lower control arm replacement - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 8 (permalink) Old 07-10-2009, 12:44 AM Thread Starter
ducky's Avatar
Quoted: 21 Post(s)
I need to replace my left lower control arm and I noticed that on the inside of both frame mounting points that there is an oblonged washer with hash marks on it, are these set at a specific point. Can I just mark them and put them back in the same spot or is there more to it than that.
2015 trd limited dc mgm
614 OME coil overs 1/4" spacer lr uca ome rear shocks and add a leaf n-fab steps hypertech speedometer calibrator method mr306 18x9 +18 offset wheels 35x12.5xBFG KO2 coachbuilder +3 shackles
ducky is offline
post #2 of 8 (permalink) Old 07-10-2009, 01:08 AM
"I'm your Huckleberry"
Gutz's Avatar
Quoted: 27 Post(s)
What happened to it? I would say marking it and tightening it up to the proper torque should be fine....
2007 RSCB | Forged 5.7 | TRD SC | JBA Headers | Auburn LSD | Cal-Tracs | Smaller Pulley | Audio System | Lowered
Gutz is offline
post #3 of 8 (permalink) Old 07-10-2009, 01:25 AM
Quoted: 397 Post(s)
there's more to it than that,
if the replacement arm is absolutely identical then it should work fine but odds are it's going to a little different so an alignment is in your near future .
restosud is offline
post #4 of 8 (permalink) Old 07-10-2009, 02:30 AM Thread Starter
ducky's Avatar
Quoted: 21 Post(s)
One too many Budwiesers while puting on my lift I punctured the boot on the lower ball joint and have to replace the hole arm to fix it.
ducky is offline
post #5 of 8 (permalink) Old 07-10-2009, 03:25 AM
Quoted: 397 Post(s)
isn't the ball joint removable from the lower arm?
i mean it's bolted on so it should be removable.
restosud is offline
post #6 of 8 (permalink) Old 07-10-2009, 07:11 AM Thread Starter
ducky's Avatar
Quoted: 21 Post(s)
Nope its pressed in, I looked all over for an aftermarket one that was just a ball joint but didnt have any luck.
ducky is offline
post #7 of 8 (permalink) Old 07-10-2009, 10:53 AM
Quoted: 397 Post(s)
my bad.brain fart here!
the ball joint is pressed in from the bottom and bolts to the spindle bracket.
you're right.
did you look into a replacement boot only?
NAPA used to have a decent selection a few years back.
restosud is offline
post #8 of 8 (permalink) Old 07-20-2009, 12:37 AM
Rock auto sells aftermarket lower ball joints for $70.79 each pn #1015281 here's a pic
bullardshaun is offline
