Fan Blade noise
Has Anyone Had A Problem When You First Start The Truck You Hear A Noise Coming From The Front Of The Truck And Sounds Like The Fan Blade Is Hitting Something. Then The Sound Goes Away. The Sound Only Seems To Happen Either First Thing In The Morning Or If The Truck Has Sit For A Period Of Time.
You Know How Tundra's Sound When You First Start The Truck And It Ildes Higher Until It Becomes Warmed Up. Should I Make The Dealer Take Care Of It? |
mine has a noise that i cant describe but goes away fast after fluids are up and running maybe 30 sec to a min after starting
2008 TOYOTA TUNDRA CREWMAXX 5.7 TRD PYRITE MICA 4x4 MADE IN THE U.S.A. PRINCETON INDIANA ![]() MODS DONE ![]() FACTORY ALARM TURNED ON DROP IN K&N FILTER GO-RHINO QUICK RACK EXTANG TUFF TONNEAU FIRE AND ICE LED LIGHT BAR AVS VENTVISORS C.M.T.T.F.F. PROUD MEMBER |
I don't have any noise. Have you looked under the hood right when you turn it on? It might not even be the fan. If it is, it might be something simple. Good luck.
2008 Toyota Tundra SR5 5.7L 4X4 Double Cab Silver Sky Metallica |
Try raising the hood turn over the engine and walk in front to narrow it down. This way you can show and tell the dealership.
MIDNIGHT RIDER ![]() 07 Crewmax Limited Nautical Blue AVS Bug Shield AFE CAI Borla XS Duals Tundra Weather Mats Trail FX SS Nerf Bars Bully SS Step Bar Reverse Camera Fire & Ice LED Light Bar Herculiner Hellwig Anti-Sway Bar Extang Black Max Eurodezigns HID Lights TRD Shifter XM Satellite Radio Samsung MP3 Locking gas cap DEBADGED Blackened Grill DEER KILLER IBTO
i think if you read owners manual it has something to do with the traction control doing a self test . i read something in the manual about a self test on something when you first start truck up coming from under the hood . hope this helps .
My dealer told me it was the air pump making that noise so obviously mine makes that sound as well. Normally when it is cold and on initial start up.
08 Double Cab SR5 5.7 4x4 TRD Pyrite Mica IBTO Mods: Tinted Windows Hurst Shifter Kobalt Narrow Over Rail Tool Box Under Seat Storage Box Toyota Bed Mat Trailer Brake Conroller
#8 (permalink) |
I have had the same noise. I let my truck sit for about 5 days and when I went to start it, there was this metal rattling sound that comes from the right side of the engine compartment. It only lasts for a second or two.
2007 Tundra,TRD Pkg, DC, Limited, Slate, 5.7L Fully De-Badged Black Mod Headlights Back-up Camera & Monitor Color Matched Tailgate Handle Color Matched Fender Flares Bullet Antenna Color Matched Handles Door Window Pillar Mod ...and still savin up $$$ for more mods!!! |
