5.7 starter replacement suggestions - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 5 (permalink) Old 04-08-2012, 10:25 AM Thread Starter
toyturbodiesel's Avatar
Quoted: 36 Post(s)
Any suggestions on removing/replacing the starter on a 5.7 Tundra? The factory procedure is quite involved and I was wondering if there are any shortcuts that anyone has found?
I did post a short procedure I found to keep the starter working till it can be replaced if you find yourself facing the dreaded click. It's in the DIY section.
toyturbodiesel is offline
The Following User Says Thank You to toyturbodiesel For This Useful Post:
Mr. Creosote (04-08-2012)
post #2 of 5 (permalink) Old 04-23-2012, 06:14 AM
I have never seen a 5.7 starter go bad in the 4 years i've been a tech at toyota. I have done plenty if trans on a 5.7 and the starter is a nightmare. It says you have to remove the exhaust manifold but it you can remove the heat shield on the starter first then it will come out. Its like a puzzle, Id pay someone to do it.
O2VW1.8T is offline
The Following User Says Thank You to O2VW1.8T For This Useful Post:
Mr. Creosote (04-24-2012)
post #3 of 5 (permalink) Old 04-23-2012, 07:47 AM Thread Starter
Quoted: 36 Post(s)
I posted a DIY starter removal/replacement. Exhaust manifold did have to come off. All the things Toyota says to remove from the front of the motor can be left alone though. Job took me about 7 hours start to finish, I could do it in 4 now. But it's a lot of work and as these trucks get older more starters will have solenoid issues.
post #4 of 5 (permalink) Old 04-23-2012, 07:02 PM
Starter i can do in 30 minutes to remove and a little longer to install cause the heat shield is a nightmare.
O2VW1.8T is offline
post #5 of 5 (permalink) Old 04-24-2012, 01:26 PM
xxxxxxtomahawk's Avatar
AlldataDIY says it calls for 3.5 hours.
Remove me from this forum.
xxxxxxtomahawk is offline
The Following User Says Thank You to xxxxxxtomahawk For This Useful Post:
