix (however they have not officially acknowledged the problem yet) has anyone installed another brake controller?
I've been using the manual slider but that's getting old. I have a P3 so I'd like to install that until there is a fix.
The factory IBC has a ten pin plug in the back of it. The P3, with the Toyota harness (3017p) is a 5 pin plug. So unless I dont use the plug and play harness and just tap into all the wires, is there any other way to do it?
What have you guys with the 2015s done that bought the IBC and installed it into your truck? Is there another harness that you used to plug into the back of the IBC?
