ABS, Trac, and 4Hi dash lights on after lifting - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 20 (permalink) Old 04-02-2013, 09:50 PM Thread Starter
C_Litt's Avatar
Hey guys. Just installed a set of KING coilovers and a uniball UCA. Within 20 miles of having the lift installed, I have a ABS light and Trac light on... and the 4hi light is flashing occasionally. The truck has not been aligned yet (waiting til Thursday when I get my new tires) and has not had the zero point calibration done. Doesn't it normally take more than 20 miles for this to register and start throwing lights?
Next question... which has been found to be a better method, having the dealer do the calibration or shimming the sensor?
Thanks!
2013 Crewmax Limited 4x4 TRD - White/Redrock
-King Coilovers and Rear Shocks with Resi's
-Camburg Uniball UCA
-35x12.50/20 Falken Wild Peak A/T on 20" Method Standards (+18mm offset)
-6000k 55w Hi/Low HID and 3000k 55w Fog HID
-5% tint w/ 35% windshield
-TRD color matched grill, mirrors, and door handles.
-Powdercoat color matched rear bumper w/ Rigid Dually -D2 flush mount reverse lights
C_Litt is offline
post #2 of 20 (permalink) Old 04-02-2013, 10:01 PM
Jesco's Avatar
Quoted: 5079 Post(s)
Bad abs sensor?
Jesco is offline
post #3 of 20 (permalink) Old 04-02-2013, 10:08 PM Thread Starter
C_Litt's Avatar
I suppose it's possible? But the truck only has 1200 miles on it... no issues up until the coilover install which was just installed about 20 miles ago....
C_Litt is offline
post #4 of 20 (permalink) Old 04-02-2013, 11:26 PM
serberus's Avatar
Quoted: 10 Post(s)
just because the abs was not bad before the lift does not mean the abs didn't get messed up in the process.
CAMBURG COIL OVERS, DEVER 5 LEAF + 3" BLOCK, 20" RBP 96R WRAPPED IN 34" BFG KO, PUTCO FRONT WIND DEFLECTORS, MGHLM, DISCONTINUED SHIFT KNOB, TRD CAI, TOW MIRRORS, DEBADGED, DIPPED BUMPERS,ORACLE COLOR SHIFT HALOS, WEATHER TECH DIGIFIT FLOOR LINERS, GOPRO SILVER EDITION DASH CAM
POTOOWA MEMBER #2
serberus is offline
post #5 of 20 (permalink) Old 04-02-2013, 11:32 PM Thread Starter
C_Litt's Avatar
Would that also cause trac control and 4hi lights?
C_Litt is offline
post #6 of 20 (permalink) Old 04-02-2013, 11:34 PM
Elton's Avatar
its prob the wheel speed sensors the harness more than likely was not disconnected and was stretched
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
debadged 3/2 lift with 35" nitto trail grapplers m/t afe stage 2 intake jba shorty headers rear cats deleted y piped single bbk varitune muffler short 3"'out dumped after rear axle with a 5" tip
Elton is offline
post #7 of 20 (permalink) Old 04-02-2013, 11:36 PM
Elton's Avatar
id unhook the battery for a little while see if that helps any first
Elton is offline
post #8 of 20 (permalink) Old 04-02-2013, 11:37 PM Thread Starter
C_Litt's Avatar
Is that the ABS wire sensor that goes to the caliper (grey plug)?
C_Litt is offline
post #9 of 20 (permalink) Old 04-02-2013, 11:39 PM
serberus's Avatar
Quoted: 10 Post(s)
if you do a search on the forum the two main contributors to the problem you mentioned is 1) severed or damaged abs or 2) AIP failure
POTOOWA MEMBER #2
serberus is offline
post #10 of 20 (permalink) Old 04-02-2013, 11:41 PM Thread Starter
C_Litt's Avatar
Ok. I'll do some forum trolling. Should I take it back to the shop that did the install (Sierra Expeditions) or over to the Dealership?
C_Litt is offline
post #11 of 20 (permalink) Old 04-02-2013, 11:43 PM
Elton's Avatar
dealership have them run the codes then talk to the shop that lifted it
Elton is offline
post #12 of 20 (permalink) Old 04-02-2013, 11:44 PM Thread Starter
C_Litt's Avatar
Also... if it's a severed ABS wire, shouldn't that have registered right away? I didn't have any issues until I was about to pull into my drive way... which is about 20 miles from the shop...
C_Litt is offline
post #13 of 20 (permalink) Old 04-02-2013, 11:46 PM Thread Starter
C_Litt's Avatar
Ok. I'll head to the dealer in the AM.
C_Litt is offline
post #14 of 20 (permalink) Old 04-03-2013, 01:53 AM
serberus's Avatar
Quoted: 10 Post(s)
I didn't damage or severe any wires when I installed my level kit so I don't know, but it seems to be a very common thing. you should be able to inspect your abs wires your self to determine if they are damaged off you can't do it then a dealership works to
POTOOWA MEMBER #2
serberus is offline
post #15 of 20 (permalink) Old 04-03-2013, 02:36 AM Thread Starter
C_Litt's Avatar
I've already pulled both front wheels off and visually inspected everything... nothing looks damaged at all, all in in tact and looks good from what the naked I can see.
However, I just went out to my truck and started it up... dash lights were still on... sat in the truck with it running for a few minutes and the lights went off. Drove it around the block... hit the brakes hard a few times ... no lights came back on.
We'll see what happens in the morning on my drive to the office.
C_Litt is offline
