Ok, I have a 2015 Crewmax 4x4 limited. W/ TRD suspension. I want to do a small 2-4" lift and was thinking about doing a leveling kit. I have no idea where to begin or what else would need to be done along with the leveling kit. I want to keep my stock TRD tires for now. Would I need to change out my shocks if I added a leveling kit? Would it need an alignment afterwards? Does a leveling kit make the ride a lot rougher? Any advice is appreciated also any input in what kit to use would be great! Thanks a lot!
I use the truck to tow my travel trailer, which is why i don't want to put anything over a 4" lift on it. I don't plan on going off road. It would just be to improve the appearance. the front of the truck definitely seems a lot lower then the back, that's why I thought about leveling it.
3" just about brings it level. For the sake of geometry, if installing coilovers stay around the 3" range, higher will make the truck require 'creative' alignment techniques.
ProComp pro runner SS is just like the 5100's that are so popular (just never in stock)
scrap the idea of any cheap spacer kit. trust us on that!!
at a minimum...OME 612's. for you....most likely OME 614's. you may have to consider new uca's as well. do it right the first time and be done with it. oh..and I cant recommend @Coachbuilder1 shackles and poly bushings enough. just get em!
Irish - I'm with you, if you get an OME 612 kit, why would you need CB shackles? The 612 kit come with rear gear. Lot's of folks recommending them, just never explaining why you would need them in addition to, or instead of the rear components that would come with the 612 kit.
I can tell you the ride quality after coach shackles and poly bushings was amazing!! if you get the full ome kit with add a leafs and all...yes youll get a little height out of it but you are still not going to have the quality and comfort of coach shackles w/poly bushings. I didn't get the ome kit as a whole. I pieced it together (in my sig below). saved money and got exactly what I was recommended to me my a whole gang of people on this forum. couldn't be happier I chose what I chose!
