Anyone else having this issue with Rough Country suspension? - TundraTalk.net - Toyota Tundra Discussion Forum
Old 11-21-2012, 05:17 PM   #1 (permalink)
seanpham79's Avatar
I just had Rough Country's 6 inch lift kit installed and now I feel a little bit of a rear-end "shimmy" upon take-off. The company that installed it said they have to order some-do-hickey part to prevent the take-off-shimmy.
Some info on this matter would be greatly appreciated.
seanpham79 is offline   Reply With Quote
The Following User Says Thank You to seanpham79 For This Useful Post:
Ogtoyfan (11-21-2012)
Old 11-21-2012, 05:20 PM   #2 (permalink)
JCv2.0's Avatar
Gameroom cash: $2211179
You need a carrier bearing spacer
The Following User Says Thank You to JCv2.0 For This Useful Post:
Old 11-21-2012, 05:21 PM   #3 (permalink)
idk i dont really like rough county but i would ask them to see if it was designed to do that could be the shop trying to cover up there fuk up at ur cost...u know
bodio is offline   Reply With Quote
The Following User Says Thank You to bodio For This Useful Post:
Old 11-21-2012, 05:25 PM   #4 (permalink)
seanpham79's Avatar
You had the same problem?
Old 11-21-2012, 05:27 PM   #5 (permalink)
seanpham79's Avatar
They arent charging me for the part or labor. They said that they were told by R.C. its a typical problem with the suspension and the way it fits on tundras specifically...well see if that spacer is the problem.
Old 11-21-2012, 05:31 PM   #6 (permalink)
i see...so when u step on it the rear end sways?
Old 11-21-2012, 05:40 PM   #7 (permalink)
SC Tuna's Avatar
I have an issue. I didn't buy them.
SC Tuna is offline   Reply With Quote
Old 11-21-2012, 05:40 PM   #8 (permalink)
Common problem with any suspension lift on Tundra. It's because we have a 2 piece driveshaft with a carrier bearing. The lift puts it in a bind and the drop bracket straightens it out
2012 CM TRD 5.7 Pyrite Mica
Zone 5" + Shims, Coach Builder's 3" Shackles, Ballistic Wizard 18x9 +14mm, 295/70r18 Trail Grappler
K&N CAI, Magnaflow Performance Exhaust P/N 16485, LED Interior Lights
Stubby Antenna, Nfabs, Floor Liners, Towing Mirrors, Python 574 Remote Start, TPMS Bypass Mod
Build Log
bigbair2002 is offline   Reply With Quote
Old 11-21-2012, 05:48 PM   #9 (permalink)
i have the procomp K5069-MM i dont have any issues with it...as i know of.. when i stomp on it truck is stable and like a rock what should i test for ? swaying?
Old 11-21-2012, 05:58 PM   #10 (permalink)
No sway. It's a vibration in the driveline. The ProComp lift probably came with the carrier bearing drop kit. I believe some lifts come with it and some leave it as an option.
I think most people start feeling the vibration when the rear of the truck is raised 3" or more. Mine had a slight vibration with the 3" block that came with the Zone lift. When I added the +3" shackles it bumped me up to about 4 1/2" lift in the rear and the vibration became very noticeable. I added the drop bracket and it no longer has the vibration or "Shimmy".
Build Log
Old 11-21-2012, 06:35 PM   #11 (permalink)
"Bad Example"
Bad Dad's Tundra's Avatar
All of us have had the same problem, regardless of how we lifted the rear suspension. You lift 2-3" or more, and you get the vibration. 1" or 1.5" carrier bearing bracket reduces or eliminates the problem.
Bad Dad's Tundra is offline   Reply With Quote
Old 11-21-2012, 10:35 PM   #12 (permalink)
It is certainly the carrier bearing. The shop that lifted it should have know to order the carrier bearing drop/spacer when they did the lift. You will get this with pretty much any lift over 4" on a truck with a two piece drive shaft. I have never had a problem with a Rouch Country lift. I think they are great quality for the cost. I will however never install another pro comp or sky jacker. I usually do zone, bds, or rough country. Probably do 2-3 rough country a week for the last 8 years. Not an issue yet. Rest assured you bought a good kit, problem should be solved for you soon once they install the bearing drop.
Danthetireman is offline   Reply With Quote
The Following 2 Users Say Thank You to Danthetireman For This Useful Post:
11Warrior (05-22-2013), Tundra315 (12-13-2012)
Old 11-21-2012, 11:00 PM   #13 (permalink)
theoat's Avatar
The 2wd's need a spacer made to lengthen the driveshaft too.
What's wrong with the Skyjacker kits? One of them comes with a new leaf pack.
Crewmax LTD/NFAB SS/BHLM/LAHM/Husky Classic Liners/Line-x/Skyjacker 3" struts/Skyjacker 0-2 rears/Coachbuilder +2 Shackles/285/60/20 Duratracs
theoat is online now   Reply With Quote
Old 11-21-2012, 11:04 PM   #14 (permalink)
In my experience, a lot of the kits I have received have been incomplete from both companies. I have missing bolts mostly and sometimes actual components. With Skyjacker I have not been impressed with their shocks either. I know several people who have had good luck. I have never had an issue with the bds, zone, or rc which is why I now just stick with them.
The Following User Says Thank You to Danthetireman For This Useful Post:
theoat (11-21-2012)
Old 11-22-2012, 03:55 PM   #15 (permalink)
seanpham79's Avatar
Thanks for the info guys. Im glad to hear its not just this specific brand lift kit.
