I came across some light reading the other day that helps explain how the loading changes on a tow vehicle (TV) and trailer (TT) when using a weight distributing hitch. I was thinking of creating a force diagram for the exact same thing to illustrate how the forces are distributed, then I found that somebody else had already done it
From RV.net:
START THEORETICAL NUMBERS
A summary of the 150+ posts in this topic has been developed by several of the contributors to explain WHY a weight distribution system might be necessary and WHAT a WD system does to improve a rig's handling:
Without a WD system, the tow vehicle's rear axle load could significantly increase due to leveraging of the tongue weight. Conversely the front axle load will be decreased. These axle load changes will make most tow vehicles unlevel. The decreased load on the front axle can cause a loss of steering control and braking difficulties. The increased rear axle load might exceed that axle's rating, and the load on the receiver might exceed its rating.
A weight distribution system enables a tow vehicle to more effectively handle the tongue weight of a trailer by removing some of the load from the tow vehicle's rear axle and distributing it to the tow vehicle's front axle and the trailer's axle(s). Note - When the WD system is engaged the actual tongue weight does not change. Recommended tongue weight is from 10% to 15%.
Consult your owner’s manual to determine if your vehicle is suited for a WD system.
Several recent posts have discussed WD hitches. One member stopped using his because he felt it was contributing to sway by decreasing the "tongue weight". I hope the following will give a better idea of what the WD hitch does and does not. Questions and comments are welcome.
Example assumptions:
TV wheelbase = 130”
TV rear axle to ball coupler = 65”
Ball coupler to TT axles = 200”
WD spring bar length = 30”
WD spring bar rear end load = 1000 lbs/bar = 2000 lbs total
How the WD hitch works:
Spring bar tensioner pulls UP on rear end of bar and DOWN on TT tongue. DOWN force of 2000 lbs on TT tongue adds a load of 300 lbs at TT axles.
This is calculated using ball coupler as the fulcrum: 2000x30/200 = 300.
Now, having added a load of 300 lbs at the TT axles, we must balance the TV/TT teeter totter. Using the TV’s rear axle as the fulcrum, to balance the 300 lbs at the TT’s axles we must add some load at the TV’s front axle.
The lever arm from the rear axle to front axle is 130”. The lever arm from the rear axle to the TT axles is 65+200 = 265”.
The required balancing load at the front axle is 300x265/130 = 611.54 lbs.
Or, we can calculate the reaction at the TV’s rear axle by treating the TV/TT as a lever with the fulcrum at the TV’s front axle.
The lever arm for the 300 lbs at the TT’s axles is 130+65+200 = 395”.
The lever arm for the rear axle is the wheelbase = 130”.
Since the TT axles are “lifting up” with a force of 300 lbs, this translates to an “uplift” at the rear axle equal to 300*395/130 = 911.54 lbs.
Summary of axle load changes:
TV front axle 611.54 lbs ADDED
TV rear axle 911.54 lbs REMOVED
TT axles 300.00 lbs ADDED
Now it is interesting to consider what happens at the hitch.
DOWN force of 2000 lbs on TT tongue adds a load of 1700 lbs at ball coupler.
This is calculated using TT axles as the fulcrum: 2000x170/200 = 1700.
The UP force of 2000 lbs on the rear ends of the spring bars produces an UP force of 2000 lbs at the hitch end of the spring bars.
The UP force of 2000 lbs minus the DOWN force of 1700 lbs on the ball gives a net UP force of 300 lbs at the hitch.
The vertical load on the receiver has been reduced by 300 lbs.
The vertical load transmitted through the ball has been increased by 1700 lbs.
It is interesting to note that TT weight and “tongue weight” do not enter into these calculations. The WD hitch does not distribute “tongue weight”. It simply removes load from the TV’s rear axle and distributes it to the TV’s front axle and the TT’s axles.
END THEORETICAL NUMBERS
Later in the thread, the author helps to define and differentiate a few terms such as tongue weight and receiver weight/load which often get incorrectly lumped together. From Woodalls:
Tongue Weight: That portion of the TT weight which is carried on the ball coupler as opposed to that carried on the axles.
Hitch Load: The vertical force exerted by the hitch head on the TV's receiver.
Now here a post from page two of the original post on RV.Net using real numbers.
START USING NUMBERS
Lets try using some numbers. Take all the dimensions from my diagram and add your 900# tongue weight.
Back the ball of the Burb under the coupler and raise the jack. What happens to the Burb's axle loads?
Rear axle load INCREASES by 1350#.
Front axle load DECREASES by 450#.
What happened to the "tongue weight"?
Nothing. The coupler still is pressing on the ball with a force of 900#.
Well, the loads on the TV's axles INCREASED by 1350-450 = 900#. Where did that come from? Some trailer weight must have been transferred from somewhere.
Nope, the 900# on the axles simply results from a relocation of the 900# reaction which previously was provided by the tongue jack. The loads on the TV's axles have changed, but the "tongue weight" has not changed.
Now, we are not too happy about the INCREASED load on the rear axle and the DECREASED load on the front axle. So, what can we do about it?
Well, we can install a WD hitch with 30" bars and tension them to 1000# each for a total of 2000#. This INCREASES the front axle load by 612# and DECREASES the rear axle load by 912# giving
TV front axle load = -450 + 612 = 162# INCREASE
TV rear axle load = +1350 - 912 = 438# INCREASE
This means the total load on the TV now has increased by 600#. Before we tensioned the WD bars, the total added load on the TV was 900#. What happened to the other 300#?
