Can I get some thoughts on putting a couple of Bilsteins up front only and setting them at either the middle or highest setting ? Also, How high will the middle setting raise front end ? Thanks !
2013 Silver Sky Metallic TRD SR5 CrewMax
The Following User Says Thank You to dryfly For This Useful Post:
Lots of people do front only. No issue at all. Personally, I like everything matching and they are an improvement over OEM rear shocks. Middle setting is like 1.7" and top setting is like 2.5" if I remember correctly. Middle setting is noticeable but not level. Ride is probably slightly softer than top setting. Top setting will get you close to leveled out as has already been mentioned.
The Following User Says Thank You to ChibbMD For This Useful Post:
Rack failure DID occur. Luckily, I had the dealer do the installation so they covered (warranteed) the new rack. Rack failed at <5000 miles. I'm just under ten now, no more issues.
How long did the rack last with the lift before it blew?
Sent from my C771 using AutoGuide.Com Free App
__________________ JWOUTDOORS: BIG RIG CLUB MEMBER #62
2010 DC TRD 5.7 4x4, TRD dual exhaust, BakFlip F1, Tekonsha P3 Brake Controller, 20x9 Fuel Kranks, 35x12.50 MT Baja ATZ, Toytec coilovers, Bilstein 5100 rear shocks, Coachbuilder1 3" shackles, aFe Pro Dry S drop in filter, Hypertech Speedometer Calibrator, Bushwackers, Realtree AP Wet Okoles
I've read, or heard, that rack failures can be equally attributed to the larger wheels as to the lifts... The added weight and rolling (turning) resistance of the wider tires. I also know that people's racks are blowing out on stock vehicles as well. Though I'm sure with less frequency....
All in all, I'm glad it was the dealer I bought the vehicle from who installed the kit. I considered doing it myself, or through and indy. I'm glad I didn't because it left very little wiggle room for my dealer.
Totally understand. I'd try not to, cross that bridge when and IF you come to it. You may never have to deal with it...
I pulled a lot of info together to give myself a case if they denied warranty. That's what I would suggest for you. Arm yourself with info, just in case. Look for cases wherein there was a stock vehicle whose rack was blown, or cases where it was a lifted vehicle and the dealer chose to warranty it (such as mine)...
Thanks, I'm just keeping my fingers crossed that I never have to go through that mess. I wish it was a case where if it doesn't blow right away, then it's good. But knowing that you drove several thousand miles before it blew worries me. I have been driving with the nannies off just in case there is any merit to that. Do you know what you were doing when yours blew?
