Shackles and Bags back on - PSI question - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 2 (permalink) Old 05-15-2017, 09:25 AM Thread Starter
Quoted: 16 Post(s)
I installed mt +3 shackles (no longer have add a leaf or 1" block from 4 inch pro comp lift) and installed the Airlift bags. I must say the ride it much better and the truck sits WAY better in the rear. This is at 15psi. Unloaded. What do you guys run your bags at with an empty bed?
Sk8Surfr is offline
post #2 of 2 (permalink) Old 05-15-2017, 10:25 AM
TacoBlack's Avatar
Quoted: 205 Post(s)
pressure gauges usually have a large degree for error reading low psi like 15psi. keeping that in mind i keep mine at 12psi (using digital calibration gauge) so iknow its 12psi. anything lower seems to increase bed bounce. i also found before i switched to CB bushings i was able to run lower psi wothout the bed bounce. Side note i usually have about 100lbs of gear in the bed at all times.
2014 Magnetic Grey Crewmax Platinum, Toytec coilovers up front, Coachbuilder 2+ shackles, Firestone air bags & bilstein 5100 in the rear. 20x9 Raceline Assault with 295/60/20 Toyo ATII, Debadged, Bak Flip VP, Line-x Liner, LED interior/exterior lights, Puddle lights LED mod, Clifford alarm/starter with windows and sunroof control, Grillcraft 3pc black MX grill, tinted windows, custom Magnaflow exhaust. Nfab wheel to wheel step bars. D2S 5000k Morimoto HID retrofit with BHLM, JL Audio clean sweep, Jl 500/1, Jl 300/4, 2-JL10tw3 subs, Jl ZR 650csi components front and rear.
TacoBlack is offline
