Rough Country 6" Lift installed..... - TundraTalk.net - Toyota Tundra Discussion Forum
Old 01-02-2013, 01:24 PM   #1 (permalink)
sc1978's Avatar
So I installed RC6"....took longer than I expected...off course without power tools.....other than that my whole body is sore.....I do have directions from RC...but from the looks of it some steps where missing, but it was a no brainer. product/quality meets my expectation. proper tools where in hand.
Day 1 (12/29/2012
Rear:
Rear was simple but took longer than I expected...the blocks had a slight angle on them...I was trying to figure what faces the front. Then comes to which extension bracket goes where...2 of the 3 hole brackets where no brainer as per direction..but for the abs I used the z bracket and for the top bolt on the differential I used the 2 hole bracket. Thats how it worked out for me. Shocks where installed piston down/ with extension on top.....
Day 2 (12/31/2012
Front:
Started the Front on the a.m, inlaws came we ate lunch then back to work. uninstalling was simple.......installed the rear/front crossmember/differential brackets, so I got done about 8ish cause half of the time I was BSing and drinking with neighbors...
Day 3 (1/1/2013)
Started again in the a.m. started working on the struts. installed new struts with preload installed, put everything back New Knuckles with seal/LCA/Steering Link/struts/hub/rotors/calipers/wheel adapter/new skid plate but had trouble lining it up on the holes........ finished around 4ish.....
Today, my buddy is installing the Cooper Discovery SST 325/60/18 on my 18x9 Mambas...cant wait...also alignment will be this weekend....
pics to come.....
I do want to thank members on this board for the info.....so thank you guys and thank you TundraTalk and TundraSolu....
2007 DC 5.7 4x4
Rough Country 6" lift
BW Style pocket flares line-x
Black Mamba 18x9 +35 w/ 2" wheel adapters
Xenon 6000k Hi/Lo
Falken WildPeak 325/65/18
Front and Rear bumper line-x
SLATE METALLIC
sc1978 is offline   Reply With Quote
The Following 2 Users Say Thank You to sc1978 For This Useful Post:
BigBlueAZ (01-25-2013), claridge (01-03-2013)
Old 01-02-2013, 03:33 PM   #2 (permalink)
STRICK's Avatar
subscribing for pics. Congrats!
2007 TUNDRA DC SR5 TRD 5.7
Black Tundra Club Member #69
Truxxx 3/1 Lift, OEM Fender Flares, Tow Mirrors, Limo Tent (Blacked Out), Weather Tech Floor Liners & Window Deflectors, 2 12" Kicker CVT Shallow Subs, Custom Under Seat Box, 800W Polk Audio Amp, Ceramic Brakes, Nurf Bars, Bedliner, Fog Lights, USW Black Low Profile Tool Box, Limited Stubby Antenna, K&N Air Filter
STRICK is offline   Reply With Quote
The Following User Says Thank You to STRICK For This Useful Post:
Old 01-02-2013, 03:42 PM   #3 (permalink)
KDMac015's Avatar
Same as strick^^ eager to see how it looks.
Sent from my SPH-D710 using AutoGuide.Com Free App
Texas Truck Club Member #3
Radiant Red Truck Club Member #46
08 Limited DC:
3" Leveling Kit, AFE Drop In Pro Dry S, Straight Pipe to Y-pipe, 18" XD Rockstars, 35" Mud Grapplers, Westin HDX Headache rack, 4 Hella 700 Lights, VLEDs Amber Footwell Lights
KDMac015 is online now   Reply With Quote
The Following User Says Thank You to KDMac015 For This Useful Post:
Old 01-03-2013, 07:55 AM   #4 (permalink)
sc1978's Avatar
before with 3/1 and BFG 275/70/18
Parts Installed (REAR)
Shoes: Cooper Discover SST 325/60/18
With Lift but with BFG 275/70/18
more to come....
2007 DC 5.7 4x4
Xenon 6000k Hi/Lo
SLATE METALLIC
The Following User Says Thank You to sc1978 For This Useful Post:
Old 01-03-2013, 08:17 AM   #5 (permalink)
"BHLM Master"
Big Tundra's Avatar
Location: Clearwater, Florida/ Greeneville TN- FETC member #3, Sept./Nov./Dec.2011 TOTM/Big Rig Club#11
Looks good, def need those 325's on there, lol!
