Squeeling Noise when Truck is Moving - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 34 (permalink) Old 03-11-2009, 05:57 PM Thread Starter
My 06 Tundra, 47000 miles, makes this high pitch squeeling noise continually while the truck is moving, even in reverse. It's been going on for about a month now. My first thought was that it was the brake pad wear indicators but if it was wouldn't the noise only occur when the brakes are applied? The brakes are operating normally, no grinding or pulling. The noise occurs continuously when the vehicle is moving. What can this be?
BigDan is offline
post #2 of 34 (permalink) Old 03-11-2009, 11:13 PM
Mickey's Avatar
Quoted: 7 Post(s)
Still have your brakes checked. Even though you haven't applied them the pads are very close to the rotors and anything on them like morning dew rust etc will make noise. If it was down to metal to metal it will still make noise. If this is a brake noise you're hearing.
MIDNIGHT RIDER
THIS TRUCK
CAN TAKE
A HIT
AND KEEP
ON TICKIN'
Mickey is offline
post #3 of 34 (permalink) Old 03-17-2009, 11:41 AM Thread Starter
Thanks Mickey. Is there a product I can purchase at an auto supply store that may stop the squeeking noise, assuming it's the brakes? I'll be handing in the vehicle shortly (end of lease) and would rather put the bucks towards a new Tundra instead of a brake job!
BigDan is offline
post #4 of 34 (permalink) Old 03-17-2009, 11:47 AM
"Stugots"
AXLES ETC's Avatar
Does it do it all the time ? Take it out of gear next time your driving and let me know if it does it still while in nuetraL.
AXLES ETC is offline
post #5 of 34 (permalink) Old 03-17-2009, 07:18 PM Thread Starter
Axles:
Checked it out at lunch. Yes it does it all the time, even in neutral. The noise doesn't get better or worse when the brakes are applied either.
BigDan is offline
post #6 of 34 (permalink) Old 03-18-2009, 12:23 PM
"Stugots"
AXLES ETC's Avatar
Well it might not be in the drivetrain then. Usually if you take it out of gear than you take the load off the drivetrain and the noise shouild go away. So we can eliminate the drivetrain which is good. So it has to be somwhere else, ie,wheel bearing's, rotors,Maybe even a water pump bearing ? Wheel bearings sound like thats the problem if I had to guess without seeing the vehicle I would say thats it. I had a 2002 Tundra and I had a problem with the water pump. It would make a squeel noise. It wound up being the bearing in the pulley on the water pump that was bad.
post #7 of 34 (permalink) Old 03-18-2009, 04:14 PM Thread Starter
Thanks I'll have the wheel bearings checked out. It's a real high pitched sound, quite annoying at low speed when I have the windows rolled down.
Any helpful advice on wheeling bearings?
BigDan is offline
post #8 of 34 (permalink) Old 03-18-2009, 04:23 PM
"Stugots"
AXLES ETC's Avatar
is it 4wd ? Sometimes when the bearings go bad you get a roaring noise. Its hard to say.
post #9 of 34 (permalink) Old 03-18-2009, 04:23 PM
"Stugots"
AXLES ETC's Avatar
Its really hard to diagnois this problem via internet.
post #10 of 34 (permalink) Old 03-18-2009, 04:28 PM
Does it make the noise when you are not in motion? If it does not then that would eliminate the water pump. I would go with the wheel bearing noise or the squeeler alert on the pads is scraping. If this is the case, just bend it a little bit and that will eliminate the problem if you are turning it in. Another thing that I have actually had happen was for a rock to get wedged between the shield and the rotor and cause some squeeling. Just some food for thought.
BTrzebiato is offline
post #11 of 34 (permalink) Old 03-18-2009, 04:46 PM
"Stugots"
AXLES ETC's Avatar
Wouldnt the water pump make that noise either in motion or not ? The engine is still running and the motor would need circulation of the coolant so the pully is gonna turn either way, and it should have a serpentine belt so the bearing is going to be spinning all the time so that shouldnt eliminate the water pump at all right ?
post #12 of 34 (permalink) Old 03-18-2009, 04:52 PM
Check your u-joint once you eliminate your brakes. Sounds like they are dry.
'08 CM Black 4WD TRD SR5
Chris'TRD is offline
post #13 of 34 (permalink) Old 03-18-2009, 04:56 PM
"Stugots"
AXLES ETC's Avatar
Not gonna be a ujoint, You wont get a squeel sound from a bad ujoints, maybe a grinding or clunking noise.Either way with the vehicle in nuetral the driveshaft has no load to it so that cant be it.
post #14 of 34 (permalink) Old 03-18-2009, 05:00 PM
Yes, You will get a squeal in neutral while moving... what still turns the shaft? The gears in the rear end is still moving that turns the drive shaft which will cause the squeal from a dry u-joint.
post #15 of 34 (permalink) Old 03-18-2009, 05:07 PM
"Stugots"
AXLES ETC's Avatar
Yea, but u-joints do not squeel bro. I'm not amechanic but that much I know only because thats what I do for a living. I own a driveshaft and axle company. Usually they clunk or grind from a dry ujoint. But those a non-greasable ujoints so when they go bad its usually a quick process and you'll hear a clunk when you enage it in gear. When ever you put a load on the drivetrain it will be more of a clunk noise than a squeel,Sounds to me like a bearing. It could be a center support bearing on the driveshaft too. which will make a squeel at all speeds. that could very well be it. I'd take it in and have it looked over. If its a center bearing let me know and I can get ya a good aftermarket support bearing a lot cheaper than new.
