Total Chaos UCA install tips needed - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 20 (permalink) Old 05-19-2017, 01:02 PM Thread Starter
justincase's Avatar
Quoted: 19 Post(s)
I'm installing the Total Chaos UCA this weekend.. Any tips or tricks I need to know?
2016 CrewMax | Method Wheels | BF Goodrich KO2 | Bilstein 6112/5160 | CB shims and +2 Shackles
justincase is online now
post #2 of 20 (permalink) Old 05-19-2017, 03:24 PM
Moderator
Vendor
Dragos28's Avatar
Quoted: 8261 Post(s)
beer
Build Threads
Dragos28 is offline
Azblue (05-20-2017)
post #3 of 20 (permalink) Old 05-19-2017, 03:24 PM
Moderator
Vendor
Dragos28's Avatar
removing the front wheels also will give you some more room to move around
Build Threads
Dragos28 is offline
post #4 of 20 (permalink) Old 05-19-2017, 03:25 PM
Moderator
Vendor
Dragos28's Avatar
its a PITA, but not really.
just take your time and be careful when you remove the long bolt on the UCA, it slides forward but there are tons of hoses and cables in the way.
Build Threads
Dragos28 is offline
Powertechn2 (05-20-2017)
post #5 of 20 (permalink) Old 05-19-2017, 03:25 PM
Moderator
Vendor
Dragos28's Avatar
lmk if you get stuck or need any help, ive done it a few times.
Build Threads
Dragos28 is offline
post #6 of 20 (permalink) Old 05-19-2017, 04:26 PM Thread Starter
justincase's Avatar
Quoted: 19 Post(s)
Thank you sir... any tips on lubing things up? uniball need anything ?
post #7 of 20 (permalink) Old 05-19-2017, 10:05 PM
Moderator
Vendor
Dragos28's Avatar
just spit on it.
other than that, its a straight forward swap. wouldnt hurt to have a friend over to help. i did it myself and it sucked. but its not impossible.
Build Threads
Dragos28 is offline
post #8 of 20 (permalink) Old 05-19-2017, 10:15 PM Thread Starter
justincase's Avatar
Quoted: 19 Post(s)
just spit on it.
Lmao I guess I will follow the instructions
post #9 of 20 (permalink) Old 05-19-2017, 11:37 PM
JOEGUAM's Avatar
Quoted: 70 Post(s)
Good alignment shop post installation
Lifted Tundra Club (LTC) Member #69
Pro Comp 6 Inch Stage II Lift Kit Front MX2.75 Coilovers and Pro Runner Shocks, Fuel Nutz two piece 20x12 with -44 mm offset, Toyo Tire 315x60X20, +3 Coachbuilder1 Shackles, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200
JOEGUAM is offline
post #10 of 20 (permalink) Old 05-20-2017, 04:58 PM
Powertechn2's Avatar
Quoted: 1209 Post(s)
I swapped mine, wasn't actually that bad, other than needing a torque wrench that went high enough to get the values stated.
Even then it took a fair amount of force to hit the number. And some ingenuity to get it to fit.
and you can call me Power.
Powertechn2 is offline
post #11 of 20 (permalink) Old 05-21-2017, 07:16 AM
Quoted: 18 Post(s)
As dragos said worst part is snaking bolt out. Easy swap.
Sent from my SM-G920V using Tapatalk
Andy9743 is offline
The Following User Says Thank You to Andy9743 For This Useful Post:
Dragos28 (05-21-2017)
post #12 of 20 (permalink) Old 05-24-2017, 10:05 PM
GR8White's Avatar
Quoted: 300 Post(s)
These numbers will vary depending on pinch bushings (stock type) or poly bushings though. Poly bushings doesn't require much. Stock bushings require ALOT (like 173 ft lbs)
2012 RW DC. ADS Coilovers and Piggybacks, MCM Fab UCA's, Icon Leaf Pack, 305/70/17 Nitto Terra Grappler G2's, Vision X LED's, full audio system
GR8White is offline
The Following User Says Thank You to GR8White For This Useful Post:
Powertechn2 (05-24-2017)
post #13 of 20 (permalink) Old 05-24-2017, 10:09 PM
GR8White's Avatar
Quoted: 300 Post(s)
And use a non petroleum based grease for the poly bushings. And keep the big bolt loose while you pump grease into the poly bushings through the fittings. Let it ooze out, then tighten, then wipe it down. I used Lucas Oil 10005 Red & Tacky #2 . Stuff is awesome and has some anti corrosion properties in it as well.
GR8White is offline
post #14 of 20 (permalink) Old 05-24-2017, 10:15 PM
My arms use poly bushings, but called for 185 ft/lbs from the mfg if I recall correctly.
Just looked and it was 176lb-ft.
post #15 of 20 (permalink) Old 05-24-2017, 11:05 PM
GR8White's Avatar
Quoted: 300 Post(s)
That's a lot for poly bushings compared to what I've seen from a couple other manufacturers.
GR8White is offline
Powertechn2 (Yesterday)