BIG RIG CLUB MEMBER# 11 2009DC4WD
10.5" lift- PC StgII/Blift/"Coachs" 3" Shackles/T.Choas UCA's/Air Bags/ Bed Rug/ Icon Shifter/20X12 FuelOctanes/38ToyosM/Ts/BHLM/Oraclesx3/V-leds/
3-20"LED Bars/BTLM/Volant CIA/Airaid Throttle Body/RBP Grille/8K Lo's,Hi's/Hyper Cali./AMI Fuel Door/KW DVD/12"PGold sub/Amp Bed Step/ TonnoPro/Bushwacher Flares/PC Traction Bars/"Coachs"Radiator Cover/Shocker XL Horns/Amp Steps/Colormatched surround/"Custom" Alwayslooking F/R Bumpers/GTEK sills/RBP Tips/50"Rigid
Big Tundra is offline   Reply With Quote
The Following User Says Thank You to Big Tundra For This Useful Post:
Old 01-03-2013, 12:07 PM   #6 (permalink)
STRICK's Avatar
NICE! When will you be getting that rubber put on?
Old 01-03-2013, 01:00 PM   #7 (permalink)
sc1978's Avatar
should have everything set by the weekend
2007 DC 5.7 4x4
Xenon 6000k Hi/Lo
SLATE METALLIC
Old 01-03-2013, 09:30 PM   #8 (permalink)
claridge's Avatar
Looking forward to pics..
2007 DC 5.7L 4x4 LTD
Navigation/Backup camera with in dash switch,RedRock leather,Tonneau cover,Magna Drone catback exaust dual out the side, removed now turndowns after muffler. 5" Zone suspension lift, Fuel Dunes 20x9 +20 offset black machined.
claridge is offline   Reply With Quote
The Following User Says Thank You to claridge For This Useful Post:
Old 01-04-2013, 07:50 AM   #9 (permalink)
sc1978's Avatar
I also ordered a carrier bearing drop bracket from RC.....halfway through install, come to find out it does not line up....its like 2mm off....its installed the right way.....as per directions....if installed the other way...it would be off big time....so I ended up using my diffferential spacers that I took off from my 3/1 kit....ended up using those....but still seem to have an angle on the shaft...another inch should do....
2007 DC 5.7 4x4
Xenon 6000k Hi/Lo
SLATE METALLIC
Old 01-07-2013, 07:52 AM   #10 (permalink)
sc1978's Avatar
2007 DC 5.7 4x4
Xenon 6000k Hi/Lo
SLATE METALLIC
BigBlueAZ (01-25-2013), claridge (01-07-2013)
Old 01-07-2013, 06:06 PM   #11 (permalink)
claridge's Avatar
Congrats, looks really good, all these pics on different lifts make it hard to make a decision.
Old 01-07-2013, 10:21 PM   #12 (permalink)
KDMac015's Avatar
Looks really good man. Makes me want my lift even more now.
08 Limited DC:
Old 01-25-2013, 08:37 AM   #13 (permalink)
BoxerCorps's Avatar
Your rig looks great sc1978! I also have the Rough Country lift on my rig, but I am upgrading to Fox 2.0 coilovers all around to allow for more adjustability up front. I should have the shocks on Saturday, but not sure that I will get to that project. I will be installing the LED DRL set I received this week though, and I am purchasing a Rosen/JL Audio stereo system to upgrade my stereo.
BTW, do you by chance live in New Bristow Village (Bristow, VA)? I used to live there a year ago and the houses in your neighborhood look familiar. If you are up for a M&G in the area, or if you need help with any other projects (I have a compressor and air tools), hit me up.
Anthony
2010 Silver Tundra DC - 6" Rough Country lift, Fox 2.0 Coilovers (Front) and Fox 2.0 (Rear), 20x10 Fuel Krank wheels on 35x12.50R20 Toyo Open Country, LED DRL Kit, Tonneau Pro LoRoll, Smittybilt Step Bars, N-Fab Rivet Billet Grille, Fuel Rivet Lower Bumper Billet Grille, Rosen NAV Head Unit, JL Audio Stealthbox and CX Speakers.
BoxerCorps is offline   Reply With Quote
The Following User Says Thank You to BoxerCorps For This Useful Post:
Old 01-28-2013, 08:35 PM   #14 (permalink)
Your truck looks tough. I installed a Pro Comp 6 inch in a friends truck a few months back. The stance is sweet and the ride is really nice. I love the wheels. I used a 1 inch shim under the carrier bearing and didn't notice any vibration.
Fjtoyman is offline   Reply With Quote
Old 01-29-2013, 03:13 PM   #15 (permalink)
sc1978's Avatar
Anthony[/QUOTE]
Man...I sure needed those airtools....it really sucked without it....Im right off sudley manor (victory lakes comm) by victory elementary...
2007 DC 5.7 4x4
Xenon 6000k Hi/Lo
SLATE METALLIC
Crimsoncountry (05-28-2013)
