5100s all around w/ Coachbuilder shackles - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 43 (permalink) Old 03-12-2017, 05:08 PM Thread Starter
Quoted: 6 Post(s)
Hey all! Relatively new to the forum--I've been creeping for a few months but this is my first post. I have a brand new white SR5 CM 4x4 on the way, delivery next week, and I'm trying to figure out what I want do re suspension lift. At this point, I'm thinking about going with the 5100s all around. But I really want to maintain some rake because I plan to use the truck to tow a trailer and boat with some regularity and I don't want SBS (saggy butt syndrome). I'm thinking about going with the Coachbuilder shackles on the rear (which I've seen a lot of people say they prefer over a block or add a leaf--do you agree?) but I don't know if going that route will mean that I need some longer shocks in the rear. That is, will the 5100s still work even with the shackles installed or do I need a longer shock?
Thanks!
Jeff Wilkerson is offline
post #2 of 43 (permalink) Old 03-12-2017, 05:21 PM
Quoted: 59 Post(s)
You'd only need the shackle if you went over a certain point up front with the 5100's. Are you doing 5100's to lift or for a better ride?
the cause is offline
The Following User Says Thank You to the cause For This Useful Post:
Redwoods Jay (03-16-2017)
post #3 of 43 (permalink) Old 03-12-2017, 05:26 PM Thread Starter
Quoted: 6 Post(s)
I'm adding the bilsteins for the lift. I want to set them to the highest setting up front, which is why I'd be adding the shackles (i.e., to maintain some rake).
post #4 of 43 (permalink) Old 03-12-2017, 05:29 PM
Quoted: 59 Post(s)
I have no experience either way. But the shackles seem to be the preferred way to lift the rear of the Tundra and are much easier then blocks
Jeff Wilkerson (03-12-2017)
post #5 of 43 (permalink) Old 03-12-2017, 06:32 PM
PMG
PMG's Avatar
Quoted: 107 Post(s)
The rear 5100 allows for up to an inch of lift.
PMG
PMG is offline
The Following 2 Users Say Thank You to PMG For This Useful Post:
Powertechn2 (03-12-2017), Redwoods Jay (03-16-2017)
post #6 of 43 (permalink) Old 03-12-2017, 07:41 PM
DTdr2's Avatar
Quoted: 28 Post(s)
You're talking my exact setup. Went with 5100's on all 4. I did the top setting with 2 Coach Builder shims on the driver side, & 1 on the passenger. For the rears I used the CB +2 Shackles with the Polly Bushings. I absolutely love the ride, and am glad I spent the xtra money. I've got a 1" rake which works for me since I never tow, or haul anything.
Warning: popping the bushings out can be a b****.
DTdr2 is offline
The Following 2 Users Say Thank You to DTdr2 For This Useful Post:
Dixon Cider (03-15-2017), Redwoods Jay (03-14-2017)
post #7 of 43 (permalink) Old 03-12-2017, 07:57 PM
DTdr2's Avatar
Quoted: 28 Post(s)
Forgot to mention, but I dropped the front differential while I was at it, and put on the spacers so my skid plate wouldn't hit. Coach Builder included spacers to drop the carrier bearing. Did it all by my lonesome, & wasn't the easiest, but I got'r done.
DTdr2 is offline
post #8 of 43 (permalink) Old 03-12-2017, 09:06 PM
Quoted: 13 Post(s)
I did the 5100's at the top setting but I used the Toytec shackles on their top setting. It sits about perfect now except I need new tires and rims to finish it off.
New England Tundra Club Member #93
2016 CM MMG SR5
SnottyW is offline
post #9 of 43 (permalink) Old 03-12-2017, 10:56 PM
Powertechn2's Avatar
Quoted: 1241 Post(s)
I only went about 2.5" in the front, sits level. But add any weight in the bed and it will be lower as I only have 1/8-1/4 rake.
I have thought about shackles. If you do anything in the rear a shackle is the way to go.
and you can call me Power.
Powertechn2 is offline
The Following 2 Users Say Thank You to Powertechn2 For This Useful Post:
car9cop (04-10-2017), Redwoods Jay (03-14-2017)
post #10 of 43 (permalink) Old 03-13-2017, 12:07 AM
rruff's Avatar
Quoted: 198 Post(s)
Why? Could use the middle setting, leave the rear alone, and it would ride and handle better.
2016 SR DC Long 4x4. Intermittent wipers added (?!)
Future Offroad RV plans: Bed removed, homebuilt camper installed. Rear seat removed to make room for storage and bikes. King or ADS shocks with 700 lb springs, ~2" lift. Rear leaves, maybe air bags. 18x9 25-35mm rims. Nitto Dura Grappler 305/70r18 (35.2x12.8). And more!
rruff is online now
post #11 of 43 (permalink) Old 03-13-2017, 09:57 AM Thread Starter
Quoted: 6 Post(s)
That's exactly what I'm planning to do. But I want to use the +3 Coachbuilders if I can.
post #12 of 43 (permalink) Old 03-13-2017, 09:59 AM Thread Starter
Quoted: 6 Post(s)
The top setting on the toytec shackles is 1.5" lift, right? And the 5100s were still long enough in the rear?
post #13 of 43 (permalink) Old 03-13-2017, 10:00 AM Thread Starter
Quoted: 6 Post(s)
Not gonna BS you. I like the look with it lifted more. Can sacrifice a little bit in ride quality to look bad ass. And if someone says, well an inch more won't make a huge difference, I say that's not what your wife said.
post #14 of 43 (permalink) Old 03-13-2017, 10:02 AM
DTdr2's Avatar
Quoted: 28 Post(s)
CB Shackles are definitely the way to go. Those bad boys make a huge difference on the handling, and it's a pretty easy install.
DTdr2 is offline
The Following User Says Thank You to DTdr2 For This Useful Post:
post #15 of 43 (permalink) Old 03-13-2017, 12:13 PM
Quoted: 13 Post(s)
That is correct, 1 1/2" lift. As far as I know they are, I didn't install them myself I had a shop do it.
2016 CM MMG SR5
SnottyW is offline
The Following User Says Thank You to SnottyW For This Useful Post:
Sandy712 (04-04-2017)
