Water leaking from exhaust pipe - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 10 (permalink) Old 03-19-2017, 08:32 PM Thread Starter
Quoted: 29 Post(s)
2015 Tundra SR5 TRD with the 5.7L engine. 28K miles.
This morning I noticed a puddle under the middle of my truck. It had been sitting in that position idling as I was hitching the trailer. Another puddle showed up when I got home and the truck was idling. The water is dripping from a joint in the exhaust system just behind what is either the cat converter or the muffler (I"m not sure which). The joint appears to be covered with a clamp of some sort. This joint is under the front end of the truck bed.
I know this water is condensate from the fuel burned in the engine. I'm accustomed to seeing a little drip from the end of the tail pipe, but water dripping from the middle of the exhaust system is not normal in my experience.
This water drip was before and after a 30 mile round trip to the home improvement store. I live in a rural area, so there are no short trips which can cause excessive water to build up in the exhaust system.
It wasn't cold outside; temperature was about 55 degrees when I got home.
If that water is coming out of the exhaust pipe in that position, so is exhaust gas, by my reckoning. However, I've never heard any sound that might be interpreted as an exhaust leak.
Anybody else see this behavior in their truck? Thoughts?
IamRay is offline
The Following User Says Thank You to IamRay For This Useful Post:
Mr. Creosote (03-19-2017)
post #2 of 10 (permalink) Old 03-19-2017, 08:34 PM
Blacksslumina's Avatar
Condensation I'd guess, probably just need to tighten the flange bolts
Blacksslumina is offline
The Following 2 Users Say Thank You to Blacksslumina For This Useful Post:
Dixon Cider (03-19-2017), Mr. Creosote (03-19-2017)
post #3 of 10 (permalink) Old 03-19-2017, 08:50 PM
1lowlife's Avatar
Quoted: 786 Post(s)
I have an aftermarket BA muffler and mine leaks there.
Since you're still under warranty, let them fix it.
OR, this is the gasket that goes there.
Fel-Pro 60461 Exhaust Flange Gasket
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
OEM gasket is like $14......
Take it easy tightening that bolt.
I broke 1 tightening it too much..
Learn it, know it, live it.
Texas Tundra Group #183
1lowlife is offline
Blacksslumina (03-19-2017)
post #4 of 10 (permalink) Old 03-19-2017, 11:32 PM
Wynnded's Avatar
Quoted: 196 Post(s)
I have a BA muffler as well and have put in a couple new gaskets at that junction and they just burn up and leak again.
Tesla > Edison
2011 RCSB 5.7L AWD (not a typo)
Wynnded is offline
post #5 of 10 (permalink) Old 03-19-2017, 11:40 PM
MetalMonkey's Avatar
Quoted: 201 Post(s)
I have the dreaded Flowmaster American Thunder Cat Back system that leaves puddles under the exhaust tips as well. The remainder of the system is pretty much 'water tight' at the joints in the pipe/muffler.
Just a thought here ~ I hope you don't have a coolant leak in the engine somewhere that's causing this. Have a good look at your radiator overflow receptacle to make sure the coolant level is constant. Otherwise, it's merely water ~ a byproduct of combustion in the engine.
MetalMonkey is offline
post #6 of 10 (permalink) Old 03-20-2017, 05:33 AM Thread Starter
Quoted: 29 Post(s)
Yeah, that's my real concern.
The coolant level this morning was about 3/8 inch below the "Full" line on the reservoir. I used a sharpie to put a red dot at the coolant level on the coolant reservoir this morning before I headed out for my daily commute. I'll check it at lunch when the engine is cold again. At only 28K miles with this truck and most of that highway miles, any coolant loss is unacceptable.
IamRay is offline
MetalMonkey (03-21-2017)
post #7 of 10 (permalink) Old 03-21-2017, 01:32 PM
partyguy816's Avatar
Quoted: 43 Post(s)
Mine is under the full line also. I just assumed it came that way. 2016 now has 4400 or so on it.
partyguy816 is offline
post #8 of 10 (permalink) Old 03-21-2017, 09:41 PM
Quoted: 419 Post(s)
if coolant was going down the exhaust pipe.wouldn't you think some smoke would emanate from said pipe when running?
op,are you sure it's not just water coming from the bed?
restosud is offline
The Following 2 Users Say Thank You to restosud For This Useful Post:
Blacksslumina (03-21-2017), Wynnded (03-21-2017)
post #9 of 10 (permalink) Old 03-21-2017, 10:43 PM
Russ80's Avatar
Quoted: 21 Post(s)
By any chance was your truck pointed downhill?
2017 TRD O/R Crewmax w/ 5.7L. TRD Grille, Radflo remote resevoir front coilovers, shackle lift rear, custom skids, custom sliders. 285/75R18 Toyo M/T
Russ80 is offline
post #10 of 10 (permalink) Old 03-22-2017, 08:12 AM Thread Starter
Quoted: 29 Post(s)
Not coming from the bed. We have not had any rain/snow in a couple weeks, rest of truck was bone dry. As for visible steam coming from the pipe; I saw a little steam while driving on Saturday morning, but that seemed normal for a 40-degree morning. I've also had head gasket failures on previous vehicles that were only detected through watching the coolant level as no steam was visible coming from the pipe.
The vehicle was on level ground both times when I noticed the drip.
I've looked at the mark I put on the coolant reservoir before I left the house on Monday morning. No detectable drop in the coolant level to this point, and I've put about 150 miles on it since marking the reservoir. I also idled the truck yesterday during lunch time for about 20 minutes and detected no leak under the truck.
Guess I'll put it into "watch" status.
IamRay is offline