It was transferred by action of the WD hitch to the TT's axles. So, of the initial 900# added to the TV, we now have
162# = 18% on the front axle
438# = 49% on the rear axle
300# = 33% on the TT's axles
If we wanted to shoot for the 1/3-1/3-1/3 "distribution", we could increase the WD bar tension from 2000# to 2300#. This would INCREASE the front axle load by 703# and DECREASE the rear axle load by 1048# giving
253# = 28% on the front axle
302# = 34% on the rear axle
345# = 38% on the TT's axles
and this is about as close as you can get to equal thirds with the assumed dimensions.
So, have we distributed the 900# "tongue
weight"?
Nope, it's still where it was to begin with. But we have re-distributed the 900# load which was transferred from the tongue jack to the TV's axles.
Hope this helps.
Ron
END USING NUMBERS
What I gather from this, first of all, is that assuming tongue weight translates directly to payload on the TV is WRONG. The WD hitch distributes a portion of the load back on to the TT's axles, thereby reducing the load shouldered by the TV. A 900# tongue weight (as used in the example) translates to a 600# load on the TV (split 162#/438# front/back on the TV's axles).
Second, which coincides with the first, the simplification of terms we use are often inappropriate and insufficiently describe vehicle loading. It is easy to simplify a TT/TV loading scenario (that's why it's called 'simplify', right?) in to very few components: TV weight, TT Tongue weight, and payload. Add the three together and they can't exceed GVWR. According to observation 1, this is flat out incorrect because TT tongue weight does not equal the load seen by the TV using a WD hitch.
Third, Gross Axle Weight ratings will rarely be approached in a WD hitch setup.
Fourth, payload capacities of these trucks isn't NEARLY as limiting as they are made out to be.
And fifth, these numbers and load percentages DON'T apply to 5th wheel trailers (as much as we wish they would.
Let's use my truck, family, and gear with the numbers above to work out a scenario.
According to the stickers on my door jamb, Toyota says my truck weighs 5,714 lbs, including the payload deduction of the little yellow 'accessory' sticker (though scaled trucks have been known to weigh less). Specs are as follows:
Vehicle weight as delivered: 5714 lbs
GVWR: 7100 lbs
Front GAWR: 4000 lbs
Rear GAWR: 4150 lbs
Total payload capacity: 1374 lbs
Family + dog weight: 427 lbs
Coca Cola stashed in door cup holders and dewzer cups: 8.8 lbs
Upgrades (roll bar, tonneau, stereo, sound deadener): 27+30+13+45 = 115
Travel Trailer Tongue weight: 900 lbs
Travel Trailer weight: (assuming 11% tongue weight) 8182 lbs
My WD hitch: 130 lbs
Weight distribution from tongue weight using (2) 1000# bars:
So, my 8182 lb trailer exerts a total force of 600 lbs on my truck. I have 550.8 lbs of people and gear in the truck (427 + 115 + 8.8) plus a 130 lb hitch. That means that my payload is 600+550.8 + 130 = 1280.8 lbs. Since my payload capacity is 1374, I'm still 100 lbs UNDER my payload. I believe that even keeps things under payload for most CrewMax trucks, as well.
And what's more, if I were to MAX out my towing capacity of 9800 lbs and use (2) 1150# bars instead of 1000# bars, according to the relative percentages presented above, the trailer would exert 668 pounds of force (9800*.11*.62) on my truck. Technically, that would exceed my GVWR by just 24 lbs. Of course, I could just quit drinking so much darn Coca Cola and lose 15 lbs. I'd lose the 8.8 lbs of Coke in the cab, too. Then I would be spot on! Also note that as long as I don't have more than 500 lbs or junk in my truck (which, unfortunately, I do in this example) I would be under the 16,000 lb GCVWR as well. The load that is transferred to the vehicle by the trailer (hitch load or tongue weight, depending on the context) does NOT factor in to GCVW; only the weight of the TT, TV, and passengers with gear are added together to find GCVW.
And just in case you think I started at the end result and worked backwards to 'doctor' the numbers, I didn't. I kept pushing my trailer weight up until I reached max payload. Just so happened it worked out to be max trailer rating. How's that for Toyota engineering! And as for the weight of the Coke, I assumed 4 liters from the beginning, which is where the 8.8 lbs comes from.
What I'm getting at is towing safety is about numbers and driver awareness. We can assume all is OK and just go for it; we can assume it's all too much for our trucks, park them in the mall parking lot while getting groceries, and dicker over rule's of thumb; or we can do the math and figure out what is safe. Either way, assumptions aren't helping anybody. Of course, you would need to start at the beginning by measuring actual distances on your trailer and truck instead of using the ones in the original excerpt (though they are pretty close).
That being said, if you think you are approaching any max capacities, weigh your setup and crunch the data. That will tell you if you are within the capacities of your truck.
Let the keyboard :boxing:, context :machinegunner: , noobie :nunu:, and general:whacky: begin...
From RV.net:
TV wheelbase = 130”
START USING NUMBERS
weight"?
Hope this helps.
Ron
END USING NUMBERS
GVWR: 7100 lbs
Rear GAWR: 4150 lbs
