Front end noise - TundraTalk.net - Toyota Tundra Discussion Forum
Old 10-27-2012, 10:53 AM   #1 (permalink)
elbine69's Avatar
Front end noise
Anytime when I have the steering wheel cranked all the way to the left there is metal on metal noise coming from what I think is the right front. Its the same sort of noise as like a dust shield rubbing on a brake rotor. I dont see anything that looks like its rubbing or coming into contact with anything. Ideas on what to look for?
2011 Radiant Red Rock Warrior
1993 Mazda B2600i-SFBD in progress
elbine69 is offline   Reply With Quote
The Following 2 Users Say Thank You to elbine69 For This Useful Post:
Mr. Creosote (10-28-2012), socal57chevy (10-28-2012)
Old 10-27-2012, 10:56 AM   #2 (permalink)
theoat's Avatar
Did you get bigger tires? Rubbing on the skidplate?
Crewmax LTD/NFAB SS/BHLM/LAHM/Husky Classic Liners/Line-x/Skyjacker 3" struts/Skyjacker 0-2 rears/Coachbuilder +2 Shackles/285/60/20 Duratracs
theoat is offline   Reply With Quote
The Following 2 Users Say Thank You to theoat For This Useful Post:
Old 10-27-2012, 11:00 AM   #3 (permalink)
elbine69's Avatar
Nope stock tires still.
Old 10-28-2012, 11:47 PM   #4 (permalink)
socal57chevy's Avatar
There is a stop that needs to be greased. It's a convexed area on the knuckle that rubs a stop on the control arm. Grease both sides.
I found a pic in my lowering kit install thread that kinda shows it...
socal57chevy is offline   Reply With Quote
The Following User Says Thank You to socal57chevy For This Useful Post:
Old 10-29-2012, 12:39 AM   #5 (permalink)
theoat's Avatar
Is that just the steer stop?
The Following User Says Thank You to theoat For This Useful Post:
socal57chevy (10-29-2012)
Old 10-29-2012, 11:16 AM   #6 (permalink)
I had a noise like that which ended up being my anti-sway bar. I just removed it.
2008 CM Pyrite Mica SR5 TRD
Snugtop camper with Bedrug
4" X Factor lift
325/65/18 Nitto TG's
XD Monster 18X9 +18
Custom Rock Sliders
TRD Dual Exhaust
TRD Supercharger
Noyac is offline   Reply With Quote
The Following User Says Thank You to Noyac For This Useful Post:
Old 10-29-2012, 06:02 PM   #7 (permalink)
elbine69's Avatar
Thanks socal, Ill give that a try.
The Following User Says Thank You to elbine69 For This Useful Post:
Old 10-29-2012, 07:09 PM   #8 (permalink)
nastyn8's Avatar
Or the brake backing plates, when they are off just a little bit they will squeal only when turning
Lotsa Crap Added
nastyn8 is offline   Reply With Quote
The Following 2 Users Say Thank You to nastyn8 For This Useful Post:
socal57chevy (10-29-2012), theoat (10-30-2012)
Old 10-29-2012, 11:53 PM   #9 (permalink)
Yes. Toyota has used them for years and they make a grunt/grind/scrape noise if you articulate the suspension even a little while at full lock.
Like Nate mentioned, backing plates are another good place to look.
theoat (10-30-2012)
Old 11-08-2012, 02:12 AM   #10 (permalink)
Ramirezus5's Avatar
Mine sounds like it's coming from the back of the truck. Just got a 7" BDS lift. I have no idea what it is but will take to shop for inspection tomorrow
Ramirezus5 is offline   Reply With Quote
The Following User Says Thank You to Ramirezus5 For This Useful Post:
socal57chevy (11-10-2012)
Old 11-10-2012, 12:38 AM   #11 (permalink)
How'd it go? I'd check the U-bolts first, then the springs. The rear springs rust between the leaves and squeak.
