Supreme Suspension Lifts - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 16 (permalink) Old 07-31-2011, 02:05 PM Thread Starter
Most threads I have read have people recommending the LRO leveling kit. Does anyone have any legit gripes or praises for the leveling kit offered by Supreme Suspension Lifts on ebay. Its half the price and looks pretty solid. I would hate to pay double if its just a name brand thing.
jmiller is offline
The Following User Says Thank You to jmiller For This Useful Post:
ShakerMD (03-05-2014)
post #2 of 16 (permalink) Old 07-31-2011, 02:46 PM
WhatToBuy's Avatar
A lot of people run spacer lifts, I'm not a fan. Here is some info just to be aware of:
Spacer lift problems
2014 Crewmax
Done -
Fox Remote-Resi Coil-Overs, Camburg Ball-Joint UCA's, Fox Remote-Resi Rear Shocks, OME Springs, Method 18's w/ +25mm offset, BFGood-y All-Terrain 285's, Super 40 Dual In/Single Out, De-Badge
WhatToBuy is offline
post #3 of 16 (permalink) Old 08-02-2011, 12:00 AM
Quoted: 3 Post(s)
Don't listen to whattobuy. Is hes fault, I'm spending so much money trying to build a lift "the wright way" The ebay kits will do the same as the LRO. I bought a $75 bucks spacer from ebay and a block from LRO, but never installed, thx to the link whattobuy keep pasting.LOL The Ebay spacer is very good. A couple people here are running the same spacer I bought.
30PlusRetlaw is offline
post #4 of 16 (permalink) Old 08-02-2011, 03:09 PM
WhatToBuy's Avatar
Are you saying I'm a bad influence?!
2014 Crewmax
Done -
post #5 of 16 (permalink) Old 08-02-2011, 03:42 PM
F&@k Y'all, I'm from Texas
Toxarch's Avatar
Quoted: 633 Post(s)
For most trucks, a spacer lift will be fine and have zero problems.
Originally Posted by MORON #1
Toxarch is offline
post #6 of 16 (permalink) Old 08-02-2011, 10:06 PM
Quoted: 3 Post(s)
Yes U R!!!!!!!
post #7 of 16 (permalink) Old 08-02-2011, 10:31 PM
Powertechn2's Avatar
Quoted: 1084 Post(s)
all depends on use...
i prefer an actual lift strut where there is a combination of preload lift and actual strut height lift...
like the toytecs for just spacers ( one preload, one spacer) or the steins, or rancho's or...
Had/gone 2010 CM RW that was sweet,
NOW: 2017 Platinum. Tinted, trd duals, Exo Grapplers.
I like weapons.
and you can call me Power.
Powertechn2 is offline
post #8 of 16 (permalink) Old 08-09-2011, 12:48 PM
sc1978's Avatar
Quoted: 177 Post(s)
I decided to get the 3/1 level kit from supreme suspension, came in a week ago. everything is complete but they sent a wrong set of bolts for the front spacer. called them and they will send the correct bolts at no charge.
sc1978 is offline
post #9 of 16 (permalink) Old 08-09-2011, 02:23 PM
jerrykeely's Avatar
TRD Excluded though
I was looking a the LRO as well. I looked at these after your post. It specifically stated a different kit for the TRD model. I saw nothing about it on the LRO site so I sent them an email. The reply was that the LRO 3/1 will work with all models. Seems odd that the supreme suspension will only do a 2.5" lift for TRD.....
2010 Tundra Crewmax 4X4 TRD
2001 Tundra Doublecab 4X4 TRD Limited
jerrykeely is offline
post #10 of 16 (permalink) Old 08-09-2011, 05:38 PM
Quoted: 3 Post(s)
You will be happy with it. LRO charges too much for their spacer kit and on top off that they charge you $25 shipping.
post #11 of 16 (permalink) Old 09-15-2011, 04:21 PM
sc1978's Avatar
Quoted: 177 Post(s)
Kit has been in for almost a month now. when installed never had the abs/tcs/4lo/4hi lights come on. then again it seems to still have a slight rake with this kit.
Before:
After:
sc1978 is offline
post #12 of 16 (permalink) Old 09-15-2011, 09:21 PM
Quoted: 3 Post(s)
Nice!!!! Now you need bigger tires
post #13 of 16 (permalink) Old 09-16-2011, 09:31 AM
TXTUNDRA2010's Avatar
Installed the 2.5/1 kit with a 3" increase at the front and 1" increase at the rear. Measures 39" f and 40" r, from ground to top center fender well lip. Great quality and shipped and received super fast.
Now running, 285/75/18 Nitto Grabbler AT
TXTUNDRA2010 is offline
post #14 of 16 (permalink) Old 09-16-2011, 03:46 PM
SlateMax's Avatar
Has anyone changed their factory front bump stops while adding lift kits?
2010 Tundra CM 5.7L w/ TRD OffRoad Package
TRD RSB & Shift Knob, Chrome Door Handles, Limited Mirrors w/ Power Fold Mod & 20" Wheels, Platinum Grill, WTech FLs, Backup Sys, Hard Tonneau, Rhino Liner, SS Boards, Recon LED Bars, Nokya Fogs, Anytime Fogs Mod, DDM 35W 5K HIDs, Factory Alarm Activated, Hella LED BRKLTs, V-LEDs, Clazzio Seat Covers, AFe Pro Dry S Filter, Matched Fender Flares, DRL "On" Mod, Bilstein 5100's all around!
SlateMax is offline
post #15 of 16 (permalink) Old 09-16-2011, 04:17 PM
sc1978's Avatar
Quoted: 177 Post(s)
I didnt change my front bump stops. I think it relates if you upgrade your struts and height.....then again i could be wrong...im no expert.
sc1978 is offline
